hi all , I simulated OQpsk modulated data which has 4 samples per symbol (base band). I also simulated the squaring and differentiating based Timing error detector .Now i want to know how well is it performing for that i want to simulate and draw the s -curve. can anyone suggest me a best method to plot s-curve! thanks in advance...
How to plot S-Curve for TED ?
Started by ●June 25, 2015
Reply by ●June 27, 20152015-06-27
On 25.06.2015 12:57, Eshwar varma wrote:> hi all , > I simulated OQpsk modulated data which has 4 samples per symbol (base band). I also simulated the squaring and differentiating based Timing error detector .Now i want to know how well is it performing for that i want to simulate and draw the s -curve. > > can anyone suggest me a best method to plot s-curve! > thanks in advance... > >Eshwar, it's one of the things you "just" do. The only thing you need is understanding what an S-curve is. I suggest you to use Matlab (or any analogue) for simulations / plotting, since it's really efficient for such tasks. Regards, Evgeny.
Reply by ●July 1, 20152015-07-01
>hi all , > I simulated OQpsk modulated data which has 4 samples per symbol >(base band). I also simulated the squaring and differentiating basedTiming>error detector .Now i want to know how well is it performing for that iwant>to simulate and draw the s -curve. > > can anyone suggest me a best method to plot s-curve! >thanks in advance...Lets say, you have 10 samples per symbol and lets say you have 10 symbols. This makes in total of 100 samples in a packet. Now lets say you receive these 100 samples noise free at receiver and assuming that you are using rectangular pulse both at Tx and Rx, what will be the output waveform when you convolve the received 100 samples with the rectangular pulse? To save you sometime, you will get a triangular waveform (you should simulate it), where the peaks will indicate ideal sampling instant. Now since you have received noise free samples and if you sample at correct instant, and get the error for the 10 symbols (not samples), the mean error should be zero. But if you either advance or delay the sampling instant then your mean error will not be zero. (Once again, you should simulate it) Then plot these mean error values you get and it should follow a pretty good S-curve. Hope this helps. Sia --------------------------------------- Posted through http://www.DSPRelated.com
