Hey Is it true that a Hamming window should be computed in the time domain and not in the frequency domain like I have done?? Thanks Raj
Hamming window
Started by ●February 19, 2006
Reply by ●March 27, 20062006-03-27
Hey I just wanted to make sure that my coding looks right. I have made some modifications. Please let me know if anything doesnt look correct. Thanks. Raj. figure(1) t = (0:2/(88200-1):2); plot(t,y) title('Brain Signal (2 sec)') xlabel('Time(t)') ylabel('Voltage(v)') figure(2) Y = fft(y); plot(Y) title('FFT Brain Signal') xlabel('logf') ylabel('log|Y|') %Hamming window% X = Y.*hamming(length(Y)); figure(3) plot(X) title('Hamming window applied') xlabel('logf') ylabel('log|Y|') Z = X.*conj(X); figure(4) plot(Z) title('Hamming window + Conjugate applied') xlabel('logf') ylabel('log|Y|') figure(5) loglog(Z) title('loglog plot') figure(6) semilogx(Z) title('semilogx plot') figure(7) semilogy(Z) title('semilogy plot') A = fftshift(Z); figure(8) semilogy(A) title('Simplified signal in frequency domain') figure(9) f = (-fs/2:1/2:fs/2-1/2)/1000; semilogy(f,A) title('Simplified signal in frequency domain') xlabel('Frequency (KHz)') figure(10) f2 = (0+1/2:1/2:fs/2)/1000; A_p = A(end/2+1:end); semilogy(f2,A_p) title('Positive side of A') xlabel('Frequency (KHz)') figure(11) f3 = (-fs/2:1/2:0-1/2)/1000; A_n = A(1:end/2); semilogy(f3,A_n) title('Negative side of A') xlabel('Frequency (KHz)') figure(12) V = zeros(1,88200); f = (-44100/2:1/2:44100/2-1/2)/1000; S = 500/0.5; P = 44100-S:44100+S; V(1,P) = 1; plot(f,V) title('Filter') xlabel('Frequency (KHz)') F_filt=A(P); f_filt=f(P); figure(13) semilogy(f_filt,F_filt) title('Filtered data') xlabel('Frequency (KHz)') figure(14) I = ifft(fftshift(F_filt)); plot(t(P),abs(I)) title('Filtered signal in time domain') xlabel('Time(t)')
rajgerman wrote:> Hey > > Is it true that a Hamming window should be computed in the time domain and > not in the frequency domain like I have done??That's the way it's usually done. Applying it in the time domain uses multiplication, but in the frequency domain you must convolve. (If you multiply the time domain sequence by the frequency results, you get a hump in the middle without the expected benefits anywhere. Are you familiar with the silly joke about the man with "a knocking in the head and a ringing in the ears"? (On request.) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Hey Ok instead of X = Y.*hamming(length(Y)); it should be: W = hamming(length(Y)); X = conv(Y,W); Or do I have to fft W as well and then convolve Y and W?? Thanks Raj
rajgerman wrote:> Hey > > Ok instead of X = Y.*hamming(length(Y)); it should be: > > W = hamming(length(Y)); > > X = conv(Y,W); > > Or do I have to fft W as well and then convolve Y and W?? > > Thanks RajWe're at cross purposes. Assuming that X and Y are arrays of samples in time, then X = Y.*hamming(length(Y)) is exactly what you want to do. Then FFT X. Your use of capital X and Y lead me to wonder is they really are time samples. If not, they should be. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>rajgerman wrote: >> Hey >> >> Ok instead of X = Y.*hamming(length(Y)); it should be: >> >> W = hamming(length(Y)); >> >> X = conv(Y,W); >> >> Or do I have to fft W as well and then convolve Y and W?? >> >> Thanks RajNo Y is in the frequency domain. I'm a bit confused.
Hey Y = frequency domain (data) W = which is the hamming window is in the time domain Am I right with W?? How will this change my code? Thanks Raj
rajgerman wrote:>>rajgerman wrote: >> >>>Hey >>> >>>Ok instead of X = Y.*hamming(length(Y)); it should be: >>> >>>W = hamming(length(Y)); >>> >>>X = conv(Y,W); >>> >>>Or do I have to fft W as well and then convolve Y and W?? >>> >>>Thanks Raj > > > No Y is in the frequency domain. I'm a bit confused.You start with a sequence of samples, equally spaced in time. To see the spectrum of the signal that the samples represent, you perform an FFT on those samples. Often the FFT will give a clearer picture of the spectrum if you modify the samples with a tapered window /before/ performing the FFT. Now: you can either multiply the window vector by the sample vector and FFT the product as I described -- that's the efficient way -- or FFT the sample array, and convolve the result with the FFTed window, taking care that the convolution isn't circular. The second way works in theory, but there's no reason to use it. Matlab is too automatic to be a good learning tool. It lets one easily do complicated operations without having to understand what they are or what they do. It lets one operate on vast amounts of data with no understanding of what the data mean, either before or after the operations. You will get more out of it after you have done a simple problem by hand. That will make the nature and sequence of the operations clear. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Hey Thanks that explained alot. Could you recommend me a good book that deals with matlab and dsp together or any good dsp book that will help me?? Thanks Raj
rajgerman wrote:> Hey > > Thanks that explained alot. Could you recommend me a good book that deals > with matlab and dsp together or any good dsp book that will help me??I know very little about Matlab, but I do know that it has a good help system. Matlab is a tool for exploring your designs and for solving specific problems (like quickly computing window and filter coefficients, and transforms). It's like a very sophisticated bulldozer-backhoe combination. It's a lot faster than digging by hand, but in needs a plan to be useful. At your level, I can't think of any better book than Lyons: "Understanding Digital Signal Processing". There's an on-line book that's also good: "The Scientist and Engineer's Guide to Digital Signal Processing" by Steven W. Smith; http://dspguide.com/. There is a book that deals with doing DSP using Matlab. I don't know it. Conscious ignorance rarely gets me into deep trouble. Being wrong about what I think I know really hurts. I just bought a lens for $60 that I only thought I could use. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
