SDA Ethernet encapsulation with chatGPT o1 (part 2)
Leonard DieguezMarch 21, 2025
In my last post I covered some aspects of using chat GPT o4 to produce a module according to the SDA specification of Ethernet encapsulation. This module represents a transmitted encapsulated Ethernet packet with respect to the SDA specification. That post can be found here:
In this post I want to explore changing the LLM to chatGPT o1 , giving a very detail explanation of the module to be produced and analyze the outcome and potentially make corrections to the prompt. One of the goal changes is to produce one module (entity) that only encapsulates the Ethernet packets and does not produce the SDA frame.
The prompt used and associated code can be found here:
At first glance the code looks fairly good and chat GPT provides a very good explanation of what it's doing with the checks it also suggests what could be further implemented.
One of the key requirements of the prompt is to have a function that operates as a modified FIFO that can be reset to the last packet that is received correctly. ChatGPT is able to infer this but the treatment of a FIFO is not correct. The input is not decoupled from the output. In other words, you cannot write into the FIFO and read from the FIFO concurrently.  It uses a single statement machine implementation where there's a send packet state that is tied into the other states with respect to receiving packets. For my perspective this is a flaw in what it perceives as a definition of fifo.
I then adjusted the prompt and had it output a test bench with requirements. These are the results:
errors :
  • [USF-XSim-62] 'compile' step failed with error(s). Please check the Tcl console output or 'C:/Projects/IRAD/SDA/vivado/sda/sda.sim/sim_1/behav/xsim/xvhdl.log' file for more information.
  • [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
syntax errors , vivado gave this line as a syntax error where it did not like the ( \" )
report \"All packets submitted. End of test.\" severity note;
ERROR: [VRFC 10-724] found '0' definitions of operator "xor", cannot determine exact overloaded matching definition for "xor" [C:/Projects/IRAD/SDA/tb/sda_fsoe_make_tb.vhd:142]
line 142: if sig_in(31) xor sig_in(21) xor sig_in(1) xor sig_in(0) = '1' then
rather than performing boolean logic on unsigned integers I cast the vector into a standard logic vector
fix:
    variable sig_in_slv : std_logic_vector(31 downto 0);
    sig_in_slv := STD_LOGIC_VECTOR(sig_in);
The problem is that the VHDL tool is having trouble resolving the overloaded "xor" operator when it's used in a chain without explicit grouping. Even though VHDL defines "xor" as left-associative, some tools require you to add parentheses to help with overload resolution.
to fix the line by introduce explicit grouping so that the binary operations are performed one at a time. For example, you can rewrite the condition like this:
was:     if sig_in_slv(31) xor sig_in_slv(21) xor sig_in_slv(1) xor sig_in_slv(0) = '1' then
fix,  force the simulator to perform bit : if (((sig_in_slv(31) xor sig_in_slv(21)) xor sig_in_slv(1)) xor sig_in_slv(0)) = '1' then
WARNING: [VRFC 10-393] cannot access 'rand_val' from inside pure function 'rand_int'. [C:/Projects/IRAD/SDA/tb/sda_fsoe_make_tb.vhd:155]
ERROR: [VRFC 10-1281] process cannot have both a wait statement and a sensitivity list [C:/Projects/IRAD/SDA/tb/sda_fsoe_make_tb.vhd:329]
I fixed a few issues, but the simulation still failed. Random data was never written into the BRAM and a comparison check failed in the simulation giving this error. ERROR: [Simulator 45-1] A fatal run-time error was detected.  Simulation cannot continue.
