Using the C language to program the am335x PRU
Introduction
Some weeks ago, I published an article on how we used the PRU to implement a power supply control loop having hard realtime constraints:
//www.embeddedrelated.com/showarticle/586.php
Writing this kind of logic in assembly language is not easy. First the assembly language itself may be difficult to learn depending on your background. Then, fixed and floating point arithmetics require lot of code. While macros help to handle the complexity, they still are error prone as you must be very careful to enforce rules as regard with register usage for instance. This is especially difficult in projects involving several people, who are not used to work together and not full time on the project. Even if the rules are well established, people tend to forget them when they come back in the project from time to time, several weeks apart.
Someone pointed that TI introduced C support in the latest Code Composer Studio version. For me, using the C language clearly helps in the above issues so I started to investigate this feature. Several people contacted me to know if I made any progress on using the C language to program the PRU. My answer is that the toolchain proposed by TI, called CGT (Code Generation Tools) is very usable once the different tools and some details have been understood.
This article describes how to setup and use the PRU C toolchain, and includes a simple example.
Prerequisites
I have a GITHUB repository containing all the materials related to this article. Please clone it from here:
https://github.com/texane/pru_sdk
The build system assumes that the 2 following variables are correctly set (for instance, using the export shell command):
- CROSS_COMPILE: points to your ARM toolchain,
- PRU_SDK_DIR: points to the directory where you cloned the repo.
Refer to the previous article for more information on how to use it.
Installing the PRU C toolchain
The PRU C toolchain is too big for me to include it in the pru_sdk repo. Thus, you have to install it manually. The following describes how to do so.
First, you have to download the installer from here:
http://processors.wiki.ti.com/index.php/Download_CCS
Registration is required but it is free and runs on both LINUX and Windows. During the installation, you must enable PRU support. Please refer to the following link for more info:
The toolchain is located in the CCS installation directory called pru_2.0.0B2. If you do not find it, you may have to start CCS and install missing components using the GUI menus. The pru_2.0.0B2 directory is self contained and can moved anywhere to be used as is. Please put it in the pru_sdk directory you created previously.
pru_2.0.0B2/bin contains the usual tools:
- clpru: a C compiler,
- asmpru: an assembler,
- dispru: a disassembler,
- lnkpru: a linker,
- hexpru: an output file generation tool,
- others tools to have information on binary (ELF) files.
Also, TI provides a C standard library and a runtime, with the sources included. It can be found in the pru_2.0.0B2/lib directory. More information can be found in the README.txt file and man pages in pru_2.0.0B2/man.
Installing the PRU loader
To load application and interact with the PRU from LINUX, I use the opensource library found here:
https://github.com/beagleboard/am335x_pru_package
One important feature is the loading and execution of PRU binary files. In our case, it must be noted that the starting address will not be 0. Rather, it is located at a symbol called _c_int00, which can be anywhere in the text section. Thus, I had to modify the loading library so that an address can be specified in the routine:
prussdrv_exec_program
This was done by adding a new routine, without breaking existing interfaces:
prussdrv_exec_program_at
It writes the PRU control register address fields, as specified in am335xPruReferenceGuide section 5.4. Refer to examples/pruss_c/host_main.c for an example.
I put the new library in the pru_sdk repo, and I will submit a patch to the official repository soon.
Compiling and running a program
I added an example for this article in the pru_sdk repo, directory example/pruss_c.
The code itself simply does a floating point multiplication on the PRU and puts the result into the memory shared, refer to pru_main.c The CPU reads and display the result, refer to host_main.c
I made a simple script that compiles everything, refer to example/pruss_c/build.sh .
I will integrate it to the pru_sdk build system later. The script works as follow:
- invoke the compiler to produce object files from PRU C files,
- link them to produce an ELF file,
- extract code and data binary from the ELF file,
- retrieve the start address,
- compile the CPU program, to be run on the Beagle Bone Black.
At the end of the process, the following files are produced:
- pru_enable-00A0.dtbo: the device tree overlay enabling the PRU,
- main: the ELF program to be run on the CPU,
- text.bin: the binary file to initialize the PRU code,
- data.bin: the binary file to initialize the PRU data.
You must copy the following files to your BBB board:
- pru_enable-00A0.dtbo into /lib/firmware,
- run.sh,
- main, text.bin and data.bin.
On the BBB, the program is then run using run.sh. It is a small wrapper taking care of loading the uio_pruss driver and enabling the PRU.
Using inline assembly
Accessing some parts of the hardware still require assembly code. Previously, we took care of wrapping this code inside macros. I am in the process of porting these macros into functions usable from C code.
The functions are kept minimal and implemented using inline assembly. The inline assembly support is not as advanced as the GCC one, especially lacking support to describe register usage.
