Hi everyone. I'm looking to see if anyone would be kind enough to help me out with a few basic questions I'm looking for answers for. Part of my job involves the analysis of the accelerations that are experienced by passengers on roller coasters. This involves fixing accelerometers to rides and analysing the data that they produce. I'm required to post process the data with " a 4-pole, single pass, Butterworth low pass filter using a corner frequency (Fc) of 5 Hz". I am sampling my data at 150 Hz and I am not interested in any acceleration peaks that are less than 200 ms in duration. Could anyone please explain what a Butterworth filter is in laymans terms and why it is needed in this scenario? If you need any extra information then please just leave a comment or message and I will get back to you as soon as possible. Thank you very much
Roller Coaster Analysis
Started by ●January 27, 2011
Reply by ●January 27, 20112011-01-27
On 01/27/2011 11:29 AM, RideAnalyser wrote:> Hi everyone. > > I'm looking to see if anyone would be kind enough to help me out with a few > basic questions I'm looking for answers for. > > Part of my job involves the analysis of the accelerations that are > experienced by passengers on roller coasters. This involves fixing > accelerometers to rides and analysing the data that they produce. I'm > required to post process the data with " a 4-pole, single pass, Butterworth > low pass filter using a corner frequency (Fc) of 5 Hz". I am sampling my > data at 150 Hz and I am not interested in any acceleration peaks that are > less than 200 ms in duration. > > Could anyone please explain what a Butterworth filter is in laymans terms > and why it is needed in this scenario? > > If you need any extra information then please just leave a comment or > message and I will get back to you as soon as possible.I'm not sure if you need to know what a Butterworth filter is, or if you need to have a better understanding of what a low pass filter is. A Butterworth filter is a specific kind of filter, specified in the frequency domain, that is as close to flat in the passband as possible. So if you were to plot it's amplitude response vs. frequency, it would have the closest thing to a straight line response starting at f = 0 and going out. The reason you need a _low pass_ filter in this scenario is because when you measure your acceleration you'll be measuring a whole lot of sharp (i.e. fast) accelerations. These sharp accelerations can be quite large, but because of the way that our bodies are put together, they aren't as harmful to people as accelerations that last longer. The low pass filter reduces the effect of these sharp accelerations, while keeping the effect of the accelerations that likely do cause harm. The reason that a Butterworth, and that specific Butterworth, filter is used, is for two reasons: one, at some point in the past some researcher or industry group decided that it made a pretty good model for assessing what accelerations are going to be harmful, and two, the same or another researcher or industry group decided that it would be easy to reproduce. Since one of the points of measurement standards is to make the results unambiguous, and since "everyone" knows what a Butterworth filter is, that's what was chosen. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
