8 Weeks - 8 Giveaways!
Stephane BoucherMarch 10, 2021
If for some reason, you've been putting off registering for the upcoming 2021 Embedded Online Conference, here are 8 good reasons to register today.
The idea is simple; if you are registered for the conference by the 'raffle date' for any of the following giveaways, you'll automatically be entered into the draw.
So for instance, if you are already registered for the conference or register before March the 22nd, you'll be automatically entered into the 8 draws for a chance to win any of the following prizes.
Are you registered yet?  Make sure to enter promo code ER90 to save $100 on the current registration fee (valid until the end of April).
Prize: Three-days TEST-DRIVEN DEVELOPMENT FOR C OR C++ TRAINING
Raffle date: Mars 22
Value: $1,000
This training course helps you build knowledge, understanding and skill in the engineering practices needed to build great C or C++ code. You learn how to build flexible and modular software with very few defects, software that can have a long useful life. We teach you how to prevent defects and how to keep code clean over years of evolving needs.
Prize: Siglent SDS1104X-E Oscilloscope
Raffle date: Mars 29
Value: $499
  • 100Mhz, 4 channels, 1Gsa/use, 1Mpts fft
  • Standard decoder: iic, spi, uart/Rs232, can, lin
  • 16 digital channels (mso) (four channel series only, option)
Prize: Saleae Logic Pro 8
Raffle date: April 5
Value: $699
  • 8 Digital/Analog inputs (multi-use)
  • Decode SPI, I2C, and 20+ more
  • Digital sample rate up to 500 MS/s, Analog sample rate up to 50 MS/s
  • 10 Billion+ samples of digital, 500 Million+ samples of analog (uses PC memory, USB 3.0)
  • Cross platform - Mac, Windows, & Linux (Ubuntu)
Prize: Beningo’s Embedded Group RTOS Workshop Package
Raffle date: April 12
Value: $1995
This package includes three course, contains nineteen lectures and labs that run approximately 1 - 1.5 hours long each.  The courses are:
Prize: Joulescope
Raffle date: April 19
Value: $799
Joulescope measures current and voltage, then computes power and energy. Joulescope™ enables designers, engineers, and makers to quickly and easily optimize the energy consumption and battery life of a target device. Joulescope is designed to automatically handle wide current ranges and rapid changes in energy consumption, while allowing the target device to run normally.
Prize: Zeroplus Logic Analyzer Lap-C Pro 32-Channels 256Mb per Channel Compitable with Windows, Portable & Flexible
Raffle date: April 26
Value: $3,500
  • 32-Channels Logic Analyzer, 256Mb per Channel
  • 6 protocol triggers (hardware): I2C, I2S, SPI, SVID, UART, CAN2.0B
  • Pattern Generator: I2C, SPI, UART, CAN, more than 120 built-in protocol decoders
  • Long-time records: Transfer via USB 3.0 to hard drive to sample for hours or days
  • Compitable with Windows OS 10/ 8.1 / 7 (32 or 64 bit)
Prize: Rigol DS1202Z-E Oscilloscope
Raffle date: May 3
Value: $369
  • 200 MHz bandwidth
  • 2 analog channels
  • 1 GSa/s Real Time Sample Rate
  • 24 Mpts memory depth
  • Innovative "UltraVision" technology
  • Serial Triggering and Analysis Included
Prize: Percepio's Tracealyzer One Year License
Raffle date: May 10
Value: $1695
Tracealyzer is the premier solution for visual trace diagnostics, giving embedded software developers amazing insight into their runtime systems. This allows for easier debugging of system-level issues, finding software designs flaws and for measuring software timing and resource usage. Ensure your code is reliable, efficient and responsive. If not, learn why.
