On Sat, 09 Jun 2007 20:59:19 -0400, Randy Yates wrote:> p.kootsookos@remove.ieee.org (Peter K.) writes: > >> Tim Wescott <tim@seemywebsite.com> writes: >> >>> Why do you say that the ideal low-pass filters are not BIBO stable? >>> The impulse response you give has a finite amount of energy in it, and >>> it goes to zero over time -- that says "BIBO stable" to me. >> >> For BIBO stability, the impulse response has to be absolutely summable >> (http://en.wikipedia.org/wiki/BIBO_stability). >> >> The sinc function is not absolutely summable (or integrable in >> continuous time http://en.wikipedia.org/wiki/Sinc_function), so the >> ideal low pass filter is not BIBO stable. :-) > > Ayup. Here's a copy of the post (from Google Groups) on a proof I made a few years back: >-- snip -- Well, I'll be dipped. For what evil (yet bounded) signals does a filter with this impulse response respond with infinite strength? My intuition tells me that it would be sin(wt). But then, my intuition told me earlier today that the system was stable, so I'm not sure it's trustworthy. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
BIBO stability
Started by ●May 7, 2007
Reply by ●June 10, 20072007-06-10
Tim Wescott <tim@seemywebsite.com> writes:> On Sat, 09 Jun 2007 20:59:19 -0400, Randy Yates wrote: > >> p.kootsookos@remove.ieee.org (Peter K.) writes: >> >>> Tim Wescott <tim@seemywebsite.com> writes: >>> >>>> Why do you say that the ideal low-pass filters are not BIBO stable? >>>> The impulse response you give has a finite amount of energy in it, and >>>> it goes to zero over time -- that says "BIBO stable" to me. >>> >>> For BIBO stability, the impulse response has to be absolutely summable >>> (http://en.wikipedia.org/wiki/BIBO_stability). >>> >>> The sinc function is not absolutely summable (or integrable in >>> continuous time http://en.wikipedia.org/wiki/Sinc_function), so the >>> ideal low pass filter is not BIBO stable. :-) >> >> Ayup. Here's a copy of the post (from Google Groups) on a proof I made a few years back: >> > -- snip -- > > Well, I'll be dipped. > > For what evil (yet bounded) signals does a filter with this impulse > response respond with infinite strength?It was embedded in the proof: Now assume x[L*m] = sgn(h[1-L*m]).> My intuition tells me that it would be sin(wt). But then, my > intuition told me earlier today that the system was stable, so I'm > not sure it's trustworthy.When I first realized this I had a hard time swallowing it, too. My encounter came about when I was trying to predict what the bound of the output of interpolating filter in my delta-sigma DAC would be. -- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
On Jun 9, 9:22 pm, Tim Wescott <t...@seemywebsite.com> wrote:> On Sat, 09 Jun 2007 20:59:19 -0400, Randy Yates wrote: > > p.kootsoo...@remove.ieee.org (Peter K.) writes: > > >> Tim Wescott <t...@seemywebsite.com> writes: > > >>> Why do you say that the ideal low-pass filters are not BIBO stable? > >>> The impulse response you give has a finite amount of energy in it, and > >>> it goes to zero over time -- that says "BIBO stable" to me. > > >> For BIBO stability, the impulse response has to be absolutely summable > >> (http://en.wikipedia.org/wiki/BIBO_stability). > > >> The sinc function is not absolutely summable (or integrable in > >> continuous timehttp://en.wikipedia.org/wiki/Sinc_function), so the > >> ideal low pass filter is not BIBO stable. :-) > > > Ayup. Here's a copy of the post (from Google Groups) on a proof I made a few years back: > > -- snip -- > > Well, I'll be dipped. > > For what evil (yet bounded) signals does a filter with this impulse > response respond with infinite strength? My intuition tells me that it > would be sin(wt). But then, my intuition told me earlier today that the > system was stable, so I'm not sure it's trustworthy.A sinc has bounded energy because, even though the positive peaks only decrease roughly harmonically, the negative lobes cancel out most of the previous positive lobe, and the difference between the positive and negative lobes decreases faster than harmonically (more like an alternating harmonic series, which does converge). However, say you have a filter input which is positive for the positive lobes of a sinc filter function, but zero or negative for all the negative lobes of a sinc. Then it looks like the filter output might not converge for an arbitrarily long filter and filter input. I think (sin(t-t0) * sgn(t-t0)) or similar input would do it. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
