HI everyone, I am going to do a project on implementation of DOA estimation algorithm using MUSIC. I have read the literature about MUSIC and about DOA estimation. Still I am not able to conceive the idea practically. The input signal to the array of antennas (say M antennas) is X. (consider a single snap shot) which is equal to X = (a(theta) * S) + n Then we need to find the eigen value of the autocorrelation matrix of X. There will be M eigen values and M eigen vectors correspondingly. If the number of directions is D (D < M), then the eigen vectors from D+1 to M represent the noise subsspace. So the MUSIC spectrum is given by P(theta) = 1 / (summation from D+1 to M (a(theta) * eigen vectors))^2 This is what I understand from the theoretical stuff I read. Am i right? If I write a program in MATLAB using the above logic, will it be right? Where else can I find some practical examples of MATLAB implementation? Any help will be of great use to me. Thank you.
DOA by MUSIC algorithm
Started by ●August 15, 2008
Reply by ●August 16, 20082008-08-16
On 16 Aug, 00:45, "krish_dsp" <nmkr...@gmail.com> wrote:> HI everyone, > I am going to do a project on implementation of DOA estimation algorithm > using MUSIC. I have read the literature about MUSIC and about DOA > estimation. > Still I am not able to conceive the idea practically. The input signal to > the array of antennas (say M antennas) is X. (consider a single snap shot) > which is equal to > X = (a(theta) * S) + nI suppose S is the steering vector and a(theta) is the amplitude vector...> Then we need to find the eigen value of the autocorrelation matrix of X. > There will be M eigen values and M eigen vectors correspondingly. > If the number of directions is D (D < M), then the eigen vectors from D+1 > to M represent the noise subsspace.Sounds about right.> So the MUSIC spectrum is given byWrong. There is a weide-spread misconception that MUSIC produces a spectrum. It doesn't. The MUSIC algorithm locates steering vectors that are orthogonal to the null space of the covariance matrices. If you look very closely at the computations, no information whatsoever about energy distribution is carried from the signal domain to the MUSIC *pseudo* spectrum.> P(theta) = 1 / (summation from D+1 to M (a(theta) * eigen vectors))^2 > > This is what I understand from the theoretical stuff I read. > Am i right?You didn't define the quantities in your signal model, so with the proviso that a(theta) is the amplitude vector, this is wrong. If a(theta) is the steering vector then the expression makes sense.> If I write a program in MATLAB using the above logic, will it be right? > Where else can I find some practical examples of MATLAB implementation? > Any help will be of great use to me.Keep in mind that you need to pay meticulous attention to detail. Remember, there is no closed-form solutions here, you need to search for the steering vectors that are orthogonal to the null space. Rune
> > If I write a program in MATLAB using the above logic, will it be right? > > Where else can I find some practical examples of MATLAB implementation? > > Any help will be of great use to me.Here is a simple matlab program that I wrote a while ago that shows an example of DOA with MUSIC, hope this help... %clear all;clc;close all theta=[-90:0.1:90]; N=length(theta); %Fixed Limitations d=0.1 %lambda=2*pi/max(w); %d=c*pi/max(w); c=1; M=50; wmax=3*c*pi/d; w=2;%linspace(1,wmax,100); W=length(w); y=zeros(N,W); z=y; wk=2; s=[0.65*exp(j*wk) exp(j*wk)]; k=2; doa=[60 -40]; %Limitations ws=wk*d*sin(pi*doa/180)/c; if(abs(max(ws))>pi | abs(max(doa))>90) %break warning('Aliasing !!') end %Model a=[exp(-j*ws(1)*[0:M-1]') exp(-j*ws(2)*[0:M-1]')]; %x=[s(:,1).*a(:,1) s(:,2).*a(:,2)]; x=a*s' + 0.1*randn(M,1); %Beamformer response bf=zeros(N,1); msc=zeros(N,1); [trasn,R]=corrmtx(x,length(x)-1,'modified'); [u,s,v]=svd(R); E=v(:,1+k:end); for i=1:N %Steer Beam throught theta b=exp(-j*(wk*d*sin(pi*theta(i)/180)/c)*[0:M-1]); bf(i)=b*x/M; b=b'; msc(i)=abs(1/(b'*E*E'*b)); end figure plot(theta,log10(abs(bf))) hold on plot(theta,log10(msc),'r') %line([-doa(1) -doa(1)],[0 1.2]) %line([-doa(2) -doa(2)],[0 max(msc)])
