FFT code for dsPIC
Started by charlyb May 10, 2008
Hi
Has anyone written their own fft function for the dsPIC ? (NOT the
supplied library fft).
I need a fft for measuring signal in noise and not being a DSP person
would prefer to implement it rather than write it from scratch. The dsPIC
library scales the data by 1/N which limits the dynamic range of the fft.
I can post scale and run the fft again until I have a usable number - its
just a lot of extra processing.
Thanks in advance.
On May 10, 7:46&#4294967295;am, "charlyb" <c...@eca.co.za> wrote:
> Hi > > Has anyone written their own fft function for the dsPIC ? (NOT the > supplied library fft). > > I need a fft for measuring signal in noise and not being a DSP person > would prefer to implement it rather than write it from scratch. The dsPIC > library scales the data by 1/N which limits the dynamic range of the fft. > > I can post scale and run the fft again until I have a usable number - its > just a lot of extra processing. > > Thanks in advance.
you not going to get any more dynamic range unless you use floating point or 32 bit fixed point FFT
I am not sure this is true. Before 32bit fixed point and floating
point DSP were introduced, everybody have to work on 16 bit or even 8
bit processor. Many techniques have been developed to gain high
dynamic range. Among them the most popular one is called block
floating point FFT. This method simply carefully scales each stage of
FFT to maximize its calculation dynamic range. The problem of 1/N is
naturally part of this process. Charlyb, you can find the solution on
older textbooks.
James
www.go-ci.com
