Hi guys, i need help from you. I've an ADC with 16 outputs lines, so i have 16 samples in parallel each time. Example: S16 S0 S17 S1 S18 S2 ... ... S31 S15 Each line has 300 MHz of sampling rate, therefore its bandwidth is 150 MHz. Now i would obtain 32 channels from these 16 but at same frequency..so i would have 32 channels with 75 MHz of bandwidth. Is possible for you? Have i aliasing? For example, for one line output of ADC i have in mind this: Line0 ----->D2----->U2-------->E0(z) | z^-1 |---->D2---->U2------->E1(z) D2=downsampler of 2, U2=upsampler of 2 Thanks very much! :(( --------------------------------------- Posted through http://www.DSPRelated.com
Oversampled dft filter banks
Started by ●February 4, 2016