Reply by ●August 19, 20082008-08-19
Thanks everyone... As u told rune, a(theta) is the steering vector and S is the amplitude. But i am not able to get what you were referring to... "Keep in mind that you need to pay meticulous attention to detail. Remember, there is no closed-form solutions here, you need to search for the steering vectors that are orthogonal to the null space." As I understood, when i project the MUSIC spectrum( not referring to the actual meaning of the word spectrum) in a graph or check the values I will get the peak values in correspondence to the DOAs. what do you mean when you say that i need to 'search' for the steering vectors that are orthogonal? I might sound very naieve .pls bear with me. As i read the matrix a(theta) is a (N X M) matrix where N is the number of antennas in the array and M is the number of directions of arrivals. How can I search for the steering vectors that are orthogonal? Can u explain that? b'cos as I read the literature, the N-M smallest eigen values represent the eigen vectors that are orthogonal to noise subspace. I thought, till now that its a striagh forward calculation. i hope you could understand what i am asking. thank you.>> > If I write a program in MATLAB using the above logic, will it beright?>> > Where else can I find some practical examples of MATLABimplementation?>> > Any help will be of great use to me. > > >Here is a simple matlab program that I wrote a while ago that shows an >example of DOA with MUSIC, hope this help... > > >%clear all;clc;close all >theta=[-90:0.1:90]; >N=length(theta); >%Fixed Limitations >d=0.1 >%lambda=2*pi/max(w); >%d=c*pi/max(w); >c=1; >M=50; >wmax=3*c*pi/d; > >w=2;%linspace(1,wmax,100); >W=length(w); >y=zeros(N,W); >z=y; > >wk=2; >s=[0.65*exp(j*wk) exp(j*wk)]; >k=2; >doa=[60 -40]; > >%Limitations >ws=wk*d*sin(pi*doa/180)/c; > >if(abs(max(ws))>pi | abs(max(doa))>90) > %break > warning('Aliasing !!') >end > >%Model >a=[exp(-j*ws(1)*[0:M-1]') exp(-j*ws(2)*[0:M-1]')]; >%x=[s(:,1).*a(:,1) s(:,2).*a(:,2)]; >x=a*s' + 0.1*randn(M,1); > >%Beamformer response >bf=zeros(N,1); >msc=zeros(N,1); > > >[trasn,R]=corrmtx(x,length(x)-1,'modified'); >[u,s,v]=svd(R); >E=v(:,1+k:end); > > >for i=1:N > > %Steer Beam throught theta > b=exp(-j*(wk*d*sin(pi*theta(i)/180)/c)*[0:M-1]); > bf(i)=b*x/M; > b=b'; > msc(i)=abs(1/(b'*E*E'*b)); > >end > >figure >plot(theta,log10(abs(bf))) >hold on >plot(theta,log10(msc),'r') >%line([-doa(1) -doa(1)],[0 1.2]) >%line([-doa(2) -doa(2)],[0 max(msc)]) >
On 19 Aug, 07:35, "krish_dsp" <nmkr...@gmail.com> wrote:> Thanks everyone... > As u told rune, a(theta) is the steering vector and S is the amplitude. > But i am not able to get what you were referring to... > > "Keep in mind that you need to pay meticulous attention to > detail. Remember, there is no closed-form solutions here, you > need to search for the steering vectors that are orthogonal > to the null space." > > As I understood, when i project the MUSIC spectrum( not referring to the > actual meaning of the word spectrum) in a graph or check the values I will > get the peak values in correspondence to the DOAs.You need to be extremely careful about the details here: The peaks in the pseudo spectrum will be located at the wavenumbers wich correspond to the DoAs. But the width or heights of the peaks will not have any relation to any relevant property of the signal.> what do you mean when > you say that i need to 'search' for the steering vectors that are > orthogonal?That's how MUSIC works. The basic recipe goes as - Estimate the spatial covariance matrix - Compute the eigen decomposition of the matrix - Separate the eigenvectors in signal and noise subspaces - Throw away any info about the signal subspace (i.e signal power and phase) {*} - Find the steering vectors that are orthogonal to the basis vectors for the noise subspace [*] This step isn't mentioned in any of the published recipes, but I include it here since you need to look very carefully for what info is used in subsequent computations to see that none of the info one would naively expect to be used actually is used.