robert bristow-johnson wrote:> On Oct 1, 5:43 pm, Tim Wescott <t...@seemywebsite.com> wrote: > ... >> In which case a look-up table would work nice, except for the minor >> problem of the infinite ordinate -- then one may want a lookup table >> with ever-increasing intervals, which actually wouldn't be too bad to >> implement. > > so how would one determine the index into the table without some > repeated search and compare operations?For floating point, look at the mantissa and do it sorta logarithmically. For fixed-point, count the number of zeros (preferably with fast, pipelined logic).> > also, i think something like > > arctan(1/x) = pi/2 - arctan(x) > > can be used for the the nearly infinite ordinates, no? (a division is > required.) > > dunno how this would work for hardware, but if a single division is > tolerable and > for -1 <= x <= 1, a very accurate approximation is: > > arctan(x) ~= x/f(x^2) > > where > > f(u) = 1.0 > + 0.33288950512027 * u > + -0.08467922817644 * u^2 > + 0.03252232640125 * u^3 > + -0.00749305860992 * u^4 > > maybe too many terms, but it's not the finite power series that's bad, > but the division by it that's costly in many different contexts. > > r b-j > >-- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Implementation of Arctan(x)
Started by ●October 1, 2007
Reply by ●October 1, 20072007-10-01
Reply by ●October 2, 20072007-10-02
>Hi, > I am implementing arctan(x) in hardware can any one suggest me any >of the algorithms other than cordic because it takes lots of iterationsto>reach the final result. > >Thanks and Regards >Karthik W > >Hi, Thanks for the response. But actually I am implementing an rectangular to polar cordinate conversion ie x + i y to sqrt(x^2 + y^2)arctan(y/x). So I need arctan(y/x) not arctan(x) because a divider costs a lot with respect to area. I intend a accuracy of 4 decimal place which is q15 fixed point format.If go to lookup table, I need a huge memory of 2^16. Interpolation technique is good but I think for hardware implementation its quite complex ,I some cases I may need a divider or a multiplier. I also tried looking into the variants (formulas) of arctan but all need a divider in some or the other way .So if I can have methood which costs less on area and with faster speed than cordic then it will be good. Thanks and Regards Karthik W
On Oct 2, 2:35 am, "karthikw" <karthikw...@gmail.com> wrote: ...> > I am implementing arctan(x) in hardware can any one suggest me any > >of the algorithms other than cordic because it takes lots of iterations to > >reach the final result. >...> ... I am implementing an rectangular > to polar cordinate conversion ie x + i y to sqrt(x^2 + y^2)arctan(y/x). So > I need arctan(y/x) not arctan(x) because a divider costs a lot with > respect to area. I intend a accuracy of 4 decimal place which is q15 fixed > point format.If go to lookup table, I need a huge memory of 2^16. > Interpolation technique is good but I think for hardware implementation > its quite complex ,I some cases I may need a divider or a multiplier. I > also tried looking into the variants (formulas) of arctan but all need a > divider in some or the other way .So if I can have methood which costs > less on area and with faster speed than cordic then it will be good.i don't think you'll avoid division. also you will have to break up your (x,y) coordinate pair into 4 quadrants (maybe 5, if you want your answer to alway be the Principal Angle which has magnitude less than pi) as is done in the atan2(x,y) function. is this for FM demodulation? ultimately, is what you want the *difference* in angles from the previous (complex) sample to the current: arg{ (x[n] + j*y[n]) } - arg{ x[n-1] + j*y[n-1] } ? is that what you want, in the end? we've had discussions about this previously on comp.dsp, but i do not know the links. is your gmail address valid and an account that you check your mail? is that where i can email you? r b-j
Reply by ●October 3, 20072007-10-03
>On Oct 2, 2:35 am, "karthikw" <karthikw...@gmail.com> wrote: >... >> > I am implementing arctan(x) in hardware can any one suggest meany>> >of the algorithms other than cordic because it takes lots ofiterations to>> >reach the final result. >> >... >> ... I am implementing an rectangular >> to polar cordinate conversion ie x + i y to sqrt(x^2 + y^2)arctan(y/x).So>> I need arctan(y/x) not arctan(x) because a divider costs a lot with >> respect to area. I intend a accuracy of 4 decimal place which is q15fixed>> point format.If go to lookup table, I need a huge memory of 2^16. >> Interpolation technique is good but I think for hardwareimplementation>> its quite complex ,I some cases I may need a divider or a multiplier.I>> also tried looking into the variants (formulas) of arctan but all needa>> divider in some or the other way .So if I can have methood which costs >> less on area and with faster speed than cordic then it will be good. > >i don't think you'll avoid division. also you will have