Digital State Variable Filters
A classic analog filter is the so-called "state variable filter". This blog covers realization of a continuous-time second-order lowpass filter as a state-space model which is then digitized via both forward and backward Euler schemes to produce the so-called Chamberlin form of a digital resonator (which has desirable numerical properties). Finally, the Faust form of the resonator is derived.
Normalized Second-Order Continuous-Time Lowpass Filter
The transfer function of a normalized second-order lowpass can be written as
where the normalization maps the desired -3dB frequency to 1, i.e.,
and the ``quality factor'' Q is defined as
where is a convenient definition for bandwidth in radians per second, given by minus the real part of the complex-conjugate pole locations and in the plane:
Here we assume , so that the poles have nonzero imaginary parts.
A second-order Butterworth lowpass filter is obtained for . Larger Q values give the ``corner resonance'' effect often used in music synthesizers.
Bode Plots for Second-Order Butterworth Filters
Filters of this type are nicely viewed in a Bode plot which shows the magnitude frequency response (in dB) versus a log frequency axis. In matlab we can say, for example,
sys = tf(1,[1,sqrt(2),1]);
bode(sys);
to see the frequency response of our normalized second-order Butterworth lowpass filter.
Note that our lowpass is easily converted to a bandpass or highpass filter by changing the transfer-function numerator from 1 to or , respectively:
bode(tf([0 0 1],[1,sqrt(2),1])); % lowpass bode(tf([0 1 0],[1,sqrt(2),1])); % bandpass bode(tf([1 0 0],[1,sqrt(2),1])); % highpass bode(tf([1 0 1],[1,sqrt(2),1])); % notch
These frequency responses are shown below:
$$y(t) = k_0 + \sum_{n=1}^{\infty} \int_{-\infty}^{\infty}\cdots \int_{-\infty}^{\infty}k_n(t_1,t_2,\ldots,t_n)x(t-t_1)x(t-t_2)\cdots x(t-t_n)dt_1dt_2\cdots dt_n$$
- Comments