> I might sound very naieve .pls bear with me. As i read the matrix a(theta) > is a (N X M) matrix where N is the number of antennas in the array and M is > the number of directions of arrivals.'Antenna' is ambiguous; it might mean one sensor or the whole array. I'd say that 'the array contains N sensors.'> How can I search for the steering > vectors that are orthogonal? Can u explain that?By brute force.> b'cos as I read the literature, the N-M smallest eigen values represent > the eigen vectors that are orthogonal to noise subspace.No. These vectors span the noise subspace and are orthogonal to the signal subspace. So the steering vectors towards the DoAs will be orthogonal to the noise subspace.> I thought, till > now that its a striagh forward calculation.You need to search through all the steering vectors and see which ones are orthogonal to the noise subspace. It's straight-forward in one sense, but you can't find a closed-form solution in th egeneral case. There are particular variations of MUSIC which work with uniform linear arrays, which provide 'semi-closed-form' solutions as roots of polynomials. However, the ROOT MUSIC recipe is obsolete as other polynomial root schemes exist which achieve the same goals with prolynomials of about half the degree of the polynomials which occur in at lest the naive versions of ROOT MUSIC. Rune
Thank you rune. I made the mistake in explaining the algorithm. Now I understand what you were explaining.>On 19 Aug, 07:35, "krish_dsp" <nmkr...@gmail.com> wrote: >> Thanks everyone... >> As u told rune, a(theta) is the steering vector and S is theamplitude.>> But i am not able to get what you were referring to... >> >> "Keep in mind that you need to pay meticulous attention to >> detail. Remember, there is no closed-form solutions here, you >> need to search for the steering vectors that are orthogonal >> to the null space." >> >> As I understood, when i project the MUSIC spectrum( not referring tothe>> actual meaning of the word spectrum) in a graph or check the values Iwill>> get the peak values in correspondence to the DOAs. > >You need to be extremely careful about the details here: >The peaks in the pseudo spectrum will be located at the >wavenumbers wich correspond to the DoAs. But the width >or heights of the peaks will not have any relation to >any relevant property of the signal. > >> what do you mean when >> you say that i need to 'search' for the steering vectors that are >> orthogonal? > >That's how MUSIC works. The basic recipe goes as > >- Estimate the spatial covariance matrix >- Compute the eigen decomposition of the matrix >- Separate the eigenvectors in signal and noise subspaces >- Throw away any info about the signal subspace (i.e signal > power and phase) {*} >- Find the steering vectors that are orthogonal to the basis > vectors for the noise subspace > >[*] This step isn't mentioned in any of the published recipes, > but I include it here since you need to look very carefully > for what info is used in subsequent computations to see > that none of the info one would naively expect to be used > actually is used. > >> I might sound very naieve .pls bear with me. As i read the matrixa(theta)>> is a (N X M) matrix where N is the number of antennas in the array andM is>> the number of directions of arrivals. > >'Antenna' is ambiguous; it might mean one sensor or the whole >array. I'd say that 'the array contains N sensors.' > >> How can I search for the steering >> vectors that are orthogonal? Can u explain that? > >By brute force. > >> b'cos as I read the literature, the N-M smallest eigen valuesrepresent>> the eigen vectors that are orthogonal to noise subspace. > >No. These vectors span the noise subspace and are orthogonal >to the signal subspace. So the steering vectors towards the >DoAs will be orthogonal to the noise subspace. > >> I thought, till >> now that its a striagh forward calculation. > >You need to search through all the steering vectors and >see which ones are orthogonal to the noise subspace. >It's straight-forward in one sense, but you can't find >a closed-form solution in th egeneral case. > >There are particular variations of MUSIC which work with >uniform linear arrays, which provide 'semi-closed-form' >solutions as roots of polynomials. However, the ROOT MUSIC >recipe is obsolete as other polynomial root schemes exist >which achieve the same goals with prolynomials of about >half the degree of the polynomials which occur in at lest >the naive versions of ROOT MUSIC. > >Rune >