to break up >your (x,y) coordinate pair into 4 quadrants (maybe 5, if you want your >answer to alway be the Principal Angle which has magnitude less than >pi) as is done in the atan2(x,y) function. is this for FM >demodulation? ultimately, is what you want the *difference* in angles >from the previous (complex) sample to the current: > > arg{ (x[n] + j*y[n]) } - arg{ x[n-1] + j*y[n-1] } ? > >is that what you want, in the end? we've had discussions about this >previously on comp.dsp, but i do not know the links. > >is your gmail address valid and an account that you check your mail? >is that where i can email you? > >r b-j >Hi, Thanks for the reply. My mail id is karthikwali@gmail.com. I am implementing arctan(x,y) for FFT. The general formula for atan(x,y) = i log((x + iy)/sqrt(x^2 + y^2)). And you can see how complex it is to implement in hardware.So I thought for going to cordic, but it is requiring 13 cycle latency if I pipeline it.But if I want to calculate it at different times always there will be a latency of 13 cycles. Thanks and Regards Karthik W
Reply by ●October 4, 20072007-10-04
On Tue, 02 Oct 2007 01:35:10 -0500, "karthikw" <karthikwali@gmail.com> wrote:>>Hi, >> I am implementing arctan(x) in hardware can any one suggest me any >>of the algorithms other than cordic because it takes lots of iterations >to >>reach the final result. >> >>Thanks and Regards >>Karthik W >> >> >Hi, > Thanks for the response. But actually I am implementing an rectangular >to polar cordinate conversion ie x + i y to sqrt(x^2 + y^2)arctan(y/x). So >I need arctan(y/x) not arctan(x) because a divider costs a lot with >respect to area. I intend a accuracy of 4 decimal place which is q15 fixed >point format.If go to lookup table, I need a huge memory of 2^16. >Interpolation technique is good but I think for hardware implementation >its quite complex ,I some cases I may need a divider or a multiplier. I >also tried looking into the variants (formulas) of arctan but all need a >divider in some or the other way .So if I can have methood which costs >less on area and with faster speed than cordic then it will be good. > >Thanks and Regards >Karthik WHi Karthik, ya' might take a look at "Another Contender in The Arctangent Race", by R. Lyons, IEEE Signal Processing Magazine, DSP Tips & Tricks column, Vol. 21, No. 1, Jan. 2004, page 109. The algorithm there yields an arctan accuracy of roughly one quarter of a degree, and does not use a lookup table. The algo is fairly efficient except, darn it, it requires a divide operation. I don't know of a fast, accurate, table-free, divide-free arctan algorithm. If you find one, Karthik, you'll become famous. Good Luck, [-Rick-]
Reply by ●October 16, 20072007-10-16
karthikw wrote:>>Hi, >> I am implementing arctan(x) in hardware can any one suggest me any >>of the algorithms other than cordic because it takes lots of iterations > > to > >>reach the final result. >> >>Thanks and Regards >>Karthik W >> >> > > Hi, > Thanks for the response. But actually I am implementing an rectangular > to polar cordinate conversion ie x + i y to sqrt(x^2 + y^2)arctan(y/x). So > I need arctan(y/x) not arctan(x) because a divider costs a lot with > respect to area. I intend a accuracy of 4 decimal place which is q15 fixed > point format.If go to lookup table, I need a huge memory of 2^16. > Interpolation technique is good but I think for hardware implementation > its quite complex ,I some cases I may need a divider or a multiplier. I > also tried looking into the variants (formulas) of arctan but all need a > divider in some or the other way .So if I can have methood which costs > less on area and with faster speed than cordic then it will be good. > > Thanks and Regards > Karthik W > >Unfortunately, most of the algorithms for arctan involve division by a variable, so I don't think you are going to find any that give much of a net savings in latency over CORDIC for similar performance. The best performance will be from a look-up table, but you are obviously limited by to a relatively small number of angles by the size of the memory. Your best bet might be to use a cross between CORDIC and a look-up where instead of having a binary rotation decision at each step, you have a small finite number of rotation angles. That result is then passed to subsequent stages that have finer angular resolutions. I think in the end though, you'll wind up with about the same latency as the CORDIC. The other advantage to using CORDIC is that you obtain not only the arctan, but you also get the magnitude, and you don't need to compute a square root for it. The square root and the divide are both hardware intensive and don't lend themselves well to parallelizing because the intermediate results depend on the previous intermediate results. Same is true for CORDIC, only CORDIC gives you both functions at once. Perhaps you can look at ways to speed up the CORDIC, maybe using a multiplied clock or not pipelining at every stage.
