Hi Everyone, I am struggling to manually apply the scale values to a digital filter I designed in MATLAB using fdatool. I generated the filter (IIR band stop filter consisting of four second order sections) and exported it as an object. I can use MATLAB's "filter" function to filter my data correctly. As a precursor to implementing the filter in C and embedding it onto a hardware device, I wanted to manually write the code in MATLAB. I can successfully apply the coefficients and the waveform shape matches that obtained using MATLAB's "filter" function however the values have changed because I am not applying any scaling. I have a scale vector consisting of 5 values (this is as I expected as I have four second order sections in my filter). My question is how to correctly apply the scale values to my filter? My (obviously incorrect) belief was that you apply the first scale value to the input and the subsequent scale values to the outputs of each second order section. However when I do this, the shape of the data is changed and it is centred around 0, as though I applied a high pass filter. To get the correct waveform I need to ignore the scale values provided by MATLAB and apply only the coefficients and then "fudge" the output by applying a scale value at the end which I came up with by trial and error. Please see my code below which attempts to apply MATLAB's scale values as per my previous "understanding": % Bandstop Scale Values Scale = [0.98896 0.98896 0.97448 0.97448 1]; % Bandstop Filter Coefficients Section1 = [1 -1.9996 1 1 -1.9579 0.96158]; Section2 = [1 -1.9996 1 1 -1.9959 0.99592]; Section3 = [1 -1.9996 1 1 -1.9868 0.98685]; Section4 = [1 -1.9996 1 1 -1.9101 0.91275]; %% Apply the filter to the data called "serial" for i=10:size(serial,1) % Section 1 output_section_1(i)=Scale(1)*(Section1(1)*serial(i) + Section1(2)*serial(i-1) + Section1(3)*serial(i-2) - Section1(5)*output_section_1(i-1) - Section1(6)*output_section_1(i-2)); % Section 2 output_section_2(i)=Scale(2)*(Section2(1)*output_section_1(i) + Section2(2)*output_section_1(i-1) + Section2(3)*output_section_1(i-2) - Section2(5)*output_section_2(i-1) - Section2(6)*output_section_2(i-2)); % Section 3 output_section_3(i)=Scale(3)*(Section3(1)*output_section_2(i) + Section3(2)*output_section_2(i-1) + Section3(3)*output_section_2(i-2) - Section3(5)*output_section_3(i-1) - Section3(6)*output_section_3(i-2)); % Section 4 output_section_4(i)=Scale(4)*(Section4(1)*output_section_3(i) + Section4(2)*output_section_3(i-1) + Section4(3)*output_section_3(i-2) - Section4(5)*output_section_4(i-1) - Section4(6)*output_section_4(i-2)); end Any advice or input would be very much appreciated. Kind Regards, David Graham. --------------------------------------- Posted through http://www.DSPRelated.com
MATLAB - Digital Filtering in Second Order Sections - Scale Values
Started by ●July 24, 2015
Reply by ●July 25, 20152015-07-25
The scale factor should only be applied to the numerator operations, so change this % Section 1 output_section_1(i)=Scale(1)*(Section1(1)*serial(i) + Section1(2)*serial(i-1) + Section1(3)*serial(i-2) - Section1(5)*output_section_1(i-1) - Section1(6)*output_section_1(i-2)); To this % Section 1 output_section_1(i)=Scale(1)*(Section1(1)*serial(i) + Section1(2)*serial(i-1) + Section1(3)*serial(i-2)) - Section1(5)*output_section_1(i-1) - Section1(6)*output_section_1(i-2); Just moved one parentheses! Alternatively you can just pre-multiply all the numerator coefficients times the scale factor for each filter, especially in this case where the scale factors are close to 1.0 (in many cases the scale factors could be very small in which case you might want to apply them separately to avoid coefficient quantization issues). Bob
Reply by ●July 27, 20152015-07-27
>Just moved one parentheses! > >Alternatively you can just pre-multiply all the numerator coefficients >times the scale factor for each filter, especially in this case wherethe>scale factors are close to 1.0 (in many cases the scale factors could bevery>small in which case you might want to apply them separately to avoid >coefficient quantization issues). >Hi Bob, Thank you very much for your helpful response! I have taken your advice and now applying the scale values (as per your description) no longer changes the waveform shape which is a great step forward. However, I think I am still missing something because the scale still isn't right. As you can see from my scale values, they are all close to 1 and so multiplying by these doesn't have a massive effect on the output. With no scale applied, my average output is around 5,000 counts. With scale applied it is around 4,500 counts but my target is 1875 counts. I can fix this by multiplying my output by 0.415 (implemented by changing my last scale value) but this seems a "fudge" because MATLAB's filter function just uses the filter object (where the output scale value is 1) and gives me an average output of 1875 counts. Thanks again for your response, I feel a step closer to getting it right now. Kind Regards, David Graham. --------------------------------------- Posted through http://www.DSPRelated.com
Where did you get your "target" value from? If you are just looking at the peaks of a complicated waveform, the action of the filter will change the peak values so this is not a reliable way of determining whether or not you have the proper gain factors. In some cases if you specify large amounts of passband ripple, the gain factors may be set so that the peak value of the frequency response is 0 dB, which may change the "nominal" passband gain. You can also check the gain at dc directly from the coefficients. Just calculate the sum of numerator coefficients divided by the sum of denominator coefficients. Bob
>Where did you get your "target" value from? If you are just looking atthe>peaks of a complicated waveform, the action of the filter will changethe>peak values so this is not a reliable way of determining whether or notyou>have the proper gain factors. >In some cases if you specify large amounts of passband ripple, the gain >factors may be set so that the peak value of the frequency response is 0dB,>which may change the "nominal" passband gain. >You can also check the gain at dc directly from the coefficients. Just >calculate the sum of numerator coefficients divided by the sum of >denominator coefficients. > > >BobHi Bob, Thanks again for getting in contact. My "target" values come from using MATLAB's "filter" function using the same filter coefficients and gain values. So I designed the filter using fdatool and filtered it using MATLAB as below output=filter(Hd,input); I then implemented the filter manually, not using MATLAB's "filter" function and I am comparing the outputs. So I hardcoded the coefficients and the scale values and I am attempting to get my output to match that of MATLAB's "filter" function. I hope that makes sense. I know the filter will change the output, where I am struggling is in getting my values to match those of MATLAB's filter function. Currently the waveform shape matches so I know I am correctly applying the coefficients but the scale does not match. Kind Regards, David. --------------------------------------- Posted through http://www.DSPRelated.com
I suspect you didn't copy enough digits into your coefficient array. The filter function is getting full precision. Try setting "format long" and then copy your coefficients with full precision. Bob
Reply by ●July 28, 20152015-07-28
>I suspect you didn't copy enough digits into your coefficient array. The >filter function is getting full precision. Try setting "format long" and >then copy your coefficients with full precision. > >BobHi Bob, Thanks again, you are quite correct. Once I changed the format and included the full coefficients and scale values, the outputs matched. Sincere thanks for your help! David. --------------------------------------- Posted through http://www.DSPRelated.com
