would like to share one thing i learned in a hardway about CIC interpolator. many of us do matlab model before trying any fixed-point coding. incidentally, i had no fixed-point tool set with my matlab. this forced me to write a plain (floating point) code for my CIC integrator an comb. implementing this was straight forward. i also implemented fixed-point code in C. interesting observation was noted when i tried to compare the output of c code with that of matlab code. for some duration the output was +/-1 error, as expected. however, as the time duration of the input waveform is increased, i noticed the error between ref out and that of c was increasing ! in fact, the increasing profile had a clear step pattern. for every 'K' samples, the error amplitude increases and continued as and when i feed more samples. invested time to check to find that the error was with matlab reference not with my fixed-point code. the error became +/-1 when i changed my matlab code with integer add/sub with wrapping! You have to use fixed-point add/sub with wrapping as 2's complement to implement CIC. time to realize that message in matlab doc about CIC that 'this module requires fixed-point tool set' was not a marketing technique from mathworks. CIC will not work in floating point! hope this will be helpful to someone. --------------------------------------- Posted through http://www.DSPRelated.com
cic interpolator filter in floating point vs fixed-point
Started by ●February 4, 2016
Reply by ●February 4, 20162016-02-04
xchalil <111653@DSPRelated> wrote:>would like to share one thing i learned in a hardway about CIC >interpolator. many of us do matlab model before trying any fixed-point >coding. incidentally, i had no fixed-point tool set with my matlab. this >forced me to write a plain (floating point) code for my CIC integrator an >comb. implementing this was straight forward. i also implemented >fixed-point code in C.>interesting observation was noted when i tried to compare the output of c >code with that of matlab code. for some duration the output was +/-1 >error, as expected. however, as the time duration of the input waveform >is increased, i noticed the error between ref out and that of c was >increasing ! in fact, the increasing profile had a clear step pattern. for >every 'K' samples, the error amplitude increases and continued as and when >i feed more samples.>invested time to check to find that the error was with matlab reference >not with my fixed-point code. the error became +/-1 when i changed my >matlab code with integer add/sub with wrapping!An excellent experience -- CIC filters require exact integer arithmetic with truncation and overflow. This is one case where a floating point implementation might be not only inexact, but possibly completely wrong. Steve
Reply by ●February 6, 20162016-02-06
On Thursday, February 4, 2016 at 2:02:55 PM UTC-5, Steve Pope wrote:> xchalil <111653@DSPRelated> wrote: > > >would like to share one thing i learned in a hardway about CIC > >interpolator. many of us do matlab model before trying any fixed-point > >coding. incidentally, i had no fixed-point tool set with my matlab. this > >forced me to write a plain (floating point) code for my CIC integrator an > >comb. implementing this was straight forward. i also implemented > >fixed-point code in C. > > >interesting observation was noted when i tried to compare the output of c > >code with that of matlab code. for some duration the output was +/-1 > >error, as expected. however, as the time duration of the input waveform > >is increased, i noticed the error between ref out and that of c was > >increasing ! in fact, the increasing profile had a clear step pattern. for > >every 'K' samples, the error amplitude increases and continued as and when > >i feed more samples. > > >invested time to check to find that the error was with matlab reference > >not with my fixed-point code. the error became +/-1 when i changed my > >matlab code with integer add/sub with wrapping! > > An excellent experience -- CIC filters require exact integer > arithmetic with truncation and overflow. This is one case where > a floating point implementation might be not only inexact, > but possibly completely wrong.well, i have seen a moving-sum or moving-average filter implemented with the integrator and delay line done in floating-point. maybe it was double-precision. i sorta objected to it on principle, but the accumulated error didn't seem to explode in the time we were running it (for hours). in principle either you must make sure that whatever you add is exactly what you subtract from the integrator, **or** you need to put the pole of the integrator slightly inside the unit circle. r b-j
