>Design a single band-pass filter. Or rather, let a program design itfor you. lol, well said.
FIR Filter Help
Started by ●February 13, 2005
Reply by ●February 15, 20052005-02-15
Reply by ●February 16, 20052005-02-16
Jerry Avins wrote:> > I like the Lyons book. You'll find it and others cited on > http://www.dspguru.com/.THat site is chock-full-o good DSP stuff. In particular, it has a nice FAQ on FIRs, including working code. http://www.dspguru.com/info/faqs/firfaq.htm -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Quidquid latine dictum sit, altum sonatur. Whatever is said in Latin sounds profound.
samseed wrote:> Coefficients: > > a[0] = -0.047739632 > a[1] = -0.017229123 > a[2] = 1.0119492E-8 > a[3] = -0.064445764 > a[4] = -0.087204635 > a[5] = -0.011658093 > a[6] = -0.021648642 > a[7] = -0.15716003 > a[8] = -0.11321392 > a[9] = 0.221274 > a[10] = 0.43638006 > a[11] = 0.221274 > a[12] = -0.11321392 > a[13] = -0.15716003 > a[14] = -0.021648642 > a[15] = -0.011658093 > a[16] = -0.087204635 > a[17] = -0.064445764 > a[18] = 1.0119492E-8 > a[19] = -0.017229123 > a[20] = -0.047739632 > > > So, I have my time-domain samples patiently sitting in an array and I'm > currently fumbling with the proper formulas! :O >You have 21 coefficients, but the code snippet you posted uses only three of them. You need to use them all. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Quidquid latine dictum sit, altum sonatur. Whatever is said in Latin sounds profound.
Is the following process correct? //20 tap low-pass filter, Rectangular, coefficiants--->2000Hz, -10dB double a0 =-0.028991204; double a1 =0.008665845; double a2 =0.033431053; double a3 =-0.022146255; double a4 =-0.037133045; double a5 =0.043838896; double a6 =0.039916355; double a7 =-0.08839386; double a8 =-0.041643664; double a9 =0.28917018; double a10 =0.50124127; double a11 =0.28917018; double a12 =-0.041643664; double a13 =-0.08839386; double a14 =0.039916355; double a15 =0.043838896; double a16 =-0.037133045; double a17 =-0.022146255; double a18 =0.033431053; double a19 =0.008665845; double a20 =-0.028991204; for (int t=20; t < audioShortData.length; t++) { audioShortData[t] = (short)(( a0*audioShortData[t]+ a1*audioShortData[t-1]+ a2*audioShortData[t-2]+ a3*audioShortData[t-3]+ a4*audioShortData[t-4]+ a5*audioShortData[t-5]+ a6*audioShortData[t-6]+ a7*audioShortData[t-7]+ a8*audioShortData[t-8]+ a9*audioShortData[t-9]+ a10*audioShortData[t-10]+ a11*audioShortData[t-11]+ a12*audioShortData[t-12]+ a13*audioShortData[t-13]+ a14*audioShortData[t-14]+ a15*audioShortData[t-15]+ a16*audioShortData[t-16]+ a17*audioShortData[t-17]+ a18*audioShortData[t-18]+ a19*audioShortData[t-19]+ a20*audioShortData[t-20] }
Looks good to me! I still would use a loop for the convolution step so it is easier to change number of taps, but that's just a programming preference. Based on your filter coefs and stated spec (2000Hz, -10dB), I'm guessing your audio sample rate is something around 8kHz? "samseed" <agent3492003@yahoo.com> wrote in message news:1108564946.710984.197470@l41g2000cwc.googlegroups.com...> Is the following process correct? > > //20 tap low-pass filter, Rectangular, coefficiants--->2000Hz, -10dB > double a0 =-0.028991204; > double a1 =0.008665845; > double a2 =0.033431053; > double a3 =-0.022146255; > double a4 =-0.037133045; > double a5 =0.043838896; > double a6 =0.039916355; > double a7 =-0.08839386; > double a8 =-0.041643664; > double a9 =0.28917018; > double a10 =0.50124127; > double a11 =0.28917018; > double a12 =-0.041643664; > double a13 =-0.08839386; > double a14 =0.039916355; > double a15 =0.043838896; > double a16 =-0.037133045; > double a17 =-0.022146255; > double