In general,  chatGPT o1 still fails and requires the user to fix some errors and the overall simulation does not work. I did not go into the specifics to finish this debug or check to see if the overall solution would work. values being written into the BRAM from the input (slave side of the interface) were stalled or wrong.
chatGPT module prompt:
1st prompt
section 3.4.8 Ethernet Encapsulation it describes how to encapsulate Ethernet packets. There are to be 2 modules (Entities) that perform the task of encapsulating Ethernet packets and producing a FSO payload frame . Act as a VHDL digital design engineer and code in vhdl a module that inputs AXIS-stream Ethernet packets where the data width is 32 bits wide, the first data word is marked by the first assertion of s_tvaild and s_tready after the previous s_tlast. The last data word is marked by s_tlast, s_tvalid, and s_tready asserted. s_tkeep identifies the valid bytes in the last data beat. You are to code the first entity. Name it "sda_fsoe_make". The function is to gather Ethernet packet data, perform functions to populate the FSO packet header, output as a AXIS-stream master the "wrapped" Ethernet packet with its header. The term wrapped Ethernet packet describes the Ethernet packet with a valid SDA FSO packet header. The input is an axi stream interface and the output is an axi-stream interface. inputs are identified as "s_t" then the name of the signal follows. For example data, keep, last, valid. The output is identified as "m_t" then the signal name. This module should perform a byte count as the data is received and use this byte count to populate the FSO packet header. The data and header should be stored in a FPGA internal memory structure known as a block ram or BRAM for short. This structure should function as a modified FIFO. As data is received it is written into the FIFO. The first data beat should be written into the 2nd location. Once the last word is received the header is populated in the first location for that packet. The received Ethernet packet should be checked for maximum MTU size. If it is over the maximum the data in the FIFO should be discarded, the write pointer should be reset to it's previous location prior to receiving that packet. The FIFO width should be 32-bits wide and 2048 words deep. It should be able to hold at least 5 Ethernet packets if each one is its maximum size. This unique FIFO should be able to return the write pointer to the next location after the end of the last good packet received. If there are any errors in the packet that is being received the rest of the input data is ignored and the data in the fifo is to be removed by returning the write pointer to the last good location prior to receiving data from the bad transaction. Analyze the code produced and check for correctness in function.
2nd prompt
The code in sda_fsoe_make.vhd does not have the ability to receive an AXIS stream and source an AXIS stream, or act as a slave and master at the same time. In general FIFO should be able to accept data written to them and also read data from the FIFO at the same time. This requires 2 processes, a write process and a read process. The read process will source data on the AXIS-stream master signals. Modify the code sda_fsoe_make.vhd to support these changes.
chatGPT module code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;  -- For arithmetic on integers, unsigned
entity sda_fsoe_make is
    generic (
        G_MAX_MTU            : integer := 1500;   -- Max Ethernet Payload in bytes
        G_BRAM_DEPTH         : integer := 2048;   -- BRAM depth (in 32-bit words)
        G_DATA_WIDTH         : integer := 32;     -- Data width (bits)
        G_HEADER_WORDS       : integer := 1       -- # of words reserved for FSO header
    port (
        clk         : in  std_logic;
        reset       : in  std_logic;
        -- AXI-Stream Slave: Ethernet input
        s_tvalid    : in  std_logic;
        s_tready    : out std_logic;
        s_tdata     : in  std_logic_vector(G_DATA_WIDTH-1 downto 0);
        s_tkeep     : in  std_logic_vector((G_DATA_WIDTH/8)-1 downto 0);
        s_tlast     : in  std_logic;
        -- AXI-Stream Master: Wrapped data output
        m_tvalid    : out std_logic;
        m_tready    : in  std_logic;
        m_tdata     : out std_logic_vector(G_DATA_WIDTH-1 downto 0);
        m_tkeep     : out std_logic_vector((G_DATA_WIDTH/8)-1 downto 0);
        m_tlast     : out std_logic
end sda_fsoe_make;
architecture Behavioral of sda_fsoe_make is
    -- TYPE & CONSTANT DECLARATIONS
    type bram_type is array (0 to G_BRAM_DEPTH-1) of std_logic_vector(G_DATA_WIDTH-1 downto 0);
    -- Write state machine
    type w_state_type is (
        W_IDLE,       -- Wait for start of packet
