Hi all, I need some hint or pointer in order to try to solve a problem. This might not be the right place, but since here wise people are, maybe I got lucky (I tried sci.math too). If you know an other possible NG, please let me know. I've a set of vectors, same size, these are "samples" of different populations, of course I've by far more vectors than populations. These (column) vectors can be combined into a matrix (or not, it depends on the possible solutions), let's call this matrix R. Or, better, several matrices R0, R1, R2, ... Rn-1, each grouping a population. I need to find a matrix, let's call it D, under the following conditions: The sum of the rows must be zero (or very close to it). A statistical distance, like Mahalanobis or Bhattacharyya, must be minimized between some groups, while it must be maximized between other groups. So, for example dist(D*R1,D*R2) must be minimal (close to zero, actually), while dist(D*R1,D*R3) must be maximal (and as well dist(D*R2,D*R3), of course). One approach to the problem could be a genetic algorithm, I was wondering if there is any other method or algorithm that can be used to *try* to find a solution D. Thanks a lot in advance, bye, -- piergiorgio
Minimization / maximization problem
Started by ●August 27, 2015
Reply by ●August 27, 20152015-08-27
package dragonfruit; public class MExp { final int n; final int baseExp; float grandparentCost; float[] grandparent; float[] parent; float[] child; final FNF fn; final Xor1024 rnd; public MExp(int n, int precision, FNF fn) { this.n = n; this.fn = fn; baseExp = 127 - precision; grandparent = new float[n]; parent = new float[n]; child = new float[n]; rnd = new Xor1024(); for (int i = 0; i < n; i++) { grandparent[i] = rnd.nextFloatSym(); } grandparentCost = Float.POSITIVE_INFINITY; } void mutate(float[] current, float[] next) { System.arraycopy(current, 0, next, 0, n); for (int i = 0; i < n; i++) { int e = rnd.rndInclusive(baseExp, 127); if (e < 0) { continue; } int m = rnd.nextInt() & 0x807fffff; float cv = next[i] + Float.intBitsToFloat(e << 23 | m); if ((cv >= 1f) || (cv <= -1f)) { continue; } next[i] = cv; } } public void optimize(int parentIter, int childIter) { for (int i = 0; i < parentIter; i++) { mutate(grandparent, parent); float parentCost = fn.eval(parent); for (int j = 0; j < childIter; j++) { mutate(parent, child); float childCost = fn.eval(child); if (childCost < parentCost) { parentCost = childCost; float[] t = parent; parent = child; child = t; } } if (parentCost < grandparentCost) { grandparentCost = parentCost; float[] t = grandparent; grandparent = parent; parent = t; } } } public float getCost() { return grandparentCost; } public float[] getResult() { return grandparent; } public static void main(String[] args) { MExp mexp = new MExp(100, 1000, x -> { float sum = 0f; for (int i = 1; i < x.length; i++) { float x0 = x[i - 1] * 30f; float x1 = x[i] * 30f; sum += 100 * (x1 - x0 * x0) * (x1 - x0 * x0) + (x0 - 1f) * (x0 - 1f); } return sum; }); mexp.optimize(200, 100000); System.out.println("Cost:" + mexp.getCost()); System.out.println("At:"); for (int i = 0; i < mexp.getResult().length; i++) { System.out.println(mexp.getResult()[i] * 30f); } } } package dragonfruit; import java.util.concurrent.atomic.AtomicInteger; public final class Xor1024 { final static AtomicInteger ct = new AtomicInteger(); final long[] seed = new long[16]; int pos; public Xor1024() { setSeed(System.nanoTime() + ct.getAndAdd(1)); } public Xor1024(long seed) { setSeed(seed); } public long nextLong() { long s0 = seed[pos++]; pos &= 15; long s1 = seed[pos]; s1 ^= s1 << 31; s1 ^= s1 >>> 11; s0 ^= s0 >>> 30; return (seed[pos] = s0 ^ s1) * 1181783497276652981L; } public int nextInt() { return (int) nextLong(); } public int rndInclusive(int max) { long r = nextLong() & 0xffffffffL; r *= (long) max + 1; r = r >>> 32; return (int) r; } public int rndInclusive(int min, int max) { long r = nextLong() & 0xffffffffL; r *= (long) (max - min) + 1; return (int) (r >>> 32) + min; } public int rndExcludeMax(int max) { long r = nextLong() & 0xffffffffL; r *= (long) max; r = r >>> 32; return (int) r; } public int rndExcludeMax(int min, int max) { long r = nextLong() & 0xffffffffL; r *= (long) (max - min); return (int) (r >>> 32) + min; } public float nextFloatSym() { long x = nextLong(); int y = Long.numberOfLeadingZeros(x); if (y > 32) { return 0f; } int e = 126 - y; return Float.intBitsToFloat(e << 23 | ((int) x & 0x807fffff)); } public float nextFloat() { long x = nextLong(); int y = Long.numberOfLeadingZeros(x); if (y > 41) { return 0f; } int e = 126 - y; return Float.intBitsToFloat(e << 23 | ((int) x & 0x007fffff)); } public void setSeed(long s) { pos = 0; for (int i = 15; i >= 0; i--) { s = s * 2862933555777941757L + 0x5dcea454e5a46c65L; seed[i] = s; } } public void getNextState(long[] state) { while (pos != 0) { nextLong(); } System.arraycopy(seed, 0, state, 0, 16); } public void setState(long[] state) { pos = 0; System.arraycopy(state, 0, seed, 0, 16); } public void copyOf(Xor1024 x) { System.arraycopy(seed, 0, x.seed, 0, 16); x.pos = pos; } } package dragonfruit; public interface FNF { public float eval(float[] x); }
On Thursday, August 27, 2015 at 4:28:17 PM UTC-5, Piergiorgio Sartor wrote:> Hi all, > > I need some hint or pointer in order to try to solve > a problem. > This might not be the right place, but since here wise > people are, maybe I got lucky (I tried sci.math too). > If you know an other possible NG, please let me know. > > I've a set of vectors, same size, these are "samples" > of different populations, of course I've by far more > vectors than populations. > These (column) vectors can be combined into a matrix > (or not, it depends on the possible solutions), let's > call this matrix R. > Or, better, several matrices R0, R1, R2, ... Rn-1, > each grouping a population. > > I need to find a matrix, let's call it D, under the > following conditions: > > The sum of the rows must be zero (or very close to it). > > A statistical distance, like Mahalanobis or Bhattacharyya, > must be minimized between some groups, while it must be > maximized between other groups. > So, for example dist(D*R1,D*R2) must be minimal (close > to zero, actually), while dist(D*R1,D*R3) must be maximal > (and as well dist(D*R2,D*R3), of course). > > One approach to the problem could be a genetic algorithm, > I was wondering if there is any other method or algorithm > that can be used to *try* to find a solution D. > > Thanks a lot in advance, > > bye, > -- > > piergiorgioTry the following http://pritchardlab.stanford.edu/structure.html