a18 =0.033431053; > double a19 =0.008665845; > double a20 =-0.028991204; > > for (int t=20; t < audioShortData.length; t++) { > audioShortData[t] = (short)(( > a0*audioShortData[t]+ > a1*audioShortData[t-1]+ > a2*audioShortData[t-2]+ > a3*audioShortData[t-3]+ > a4*audioShortData[t-4]+ > a5*audioShortData[t-5]+ > a6*audioShortData[t-6]+ > a7*audioShortData[t-7]+ > a8*audioShortData[t-8]+ > a9*audioShortData[t-9]+ > a10*audioShortData[t-10]+ > a11*audioShortData[t-11]+ > a12*audioShortData[t-12]+ > a13*audioShortData[t-13]+ > a14*audioShortData[t-14]+ > a15*audioShortData[t-15]+ > a16*audioShortData[t-16]+ > a17*audioShortData[t-17]+ > a18*audioShortData[t-18]+ > a19*audioShortData[t-19]+ > a20*audioShortData[t-20] > } >
"samseed" <agent3492003@yahoo.com> wrote in message news:1108581210.574553.72530@z14g2000cwz.googlegroups.com...> yes.Just a tip, include some of the message you are replying too so we can see the context--what are you saying "yes" to?> what is the correct formula for a high-pass?Again, use your filter design program---there is no easy formula! I think there are some ways to transform a LP into a HP, but I would still use the program.
my bad.>I'm guessing your audio sample rate is something around 8kHzcorrect. However, 44kHz is the only rate that has valid filter output, but that may just be a bug in my app.>Again, use your filter design program---there is no easy formula! Ithink there are some ways to transform a LP into a HP, but I would still use the program. yes, I'm using the design program. What I meant to ask was, is the high-pass a multiply/add like a low-pass, or do you multiply/ subtract like so: audioShortData[t] = (short)(( a0*audioShortData[t] - a1*audioShortData[t-1] - a2*audioShortData[t-2] - ...)
samseed wrote:> my bad. > > >>I'm guessing your audio sample rate is something around 8kHz > > > correct. However, 44kHz is the only rate that has valid filter output, > but that may just be a bug in my app. > > >>Again, use your filter design program---there is no easy formula! I > > think there > are some ways to transform a LP into a HP, but I would still use the > program. > > yes, I'm using the design program. What I meant to ask was, is the > high-pass a multiply/add like a low-pass, or do you multiply/ subtract > like so: > > audioShortData[t] = (short)(( a0*audioShortData[t] - > a1*audioShortData[t-1] - a2*audioShortData[t-2] - ...)Multiply and add is the usual. but id you always subtract, that just inverts the output signal. The operation is called MAC, for "Multiply And Accumulate". Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"samseed" <agent3492003@yahoo.com> wrote in message news:1108595391.559407.170670@z14g2000cwz.googlegroups.com...> my bad. > > >I'm guessing your audio sample rate is something around 8kHz > > correct. However, 44kHz is the only rate that has valid filter output, > but that may just be a bug in my app.Probably.> >Again, use your filter design program---there is no easy formula! I > think there > are some ways to transform a LP into a HP, but I would still use the > program. > > yes, I'm using the design program. What I meant to ask was, is the > high-pass a multiply/add like a low-pass, or do you multiply/ subtract > like so: > > audioShortData[t] = (short)(( a0*audioShortData[t] - > a1*audioShortData[t-1] - a2*audioShortData[t-2] - ...)OK, I understand you. The convolution formula is always the same regardless of what filter type you are using--low-pass, high-pass, band-pass, something totally arbitrary, etc.. So your filtering function can always be the same, but depending on what filter coefficients you use, it may create a LP, HP, etc..