        W_RECEIVE,    -- Receiving data into FIFO
        W_ERROR,      -- Error/oversize, discard partial
        W_DONE        -- Wrap up the write side
    -- Read state machine
    type r_state_type is (
        R_IDLE,       -- Wait for a packet to be available
        R_WRITEHDR,   -- Insert header into 1st word for this packet
        R_READOUT,    -- Streaming out data
        R_DONE        -- Clean up
    -- SIGNAL DECLARATIONS
    -- Shared FIFO
    signal bram_mem         : bram_type := (others => (others => '0'));
    -- Write side
    signal w_state          : w_state_type := W_IDLE;
    signal write_ptr        : integer range 0 to G_BRAM_DEPTH-1 := 0;  -- Points to next write location
    signal write_ptr_start  : integer range 0 to G_BRAM_DEPTH-1 := 0;  -- For header insertion offset
    signal saved_write_ptr  : integer range 0 to G_BRAM_DEPTH-1 := 0;  -- Last valid end-of-packet pointer
    signal w_byte_count     : integer := 0;                            -- Byte count for current packet
    -- Read side
    signal r_state          : r_state_type := R_IDLE;
    signal read_ptr         : integer range 0 to G_BRAM_DEPTH-1 := 0;  -- Next read location
    signal r_byte_count     : integer := 0;                            -- Byte count for current reading packet
    -- FSO Header and related
    signal fso_header_word  : std_logic_vector(G_DATA_WIDTH-1 downto 0) := (others => '0');
    -- AXI-Stream outputs
    signal m_valid_reg      : std_logic := '0';
    signal m_data_reg       : std_logic_vector(G_DATA_WIDTH-1 downto 0) := (others => '0');
    signal m_keep_reg       : std_logic_vector((G_DATA_WIDTH/8)-1 downto 0) := (others => '1');
    signal m_last_reg       : std_logic := '0';
    -- AXI-Stream inputs
    signal s_ready_reg      : std_logic := '0';
    -- SIMPLE HELPER FUNCTION: MAKE FSO HEADER
    -- Example format:
    --  31:16 -> Magic 0xCDEF
    --  15:2  -> Packet length in bytes (14 bits)
    --  1:0   -> Reserved
    function make_fso_header(byte_len : integer) return std_logic_vector is
        variable tmp : std_logic_vector(31 downto 0) := x"CDEF0000";
        variable l14 : unsigned(13 downto 0);
    begin
        -- Convert length to 14 bits
        l14 := to_unsigned(byte_len, 14);
        -- Insert length at bits [15:2]
        tmp(15 downto 2) := std_logic_vector(l14);
        return tmp;
    end function;
begin
    -- AXI-Stream slave/master port mapping
    -- Outputs
    s_tready <= s_ready_reg;
    m_tvalid <= m_valid_reg;
    m_tdata  <= m_data_reg;
    m_tkeep  <= m_keep_reg;
    m_tlast  <= m_last_reg;
    -- WRITE PROCESS (AXI-Stream Slave) - store data in FIFO
    WriteProcess : process(clk)
    begin
        if rising_edge(clk) then
            if reset = '1' then
                w_state         <= W_IDLE;
                write_ptr       <= 0;
                write_ptr_start <= 0;
                saved_write_ptr <= 0;
                w_byte_count    <= 0;
                s_ready_reg     <= '0';
            else
                -- Default
                s_ready_reg <= '0';
                case w_state is
                    -- W_IDLE: Wait for new packet start
                    when W_IDLE =>
                        -- Set next packet to begin at saved_write_ptr
                        write_ptr_start <= saved_write_ptr;
                        write_ptr       <= saved_write_ptr + G_HEADER_WORDS;  -- skip the header area
                        w_byte_count    <= 0;
                        s_ready_reg     <= '1';  -- Ready to accept data
                        if (s_tvalid = '1') then
                            -- Accept first beat
                            bram_mem(write_ptr) <= s_tdata;
                            write_ptr    <= write_ptr + 1;
                            w_byte_count <= w_byte_count + 4;
                            if s_tlast = '1' then
                                -- If single beat packet
                                if w_byte_count + 4 > G_MAX_MTU then
                                    w_state <= W_ERROR;
                                else
                                    w_state <= W_DONE;
                                end if;
                            else
                                w_state <= W_RECEIVE;
                            end if;
                        end if;
                    -- W_RECEIVE: Storing packet data
                    when W_RECEIVE =>
                        s_ready_reg <= '1';
                            -- Write next word
                                w_state <= W_ERROR;
                            elsif s_tlast = '1' then
                                w_state <= W_DONE;
                            end if;
                        end if;
