I was studying the schematic of a 1970's era washing machine sized disk drive [1] wondering how it performed ECC. Everything was built out of simple SSI TTL circuitry. The disk controller had a 13-bit register that provided the "Error Position" and another 12-bit register that provided the "Error Pattern". I couldn't find any explanation for how this circuit worked in any of the disk drive documentation although the other circuitry had an excellent circuit description. I found a circuit that looked like a 32-bit CRC but it was wrapped other stuff like a zero detector and some counters and comparators. I wanted to understand how something so simple could perform error detection and correction. I finally extracted the polynomial from the schematic did a Google search on the polynomial. One reference mentioned that this polynomial was a "Fire Code" after P. Fire. This particular implementation could correct 11-bit burst errors so all of the register sizes made sense. I've never heard of Fire Codes. So - my question... Are there any modern uses of Fire Codes or has it gone the way of the Dodo bird? Thanks - Rob [1] DEC RP06 disk drive.
Fire Codes
Started by ●July 28, 2015
Reply by ●July 28, 20152015-07-28
Rob Doyle <radioengr@gmail.com> wrote:>I was studying the schematic of a 1970's era washing machine sized disk >drive [1] wondering how it performed ECC. Everything was built out of >simple SSI TTL circuitry.>The disk controller had a 13-bit register that provided the "Error >Position" and another 12-bit register that provided the "Error Pattern". >I couldn't find any explanation for how this circuit worked in any of >the disk drive documentation although the other circuitry had an >excellent circuit description. > >I found a circuit that looked like a 32-bit CRC but it was wrapped other >stuff like a zero detector and some counters and comparators. I wanted >to understand how something so simple could perform error detection and >correction. > >I finally extracted the polynomial from the schematic did a Google >search on the polynomial. One reference mentioned that this polynomial >was a "Fire Code" after P. Fire. This particular implementation could >correct 11-bit burst errors so all of the register sizes made sense. > >I've never heard of Fire Codes. > >So - my question... Are there any modern uses of Fire Codes or has it >gone the way of the Dodo bird?Yes, they are still used. The decoders are diabolically simple -- first, you use a FSR to create a residue, then you shift the register backwards until it contains a short enough string of one's such that you know you've found the error pattern. In your example, when after back-shifting the 32 bit register exhibits all zero's except in any 11 consecutive bits, you are done and that is your burst error pattern. Steve
On 07/28/2015 10:48 PM, Rob Doyle wrote:> I was studying the schematic of a 1970's era washing machine sized disk > drive [1] wondering how it performed ECC. Everything was built out of > simple SSI TTL circuitry. > > The disk controller had a 13-bit register that provided the "Error > Position" and another 12-bit register that provided the "Error Pattern". > I couldn't find any explanation for how this circuit worked in any of > the disk drive documentation although the other circuitry had an > excellent circuit description. > > I found a circuit that looked like a 32-bit CRC but it was wrapped other > stuff like a zero detector and some counters and comparators. I wanted > to understand how something so simple could perform error detection and > correction. > > I finally extracted the polynomial from the schematic did a Google > search on the polynomial. One reference mentioned that this polynomial > was a "Fire Code" after P. Fire. This particular implementation could > correct 11-bit burst errors so all of the register sizes made sense. > > I've never heard of Fire Codes. > > So - my question... Are there any modern uses of Fire Codes or has it > gone the way of the Dodo bird? > > Thanks - > Rob > > [1] DEC RP06 disk drive.I remember Fire codes being a big thing when they were introduced. There were articles about them all over the place. I think people were inspired by their simplicity. Steve
Rob Doyle <radioengr@gmail.com> wrote:> I was studying the schematic of a 1970's era washing machine sized disk > drive [1] wondering how it performed ECC. Everything was built out of > simple SSI TTL circuitry.> The disk controller had a 13-bit register that provided the "Error > Position" and another 12-bit register that provided the "Error Pattern". > I couldn't find any explanation for how this circuit worked in any of > the disk drive documentation although the other circuitry had an > excellent circuit description.(snip)> [1] DEC RP06 disk drive.The RP06 is the same as an IBM 3330-11, with different control logic. As far as I know, the data formatting such as ECC is the same. Not so long ago, the question came up about reading RP06 disks on 3330-11 drives with the 3830 controller/formatter. And yes, all that was available at the time was very simple logic. -- glen
On 7/28/15 10:48 AM, Rob Doyle wrote:> > I've never heard of Fire Codes. >i thought those were the codes that require smoke detectors in some American cities to be both AC and DC powered. :-) -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Steve Underwood <steveu@dis.org> wrote:>I remember Fire codes being a big thing when they were introduced. There >were articles about them all over the place. I think people were >inspired by their simplicity.The most recent use I can recall is in GSM. There is a fire code in every GSM phone; the convolutional code and Fire code are concatenated, with the Fire code being the outer code. The idea, I believe, is that any errors at the output of the convolutional decoder will manifest as a short burst. Steve
