When I ran ldd on myprogeamExecutable and I got: linux-vdso.so.1 => (0x00007fff08709000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f015360a000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0153245000) /lib64/ld-linux-x86-64.so.2 (0x00007f0153929000) I need to port this to a server. I am wondering how to meet these dependencies - I know the server is 64bit Debian - what Debian commands needs to be issued to meet these dependencies? myprogeamExecutable was generated on a 64 bit Ubuntu (AMD cpu). If Ubuntu binaries are not compatible, I will find a Debian VM and recompile - but wil still have to address the dependencies - what are each of the dependencies mean?
ldd results on binaries from Ubuntu and its dependencies?
Started by ●March 20, 2015
Reply by ●March 21, 20152015-03-21
On 3/20/2015 6:29 PM, speech2020@gmail.com wrote:> When I ran ldd on myprogeamExecutable and I got: linux-vdso.so.1 => > (0x00007fff08709000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 > (0x00007f015360a000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 > (0x00007f0153245000) /lib64/ld-linux-x86-64.so.2 > (0x00007f0153929000) > > I need to port this to a server. > > I am wondering how to meet these dependencies - I know the server is > 64bit Debian - what Debian commands needs to be issued to meet these > dependencies? > > myprogeamExecutable was generated on a 64 bit Ubuntu (AMD cpu). If > Ubuntu binaries are not compatible, I will find a Debian VM and > recompile - but wil still have to address the dependencies - what > are each of the dependencies mean? >Statically link the executable with libraries. The file will be huge but won't require any shared libraries. Google will help. For example: http://stackoverflow.com/questions/3870121/statically-linking-libraries-in-linux Rob.
On 21.3.15 03:29, speech2020@gmail.com wrote:> When I ran ldd on myprogeamExecutable and I got: > linux-vdso.so.1 => (0x00007fff08709000) > libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f015360a000) > libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0153245000) > /lib64/ld-linux-x86-64.so.2 (0x00007f0153929000) > > I need to port this to a server. > > I am wondering how to meet these dependencies - I know the server is 64bit Debian - what Debian commands needs to be issued to meet these dependencies? > > myprogeamExecutable was generated on a 64 bit Ubuntu (AMD cpu). If Ubuntu binaries are not compatible, I will find a Debian VM and recompile - but wil still have to address the dependencies - what are each of the dependencies mean?libm is the mathematics library. The other pieces are present in all user-space runnable code. linux-vdso is a system-call helper used by the C library. libc is the standard C runtime library. ld-linux-x86-64 is the 64 bit dynamic library loader. Ubuntu is a direct derivative of Debian, so your binary should work directly on the server, unless the server system code is so old that it is obsolete. -- -TV
Reply by ●March 23, 20152015-03-23
On Friday, March 20, 2015 at 8:58:54 PM UTC-7, Rob Doyle wrote:> On 3/20/2015 6:29 PM wrote: > > When I ran ldd on myprogeamExecutable and I got: linux-vdso.so.1 => > > (0x00007fff08709000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 > > (0x00007f015360a000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 > > (0x00007f0153245000) /lib64/ld-linux-x86-64.so.2 > > (0x00007f0153929000) > > > > I need to port this to a server. > > > > I am wondering how to meet these dependencies - I know the server is > > 64bit Debian - what Debian commands needs to be issued to meet these > > dependencies? > > > > myprogeamExecutable was generated on a 64 bit Ubuntu (AMD cpu). If > > Ubuntu binaries are not compatible, I will find a Debian VM and > > recompile - but wil still have to address the dependencies - what > > are each of the dependencies mean? > > > > Statically link the executable with libraries. The file will be > huge but won't require any shared libraries. > > Google will help. For example: > > http://stackoverflow.com/questions/3870121/statically-linking-libraries-in-linux > > Rob.When u say> Statically link the executable with librariesdo you mean at run time? Because, it was compiled on a different machine and then I only had to link one library with the "-lm" command. Could you elaborate your reply? Thanks
