Hi, I have to detect pulses depicted in the following picture: http://postimg.org/image/ud1usxcwr/ They are pulses superimposed on a slow varying signal. Any ideas? Thanks, Enrico Migliore --------------------------------------- Posted through http://www.DSPRelated.com
How to detect pulses superimposed on a slow varying signals
Started by ●September 28, 2015
Reply by ●September 29, 20152015-09-29
On Mon, 28 Sep 2015 12:42:36 -0500, wwwenrico wrote:> Hi, > > > I have to detect pulses depicted in the following picture: > > http://postimg.org/image/ud1usxcwr/ > > > They are pulses superimposed on a slow varying signal. > > Any ideas?The easy way is to just run the whole shebang through a really low-pass filter, and set a threshold a bit above the baseline. As long as you have a pretty good idea of how big the pulses are, as long as the baseline varies slowly, and as long as the pulse density is pretty constant, this works well. Harder situations demand more elaborate solutions, but you need to make solutions on a case-by-case basis. -- www.wescottdesign.com
