design a digital butterworth filter using matlab??
Started by Unknown October 29, 2005
Dear members:
In the demo in my class, my prof uses matlab to design a digital
butterworth filter. He first designs an analog filter using funtion
butter(, , 's') and then uses bilinear transformation to convert the
analog filter to a digital filter.
Since I know MATLAB function butter()allows us to directly design a
digital butterworth filter, I am wondering what are the advantages of
my prof's method over the direct design method?
I am wondering if prof uses this method just  to show how to design an
digital filter from an analog filter, and in practical cases, we can
use the MALAB butter to directly design digital filters, don't need to
use he bilinear transformation method. The result is the same.
Plz confirm my thinking.
Thanks
<VijaKhara@gmail.com> wrote in message
news:1130603855.459519.156340@g44g2000cwa.googlegroups.com...
> Dear members: > In the demo in my class, my prof uses matlab to design a > digital > butterworth filter. He first designs an analog filter > using funtion > butter(, , 's') and then uses bilinear transformation to > convert the > analog filter to a digital filter. > > Since I know MATLAB function butter()allows us to directly > design a > digital butterworth filter, I am wondering what are the > advantages of > my prof's method over the direct design method?
You might not always have MATLAB available, but presumably you'll always be able to look up the technique your professor is trying to teach you. Having just done exactly what you describe without benefit of MATLAB, I can appreciate your professor's diligence. So pay attention, already.
VijaKhara@gmail.com wrote:
> Dear members: > In the demo in my class, my prof uses matlab to design a digital > butterworth filter. He first designs an analog filter using funtion > butter(, , 's') and then uses bilinear transformation to convert the > analog filter to a digital filter.
I don't have access to matlab's signal processing toolbox, but I assume he first designs the butterworth prototype in s domain and then calls a function "bilinear" to tranform it to discrete time domain?
> Since I know MATLAB function butter()allows us to directly design a > digital butterworth filter, I am wondering what are the advantages of > my prof's method over the direct design method?
There are several advantages. In an educational setting, the students have a chance of seeing what is really going on. All too often somebody calls a function or uses aprogram without knowing what it does or why. Second, splitting things like that leaves you as a designer with far better control of the details. I just implemented a filter design program in C++ (got it compiled as mex files under matlab today, actually) for butterworth and Cheb 1 filters, and it let me do things somewhat differently than matlab.
> I am wondering if prof uses this method just to show how to design an > digital filter from an analog filter, and in practical cases, we can > use the MALAB butter to directly design digital filters, don't need to > use he bilinear transformation method. The result is the same.
Well... I'll split some hairs here and say that the BLT is just one of several possible ways to design discrete-time filters from analog prototypes. It is useful, though, and it is well worth the effort to understand. If you want a programming challenge, implement the thing in C++ where you try to re-use as much code as possible. Rune
Thank you very much, the group is very useful to me :)