                    -- W_ERROR: Discard partial packet
                    when W_ERROR =>
                        s_ready_reg <= '1';
                        -- Wait for s_tlast to skip rest
                                -- Discard partial by reverting
                                write_ptr    <= saved_write_ptr;
                                w_byte_count <= 0;
                                w_state      <= W_IDLE;
                            end if;
                        end if;
                    -- W_DONE: Packet in FIFO, wait for next
                    when W_DONE =>
                        -- Packet is fully received
                        saved_write_ptr <= write_ptr;
                        w_state         <= W_IDLE;
                    when others =>
                        w_state <= W_IDLE;
                end case;
            end if;
        end if;
    end process;
    -- READ PROCESS (AXI-Stream Master) - read from FIFO
    ReadProcess : process(clk)
    begin
            if reset = '1' then
                r_state      <= R_IDLE;
                read_ptr     <= 0;
                r_byte_count <= 0;
                m_valid_reg  <= '0';
                m_data_reg   <= (others => '0');
                m_keep_reg   <= (others => '1');
                m_last_reg   <= '0';
            else
                -- Defaults each cycle
                m_valid_reg <= '0';
                m_last_reg  <= '0';
                case r_state is
                    -- R_IDLE: Wait for a completed packet in FIFO
                    when R_IDLE =>
                        if (w_state = W_DONE) then
                            -- We know a new packet is done
                            r_byte_count <= w_byte_count;
                            read_ptr     <= write_ptr_start;  -- Start reading from the first word (header loc)
                            r_state      <= R_WRITEHDR;
                        else
                            -- Remain idle
                            r_state <= R_IDLE;
                        end if;
                    -- R_WRITEHDR: Insert the FSO Header at the reserved location
                    when R_WRITEHDR =>
                        -- Make a local FSO header based on the final byte_count
                        fso_header_word <= make_fso_header(r_byte_count);
                        -- Write into the first word
                        bram_mem(write_ptr_start) <= fso_header_word;
                        -- Now start streaming from read_ptr
                        read_ptr     <= write_ptr_start;  -- We'll read from 0 on next cycle
                        r_state      <= R_READOUT;
                    -- R_READOUT: Stream out from FIFO
                    when R_READOUT =>
                        -- We'll assert tvalid if we have data to send
                        if read_ptr < saved_write_ptr then
                            m_valid_reg <= '1';
                            m_data_reg  <= bram_mem(read_ptr);
                            if read_ptr = saved_write_ptr-1 then
                                m_last_reg <= '1';  -- last word
                            end if;
                            -- If the master is ready, consume the word
                            if (m_tready = '1') then
                                read_ptr <= read_ptr + 1;
                                -- If that was last word, go DONE
                                    r_state <= R_DONE;
                                end if;
                            end if;
                        else
                            r_state <= R_DONE;  -- No data to send
                        end if;
                    -- R_DONE: End of packet
                    when R_DONE =>
                        -- Cleanup and wait for next
                        m_valid_reg <= '0';
                        r_state <= R_IDLE;
                    when others =>
                        r_state <= R_IDLE;
                end case;
            end if;
        end if;
    end process;
end Behavioral;
chatGPT testbench prompt:
Provide a VHDL test bench that tests and verifies the required functions of sda_fsoe_make entity. The testbench should include continuous random packets input to the module of random length and random inter-packet gaps. The output should check for correctness of input packets. The output interface should operate at the same time as the input slave interface. The ready signal on the master (output interface) should have a random assertion. There should be a set parameter that indicates the number of input packets used in the simulation. The input packets should also test the error capabilities of the entity. Name the entity sda_fsoe_make_tb.
