Hi all , I implement qpsk demodulator on National instruments Fpga . Now i want to Demodulate Oqpsk signal . As the difference between qpsk and oqpsk is only the delay of one bit period in q channel. Q1. Can a qpsk demodulator with some changes demodulate oqpsk data ? Q2. If it works , what changes i should make ? flow of qpsk demodulater what i made.. 1. frequency shifter (input from step 4) 2. Matched filter 3. AGC 4. coarse frequency offset estimator (Rife and broostyn algorithm). 5. Timing recovery (Gardener) 6. DDPLL 7. symbol demapping what are the stages to be modified? Q3. suggest me some papers ? Thanks in advance........... --------------------------------------- Posted through http://www.DSPRelated.com
OQPSK Demodulator
Started by ●May 16, 2015
Reply by ●May 16, 20152015-05-16
On Sat, 16 May 2015 06:04:07 -0500, "eshwar402" <105862@DSPRelated> wrote:>Hi all , > I implement qpsk demodulator on National instruments Fpga . Now i >want to Demodulate Oqpsk signal . As the difference between qpsk and >oqpsk is only the delay of one bit period in q channel. > >Q1. Can a qpsk demodulator with some changes demodulate oqpsk data ? > >Q2. If it works , what changes i should make ? > flow of qpsk demodulater what i made.. > 1. frequency shifter (input from step 4) > 2. Matched filter > 3. AGC > 4. coarse frequency offset estimator (Rife and broostyn >algorithm). > 5. Timing recovery (Gardener) > 6. DDPLL > 7. symbol demapping > > what are the stages to be modified? > >Q3. suggest me some papers ? > >Thanks in advance........... > > > >--------------------------------------- >Posted through http://www.DSPRelated.comI responded in your other thread. Much easier to keep things in one thread than to have people responding to both. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