On Tue, 28 Jul 2015 18:17:49 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Steve Underwood <steveu@dis.org> wrote: > >>I remember Fire codes being a big thing when they were introduced. There >>were articles about them all over the place. I think people were >>inspired by their simplicity. > >The most recent use I can recall is in GSM. There is a fire code >in every GSM phone; the convolutional code and Fire code are >concatenated, with the Fire code being the outer code. > >The idea, I believe, is that any errors at the output of the convolutional >decoder will manifest as a short burst.That's often true, although a lot of people have a hard time believing this for some reason. It's also the reason that convolutional codes are often concatenated with RS codes. When a Viterbi (or even sequential) decoder makes an output error, if the error is large enough (i.e., the soft metrics are really bad), it can lose track of a whole chunk of the trellis, which means it's going to barf out garbage until it finds its way back to the correct path on the trellis. So usually you see two types of errors coming out of a decoder for a convolutional code, the dribbly single-bit errors or chunks of errors at a time. If I understand things correctly Fire Codes trade flexibility for simplicity in that they have a fairly restricted set of block errors that they can fix, but they can do that with a simple solution. I would guess that a properly designed interleaver, that interleaves chunks of the size matched to the Fire Code, would give it a fair chance of cleaning up the block errors that come ouf of a decoder for a convolutional code (which is usually a Viterbi decoder). Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:>On Tue, 28 Jul 2015 18:17:49 +0000 (UTC), spope33@speedymail.org>>The most recent use I can recall is in GSM. There is a fire code >>in every GSM phone; the convolutional code and Fire code are >>concatenated, with the Fire code being the outer code.>>The idea, I believe, is that any errors at the output of the convolutional >>decoder will manifest as a short burst.>That's often true, although a lot of people have a hard time believing >this for some reason. It's also the reason that convolutional codes >are often concatenated with RS codes.>When a Viterbi (or even sequential) decoder makes an output error, if >the error is large enough (i.e., the soft metrics are really bad), it >can lose track of a whole chunk of the trellis, which means it's going >to barf out garbage until it finds its way back to the correct path on >the trellis. So usually you see two types of errors coming out of a >decoder for a convolutional code, the dribbly single-bit errors or >chunks of errors at a time.>If I understand things correctly Fire Codes trade flexibility for >simplicity in that they have a fairly restricted set of block errors >that they can fix, but they can do that with a simple solution. I >would guess that a properly designed interleaver, that interleaves >chunks of the size matched to the Fire Code, would give it a fair >chance of cleaning up the block errors that come ouf of a decoder for >a convolutional code (which is usually a Viterbi decoder).And in GSM (GMSK modes) the burst errors have another possible source, which is the trellis equalizer. I think a more modern design would have something more like a RS code, but the Fire Code codewords needed to be exceptionally short -- I think about 500 bits, which is getting pretty small for an RS code. Steve
On Tue, 28 Jul 2015 20:25:35 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >>On Tue, 28 Jul 2015 18:17:49 +0000 (UTC), spope33@speedymail.org > >>>The most recent use I can recall is in GSM. There is a fire code >>>in every GSM phone; the convolutional code and Fire code are >>>concatenated, with the Fire code being the outer code. > >>>The idea, I believe, is that any errors at the output of the convolutional >>>decoder will manifest as a short burst. > >>That's often true, although a lot of people have a hard time believing >>this for some reason. It's also the reason that convolutional codes >>are often concatenated with RS codes. > >>When a Viterbi (or even sequential) decoder makes an output error, if >>the error is large enough (i.e., the soft metrics are really bad), it >>can lose track of a whole chunk of the trellis, which means it's going >>to barf out garbage until it finds its way back to the correct path on >>the trellis. So usually you see two types of errors coming out of a >>decoder for a convolutional code, the dribbly single-bit errors or >>chunks of errors at a time. > >>If I understand things correctly Fire Codes trade flexibility for >>simplicity in that they have a fairly restricted set of block errors >>that they can fix, but they can do that with a simple solution. I >>would guess that a properly designed interleaver, that interleaves >>chunks of the size matched to the Fire Code, would give it a fair >>chance of cleaning up the block errors that come ouf of a decoder for >>a convolutional code (which is usually a Viterbi decoder). > >And in GSM (GMSK modes) the burst errors have another possible source, >which is the trellis equalizer.Yup.>I think a more modern design would have something more like a >RS code, but the Fire Code codewords needed to be exceptionally >short -- I think about 500 bits, which is getting pretty small >for an RS code. > >SteveYeah, short packets are always a tricky thing to try to protect with sufficient FEC/ECC. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:>On Tue, 28 Jul 2015 20:25:35 +0000 (UTC), spope33@speedymail.org>>I think a more modern design would have something more like a >>RS code, but the Fire Code codewords needed to be exceptionally >>short -- I think about 500 bits, which is getting pretty small >>for an RS code.>Yeah, short packets are always a tricky thing to try to protect with >sufficient FEC/ECC.I looked it up and it is even shorter -- 184 bits before adding Fire code parity (40 bits) and four BCC tail bits for a total of 228 bits, becoming 456 bits after the BCC. The Fire code can correct any 11-bit burst. Should they have used an RS code instead? I think the answer is yes -- Depth 2 interleaving of two RS codewords, (22,18) and (23,19) with five-bit symbols (note there is one pad bit, but it need not be transmitter) this would correct any single burst up to 16 bits, and many other error patterns as well that the Fire code is unable to handle. There could have been other details of the system that made an RS code unworkable; no real way of telling. Steve