Reply by ●October 22, 20072007-10-22
>karthikw wrote: > >>>Hi, >>> I am implementing arctan(x) in hardware can any one suggest meany>>>of the algorithms other than cordic because it takes lots ofiterations>> >> to >> >>>reach the final result. >>> >>>Thanks and Regards >>>Karthik W >>> >>> >> >> Hi, >> Thanks for the response. But actually I am implementing anrectangular>> to polar cordinate conversion ie x + i y to sqrt(x^2 + y^2)arctan(y/x).So>> I need arctan(y/x) not arctan(x) because a divider costs a lot with >> respect to area. I intend a accuracy of 4 decimal place which is q15fixed>> point format.If go to lookup table, I need a huge memory of 2^16. >> Interpolation technique is good but I think for hardwareimplementation>> its quite complex ,I some cases I may need a divider or a multiplier.I>> also tried looking into the variants (formulas) of arctan but all needa>> divider in some or the other way .So if I can have methood which costs >> less on area and with faster speed than cordic then it will be good. >> >> Thanks and Regards >> Karthik W >> >> > > >Unfortunately, most of the algorithms for arctan involve division by a >variable, so I don't think you are going to find any that give much of a>net savings in latency over CORDIC for similar performance. The best >performance will be from a look-up table, but you are obviously limited >by to a relatively small number of angles by the size of the memory. >Your best bet might be to use a cross between CORDIC and a look-up where>instead of having a binary rotation decision at each step, you have a >small finite number of rotation angles. That result is then passed to >subsequent stages that have finer angular resolutions. I think in the >end though, you'll wind up with about the same latency as the CORDIC. >The other advantage to using CORDIC is that you obtain not only the >arctan, but you also get the magnitude, and you don't need to compute a >square root for it. The square root and the divide are both hardware >intensive and don't lend themselves well to parallelizing because the >intermediate results depend on the previous intermediate results. Same >is true for CORDIC, only CORDIC gives you both functions at once. > >Perhaps you can look at ways to speed up the CORDIC, maybe using a >multiplied clock or not pipelining at every stage. >Hi, Thanks for the suggestion.Do you know any papers which, gives the above concept of mixing both lut and cordic, and also good papers on fast hardware implementation of cordic. I wanted some information on radix4 cordic implementation, can you tell me a good paper on radix4 cordic implementation. Thanks and Regards Karthik W
Reply by ●October 23, 20072007-10-23
> Hi, > Thanks for the suggestion.Do you know any papers which, gives the > above concept of mixing both lut and cordic, and also good papers on fast > hardware implementation of cordic. I wanted some information on radix4 > cordic implementation, can you tell me a good paper on radix4 cordic > implementation. > > Thanks and Regards > Karthik W1) G O O G L E. Ray's writeup(s) on CORDIC is/are probably the most read and most cited. 2) Spend more time thinking than googling. Karthik S.
On Oct 23, 1:18 am, Karthik <karthik301...@gmail.com> wrote:> > Hi, > > Thanks for the suggestion.Do you know any papers which, gives the > > above concept of mixing both lut and cordic, and also good papers on fast > > hardware implementation of cordic. I wanted some information on radix4 > > cordic implementation, can you tell me a good paper on radix4 cordic > > implementation. > > > Thanks and Regards > > Karthik W > > 1) G O O G L E. Ray's writeup(s) on CORDIC is/are probably the most > read and most cited. > > 2) Spend more time thinking than googling. > > Karthik S.we're gonna have to keep track of the fact that there are two different Karthiks hanging around here. r b-j
Reply by ●October 24, 20072007-10-24