chat GPT testbench code:
library IEEE;
entity sda_fsoe_make_tb is
end sda_fsoe_make_tb;
architecture Behavioral of sda_fsoe_make_tb is
  -- Generic Constants
  constant CLK_PERIOD      : time := 10 ns;   -- 100 MHz
  constant NUM_TEST_PKTS   : integer := 30;   -- Number of random input packets
  constant MAX_PKT_SIZE    : integer := 2500; -- Some will exceed this to test error
  constant RANDOM_SEED     : integer := 13;   -- For pseudo-random generation
  -- Signals
  signal clk       : std_logic := '0';
  signal reset     : std_logic := '1';
  -- AXI-Stream Slave (input to DUT)
  signal s_tvalid  : std_logic := '0';
  signal s_tready  : std_logic;
  signal s_tdata   : std_logic_vector(31 downto 0) := (others => '0');
  signal s_tkeep   : std_logic_vector(3 downto 0)  := (others => '1');
  signal s_tlast   : std_logic := '0';
  -- AXI-Stream Master (output from DUT)
  signal m_tvalid  : std_logic;
  signal m_tready  : std_logic := '1';
  signal m_tdata   : std_logic_vector(31 downto 0);
  signal m_tkeep   : std_logic_vector(3 downto 0);
  signal m_tlast   : std_logic;
  -- DUT Declaration
  component sda_fsoe_make
    generic (
    port (
      clk         : in  std_logic;
      -- AXI-Stream Slave
      s_tdata     : in  std_logic_vector(31 downto 0);
      s_tkeep     : in  std_logic_vector(3 downto 0);
      m_tdata     : out std_logic_vector(31 downto 0);
      m_tkeep     : out std_logic_vector(3 downto 0);
  end component;
  -- Signals & Variables for Test
  -- Pseudo-random generator
  signal rand_val : unsigned(31 downto 0) := to_unsigned(RANDOM_SEED,32);
  -- Internal scoreboard of input packets
  type pkt_array is array (0 to NUM_TEST_PKTS-1) of std_logic_vector(8*MAX_PKT_SIZE-1 downto 0);
  signal stored_pkts     : pkt_array := (others => (others => '0'));
  signal stored_pkt_size : integer_vector(0 to NUM_TEST_PKTS-1) := (others => 0);
  -- Index to track how many packets we've sent
  signal pkt_index_in  : integer := 0;
  signal pkt_index_out : integer := 0;
  -- Transmission states
  type tb_send_state_type is (TB_SEND_IDLE, TB_SEND_DATA, TB_SEND_DONE);
  signal tb_send_state : tb_send_state_type := TB_SEND_IDLE;
  -- Output capture
  type out_capture_t is array (0 to NUM_TEST_PKTS*2-1) of std_logic_vector(31 downto 0);
  signal out_capture     : out_capture_t := (others => (others => '0'));
  signal out_capture_idx : integer := 0;
  -- Functions
  function pseudo_rand(sig_in : in unsigned(31 downto 0)) return unsigned is
    variable tmp : unsigned(31 downto 0);
  begin
    -- Simple LFSR or shift-based pseudo random
    tmp := sig_in(30 downto 0) & '0';
      tmp(0) := '1';
    end if;
    return tmp;
  end function;
  -- Return random integer in range [0..max-1]
  function rand_int(maxval : integer) return integer is
    variable r : unsigned(31 downto 0);
    variable x : integer;
  begin
    r := pseudo_rand(rand_val);
    x := to_integer(r(15 downto 0)) mod maxval;
    return x;
  end function;
begin
  -- Instantiate DUT
  DUT : sda_fsoe_make
    generic map (
      G_MAX_MTU     => 1500,    -- can be adjusted
      G_BRAM_DEPTH  => 2048,
      G_DATA_WIDTH  => 32,
      G_HEADER_WORDS => 1
    port map (
      clk       => clk,
      reset     => reset,
      -- AXI-Slave
      s_tvalid  => s_tvalid,
      s_tready  => s_tready,
      s_tdata   => s_tdata,
      s_tkeep   => s_tkeep,
      s_tlast   => s_tlast,
      -- AXI-Master
      m_tvalid  => m_tvalid,
      m_tready  => m_tready,
      m_tdata   => m_tdata,
      m_tkeep   => m_tkeep,
      m_tlast   => m_tlast
  -- Clock Generation
  clk_process : process
  begin
    clk <= '0';
    wait for CLK_PERIOD/2;
    clk <= '1';
  end process;
  -- Reset Process
  reset_process : process
  begin
    reset <= '1';
    wait for 10*CLK_PERIOD;
    reset <= '0';
    wait;
  end process;
  -- Stimulus: AXI-Slave Input (s_t*)
  slave_stim : process(clk)
    variable cur_length : integer;
    variable cur_offset : integer;
    variable wait_gap   : integer;
  begin
      rand_val <= pseudo_rand(rand_val);  -- Update seed
      case tb_send_state is
        when TB_SEND_IDLE =>
          -- Have we sent all test packets?