Reply by ●August 31, 20082008-08-31
Hi.. you have mentioned that there are other root algorithms which are more efficient than the ROOT-MUSIC. Can you mention the names of them? Thank you. bye.>Thank you rune. >I made the mistake in explaining the algorithm. Now I understand whatyou>were explaining. > >>On 19 Aug, 07:35, "krish_dsp" <nmkr...@gmail.com> wrote: >>> Thanks everyone... >>> As u told rune, a(theta) is the steering vector and S is the >amplitude. >>> But i am not able to get what you were referring to... >>> >>> "Keep in mind that you need to pay meticulous attention to >>> detail. Remember, there is no closed-form solutions here, you >>> need to search for the steering vectors that are orthogonal >>> to the null space." >>> >>> As I understood, when i project the MUSIC spectrum( not referring to >the >>> actual meaning of the word spectrum) in a graph or check the values I >will >>> get the peak values in correspondence to the DOAs. >> >>You need to be extremely careful about the details here: >>The peaks in the pseudo spectrum will be located at the >>wavenumbers wich correspond to the DoAs. But the width >>or heights of the peaks will not have any relation to >>any relevant property of the signal. >> >>> what do you mean when >>> you say that i need to 'search' for the steering vectors that are >>> orthogonal? >> >>That's how MUSIC works. The basic recipe goes as >> >>- Estimate the spatial covariance matrix >>- Compute the eigen decomposition of the matrix >>- Separate the eigenvectors in signal and noise subspaces >>- Throw away any info about the signal subspace (i.e signal >> power and phase) {*} >>- Find the steering vectors that are orthogonal to the basis >> vectors for the noise subspace >> >>[*] This step isn't mentioned in any of the published recipes, >> but I include it here since you need to look very carefully >> for what info is used in subsequent computations to see >> that none of the info one would naively expect to be used >> actually is used. >> >>> I might sound very naieve .pls bear with me. As i read the matrix >a(theta) >>> is a (N X M) matrix where N is the number of antennas in the arrayand>M is >>> the number of directions of arrivals. >> >>'Antenna' is ambiguous; it might mean one sensor or the whole >>array. I'd say that 'the array contains N sensors.' >> >>> How can I search for the steering >>> vectors that are orthogonal? Can u explain that? >> >>By brute force. >> >>> b'cos as I read the literature, the N-M smallest eigen values >represent >>> the eigen vectors that are orthogonal to noise subspace. >> >>No. These vectors span the noise subspace and are orthogonal >>to the signal subspace. So the steering vectors towards the >>DoAs will be orthogonal to the noise subspace. >> >>> I thought, till >>> now that its a striagh forward calculation. >> >>You need to search through all the steering vectors and >>see which ones are orthogonal to the noise subspace. >>It's straight-forward in one sense, but you can't find >>a closed-form solution in th egeneral case. >> >>There are particular variations of MUSIC which work with >>uniform linear arrays, which provide 'semi-closed-form' >>solutions as roots of polynomials. However, the ROOT MUSIC >>recipe is obsolete as other polynomial root schemes exist >>which achieve the same goals with prolynomials of about >>half the degree of the polynomials which occur in at lest >>the naive versions of ROOT MUSIC. >> >>Rune >> >
On 31 Aug, 19:32, "krish_dsp" <nmkr...@gmail.com> wrote:> Hi.. > you have mentioned that there are other root algorithms which are more > efficient than the ROOT-MUSIC. Can you mention the names of them?I don't know if the algorith has a name as such, but it was described in a paper by Tufts and Kumaresan in the Proceedings of IEEE in (I *think*) September 1982. Rune
