I have a decimation filter which decimates by 100. Input sampling frequency fclk1 = 1.6MHz, Output Sampling freq flck2 = 16kHz. I am trying to plot the input and output frequency responses. For the input, I use fft function in matlab, and get the magnitudes of my frequency response. To generate the plot X-axis points (i.e., frequencies) I do the following freq = (flck1/fftPtsIn)*(1:1:fftPtsIn/2) (assume fftPtsIn/2 gives an integer) fftPtsIn is the number of input sample points used in the FFT. For output plot, to generate the X-axis points freq = (flck2/fftPtsOut)*(1:1:fftPtsOut/2) (assume fftPtsOut/2 gives an integer). fftPtsOut is the number of input sample points used in the FFT. The problem is that the frequency scale for the output plot only extends to (fclk2)/2. How will I show that all frequency tones higher than (fclk2)/2 are being filtered?
Decimation filter: Output magnitude response
Started by ●July 1, 2010
Reply by ●July 1, 20102010-07-01
>I have a decimation filter which decimates by 100. > >Input sampling frequency fclk1 = 1.6MHz, >Output Sampling freq flck2 = 16kHz. > > >I am trying to plot the input and output frequency responses. > >For the input, I use fft function in matlab, and get the magnitudes of my >frequency response. To generate the plot X-axis points (i.e.,frequencies)>I do the following > >freq = (flck1/fftPtsIn)*(1:1:fftPtsIn/2) (assume fftPtsIn/2 gives an >integer) > >fftPtsIn is the number of input sample points used in the FFT. > > >For output plot, to generate the X-axis points > >freq = (flck2/fftPtsOut)*(1:1:fftPtsOut/2) (assume fftPtsOut/2 gives an >integer). > >fftPtsOut is the number of input sample points used in the FFT. > >The problem is that the frequency scale for the output plot only extends >to (fclk2)/2. How will I show that all frequency tones higher than >(fclk2)/2 are being filtered? >Typo, fftPtsOut is the number of output sample points
analog_fever <usu_vlsi@n_o_s_p_a_m.yahoo.com> wrote:>I have a decimation filter which decimates by 100.>Input sampling frequency fclk1 = 1.6MHz, >Output Sampling freq flck2 = 16kHz.>For the input, I use fft function in matlab, and get the magnitudes of my >frequency response.Any reason you are not using freqz? (Assuming you want to use an off-the-shelf matlab command.)>The problem is that the frequency scale for the output plot only extends >to (fclk2)/2. How will I show that all frequency tones higher than >(fclk2)/2 are being filtered?You need to implement your filter at 16 MHz input and 16 MHz output sample rates, without decimation, then look at its output spectrum. You will not obtain the information you are asking for if you look only at the decimated signal. Your system may not require you to implement the un-decimated filter; but you need to look at it as part of your analysis. Hope this helps. Steve
Reply by ●July 2, 20102010-07-02
>analog_fever <usu_vlsi@n_o_s_p_a_m.yahoo.com> wrote: > >>I have a decimation filter which decimates by 100. > >>Input sampling frequency fclk1 = 1.6MHz, >>Output Sampling freq flck2 = 16kHz. > >>For the input, I use fft function in matlab, and get the magnitudes ofmy>>frequency response. > >Any reason you are not using freqz? (Assuming you want to use >an off-the-shelf matlab command.) > >>The problem is that the frequency scale for the output plot only extends>>to (fclk2)/2. How will I show that all frequency tones higher than >>(fclk2)/2 are being filtered? > >You need to implement your filter at 16 MHz input and 16 MHz output >sample rates, without decimation, then look at its output spectrum. >You will not obtain the information you are asking for if you look >only at the decimated signal. > >Your system may not require you to implement the un-decimated >filter; but you need to look at it as part of your analysis. > >Hope this helps. > >SteveSteve, Thanks for the response. You mean, I have to set my decimation rate to 1, and see the filter output response? But, will the filter frequency response be different for decimated, and undecimated outputs?
Reply by ●July 6, 20102010-07-06
>>analog_fever <usu_vlsi@n_o_s_p_a_m.yahoo.com> wrote: >> >>>I have a decimation filter which decimates by 100. >> >>>Input sampling frequency fclk1 = 1.6MHz, >>>Output Sampling freq flck2 = 16kHz. >> >>>For the input, I use fft function in matlab, and get the magnitudes of >my >>>frequency response. >> >>Any reason you are not using freqz? (Assuming you want to use >>an off-the-shelf matlab command.) >> >>>The problem is that the frequency scale for the output plot onlyextends> >>>to (fclk2)/2. How will I show that all frequency tones higher than >>>(fclk2)/2 are being filtered? >> >>You need to implement your filter at 16 MHz input and 16 MHz output >>sample rates, without decimation, then look at its output spectrum. >>You will not obtain the information you are asking for if you look >>only at the decimated signal. >> >>Your system may not require you to implement the un-decimated >>filter; but you need to look at it as part of your analysis. >> >>Hope this helps. >> >>Steve > > >Steve, > >Thanks for the response. You mean, I have to set my decimation rate to 1, >and see the filter output response? But, will the filter frequencyresponse>be different for decimated, and undecimated outputs? >bump