          if pkt_index_in < NUM_TEST_PKTS then
            -- Random inter-packet gap
            wait_gap := rand_int(10);  -- up to 9 cycles
            if wait_gap > 0 then
              s_tvalid <= '0';
              s_tdata  <= (others => '0');
              s_tlast  <= '0';
              wait_gap := wait_gap - 1;
            else
              -- Start sending a new packet
              cur_length := rand_int(MAX_PKT_SIZE) + 1;  -- Range 1..MAX_PKT_SIZE
              stored_pkt_size(pkt_index_in) <= cur_length;
              -- Create pseudo-random data for it
              for i in 0 to cur_length-1 loop
                stored_pkts(pkt_index_in)(8*i + 7 downto 8*i) <= std_logic_vector(to_unsigned(rand_int(256),8));
              end loop;
              cur_offset := 0;
              s_tvalid <= '1';
              tb_send_state <= TB_SEND_DATA;
            end if;
          else
            -- No more input packets
            s_tvalid <= '0';
          end if;
        when TB_SEND_DATA =>
          if s_tready = '1' then
            -- Output next 4 bytes from stored array
            s_tdata  <= stored_pkts(pkt_index_in)(8*cur_offset+31 downto 8*cur_offset);
            cur_offset := cur_offset + 4;
            if (cur_offset*1 >= stored_pkt_size(pkt_index_in)) then
              -- Reached end of packet
              s_tlast <= '1';
              s_tvalid <= '1';
              tb_send_state <= TB_SEND_DONE;
            else
              s_tlast <= '0';
              s_tvalid <= '1';
            end if;
          end if;
        when TB_SEND_DONE =>
            -- Final word accepted
            s_tvalid <= '0';
            s_tlast  <= '0';
            pkt_index_in <= pkt_index_in + 1;
            tb_send_state <= TB_SEND_IDLE;
          end if;
        when others =>
      end case;
    end if;
  end process;
  -- AXI-Master Sink: Reading from m_t* interface
  master_read : process(clk)
  begin
      rand_val <= pseudo_rand(rand_val);  -- random for backpressure
      -- random chance to deassert m_tready
      if rand_int(8) < 2 then
        m_tready <= '0';  -- ~25% chance of backpressure
      else
        m_tready <= '1';
      end if;
      if m_tvalid = '1' and m_tready = '1' then
        -- Capture the output in scoreboard
        out_capture(out_capture_idx) <= m_tdata;
        out_capture_idx <= out_capture_idx + 1;
        -- If it's last
        if m_tlast = '1' then
          -- We can do checks, e.g. parse the header, compare data, etc.
          out_capture_idx <= out_capture_idx; -- freeze or finalize
        end if;
      end if;
    end if;
  end process;
  -- Optional: Add checks / scoreboard logic in a separate process
  --           to compare header & data from out_capture vs stored_pkts
  scoreboard_proc: process(clk)
  begin
      -- Example: Once we've read enough data, we can parse the FSO header, check
      -- For brevity, the final check can be done offline or in a custom sub-block
      if pkt_index_in = NUM_TEST_PKTS then
        -- We could add a time limit or detect last out, then finish
        if out_capture_idx > 0 then
          -- End of simulation or checks
          wait for 100 ns;
          std.env.stop;  -- end simulation
        end if;
      end if;
    end if;
  end process;
end Behavioral;
