Question about Sigma-Delta conversion/decimation
Started by Kiran June 12, 2007
Hi all,
  My question is related to sigma-delta conversion.  I understand the
analog side of this, i.e. the modulator, and have developed a matlab
simulation which gives me 1's and -1's output for any input signal.
Essentially, this is the high data rate 1 bit output of the sigma
delta modulator.
  Now, I need help understanding the decimation process.
Conceptually, I understand what decimation is (low pass filtering and
then downsampling).  However, how does this yield a multibit output?
i.e., how do the high rate of 1 bit outputs turn into a multi-bit
output?
thanks for your help!
"Roughly one-third of the American diet comes from food-"
Holden, Science October 2006 issue
Kiran wrote:
> Hi all, > My question is related to sigma-delta conversion. I understand the > analog side of this, i.e. the modulator, and have developed a matlab > simulation which gives me 1's and -1's output for any input signal. > Essentially, this is the high data rate 1 bit output of the sigma > delta modulator. > Now, I need help understanding the decimation process. > Conceptually, I understand what decimation is (low pass filtering and > then downsampling). However, how does this yield a multibit output? > i.e., how do the high rate of 1 bit outputs turn into a multi-bit > output?
Let's stick with analog, since you have no trouble with that. Imagine your high-speed stream of 1s and -1s fed into an analog low-pass filter, and consider the output. There will clearly be a continuous signal that could in some cases exceed +/-1 by a little. It will in fact be a pretty good reconstruction of the original signal. Now feed the 1s and -1s into a digital filter instead and decimate its output. That is a sampled version of the analog filter's output. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