On 3/23/2015 2:14 PM, speech2020@gmail.com wrote:> On Friday, March 20, 2015 at 8:58:54 PM UTC-7, Rob Doyle wrote: >> On 3/20/2015 6:29 PM wrote: >>> When I ran ldd on myprogeamExecutable and I got: linux-vdso.so.1 => >>> (0x00007fff08709000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 >>> (0x00007f015360a000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 >>> (0x00007f0153245000) /lib64/ld-linux-x86-64.so.2 >>> (0x00007f0153929000) >>> >>> I need to port this to a server. >>> >>> I am wondering how to meet these dependencies - I know the server is >>> 64bit Debian - what Debian commands needs to be issued to meet these >>> dependencies? >>> >>> myprogeamExecutable was generated on a 64 bit Ubuntu (AMD cpu). If >>> Ubuntu binaries are not compatible, I will find a Debian VM and >>> recompile - but wil still have to address the dependencies - what >>> are each of the dependencies mean? >>> >> >> Statically link the executable with libraries. The file will be >> huge but won't require any shared libraries. >> >> Google will help. For example: >> >> http://stackoverflow.com/questions/3870121/statically-linking-libraries-in-linux >> >> Rob. > > When u say Statically link the executable with libraries > do you mean at run time? > > Because, it was compiled on a different machine and then I only had to link one library with the "-lm" command.This just says you need to link with 'libm' - the math library. It doesn't say anything about static linkage.> Could you elaborate your reply? ThanksLibraries can be statically linked into the program when it is built or dynamically linked when the program is executed. If you statically link in all the libraries, the program does not require any shared libraries on the target computer. http://cs-fundamentals.com/tech-interview/c/difference-between-static-and-dynamic-linking.php Rob.
Reply by ●March 24, 20152015-03-24
On Monday, March 23, 2015 at 4:53:44 PM UTC-7, Rob Doyle wrote:> On 3/23/2015 2:14 PM, wrote: > > On Friday, March 20, 2015 at 8:58:54 PM UTC-7, Rob Doyle wrote: > >> On 3/20/2015 6:29 PM wrote: > >>> When I ran ldd on myprogeamExecutable and I got: linux-vdso.so.1 => > >>> (0x00007fff08709000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 > >>> (0x00007f015360a000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 > >>> (0x00007f0153245000) /lib64/ld-linux-x86-64.so.2 > >>> (0x00007f0153929000) > >>> > >>> I need to port this to a server. > >>> > >>> I am wondering how to meet these dependencies - I know the server is > >>> 64bit Debian - what Debian commands needs to be issued to meet these > >>> dependencies? > >>> > >>> myprogeamExecutable was generated on a 64 bit Ubuntu (AMD cpu). If > >>> Ubuntu binaries are not compatible, I will find a Debian VM and > >>> recompile - but wil still have to address the dependencies - what > >>> are each of the dependencies mean? > >>> > >> > >> Statically link the executable with libraries. The file will be > >> huge but won't require any shared libraries. > >> > >> Google will help. For example: > >> > >> http://stackoverflow.com/questions/3870121/statically-linking-libraries-in-linux > >> > >> Rob. > > > > When u say Statically link the executable with libraries > > do you mean at run time? > > > > Because, it was compiled on a different machine and then I only had to link one library with the "-lm" command. > > This just says you need to link with 'libm' - the math library. It > doesn't say anything about static linkage. > > > Could you elaborate your reply? Thanks > > Libraries can be statically linked into the program when it is built > or dynamically linked when the program is executed. > > If you statically link in all the libraries, the program does not > require any shared libraries on the target computer. > > http://cs-fundamentals.com/tech-interview/c/difference-between-static-and-dynamic-linking.php > > Rob.Rob, Just to confirm - I need to recompile as below? gcc a.c b.c -o myprogramEXE -static libm
Reply by ●March 26, 20152015-03-26