One important thing is to know the calling convention and rules used by the PRU C compiler. They are described in the README.txt. To summarize:
- r2 contains the stack pointer,
- r3 contains the return address,
- r14 to r29 are used for argument passing,
- r14 is used for the return value,
- r3 to r13 must be saved by the callee.
You can look at pru_hal.c for examples. It is still in progress, but gives the idea.
More to come
I am now in the process of rewriting the low level hardware related routines in C. I started with inline assembly, but it may be possible to use intrinsics instead. This is to be investigated.
Another thing to investigate is the generated code size, as the PRU program memory is limited to 8KB. From what I have seen, CLPRU does a good job and provides different optimization options to reduce the generated code size. I will soon see if it is enough.
One may argue about using the PRU C toolchain directly from command line instead of using the CCS software. It is a valid point, as CCS is freely available. Personnaly, I prefer the command line especially as I do not always have a usable X connection to the machine hosting the build system we use for the PRU.
Updates
A reader gave a link to download the PRU C compiler without the whole CCS software:
http://software-dl.ti.com/codegen/non-esd/downloads/beta.htm
You might also like
- Comments
for days, and just found your article. Your efforts are
very much appreciated. Please keep posting your progress
By the way, I found a link on TI's site where one can
Download just the PRU C Compiler ( without the whole CCS)
https://github.com/BeaglePilot/PRUSS-C.
They also modified the am335x_pru_package to support loading the data.bin and text.bin files separately. But they do not provide an entry address like you do - so I'm not sure if this is really neccessary?!? There is a nice blinkled example in subfolder am335x_pru_package\pru_sw\example_apps\blinkled of this repository that shows how to execute a PRU programm compiled with the TI PRU C compiler.
but I did get the prumain.elf, data.bin and text.bin, So I guess the cross compiler is the wrong one, So I changed to another one which from CCS 6, but still have error http://pastebin.com/gRZNAJ48
Could you help me?
I already replied to Marcus on this particular point:
Hi Marcus,
You have to install and use the modified am335x_pru_package
available in the pru_sdk repository, which provides the missing
routine.
Cheers,
Fabien.
Happy hacking!
ENTRY POINT SYMBOL: "_c_int00_noinit_noargs_noexit" address: 000002d4
Your solution seemsto be the right one - great and many thanks :)
Thanks.
Actually it was left as a TODO until someone needed it. I integrated the support for data loading, as done in the BeaglePilot/PRUSS-C github repo. I am pretty confident it will work, but I did not test it yet. If you do please let me know if it works. Everything is in the latest branch of the pru_sdk repo. Thanks for your comments !
example to generate all the files. But I got an error message when the build script tried to generate the pru_enable.dtbo overlay file. It complains about a missing "(" in the .dts file. Didn't have time yet to track that down, but I did add some global variables to the pro_main.c file and manipulated them and they show up in the map file and the data.bin file size is larger. Tomorrow, hopefully, I can finish and actually load it onto my BBB and report back success! Thanks again.
the DTC tool is used to generate the DTBO from DTS. The only reason I see it to fail is that I compiled DTC for a 64 bits architecture using shared libraries. It may fail to execute on your own platform, either because of the hardware architecture or missing dependencies. In this case, you may have to compile the DTC tool yourself.
I just added the DTC source code and a build.sh script in the pru_sdk repository. Please rebuild the DTC tool using the script, and put the resulting binary in the correct directory... I hope this should fix your issue.
Cheers !
I then scp'd all the necessary ties over to my debian BBB, and voila - it works!
Now, I still have much to learn, but thanks to you help, I have a working example to guide me. This has also forced me to learn more about make files and shell scripts, and has propelled me further on my journey of knowledge.
Thank you so very much for all your help and time
I am glad it works and you have learned new things along the way. Also, it did improve the pru_sdk repo, so it was a good interaction.
Cheers,
I cannot reply directly to texane's answer, so I'll post it here. The DTC tool in the pru_sdk/dtc_src (version 1.2.0-g37c0b6a) doesn't work properly even recompiled on my bbb. I get the same error as you had:
Syntax error: "(" enexpected.
When I modified the top.mk to use system default dtc tool (version 1.4.0 on debian wheezy) the dtbo compilation was OK.
0xdeadbeef (-6259853398707798016.000000)
0x2b2b2c2d (0.000000)
0x41fb51ec (31.415001)
0x2404287b (0.000000)
0x9e9b6c26 (-0.000000)
0xad8883d0 (-0.000000)
0x56b5a8ac (99868022407168.000000)
0x2cd21c2e (0.000000)
I do every step you mention above, however, when I compile, there is an error message shows "undefined reference to 'prussdrv_load_datafile".
I google the error message, and someone says that libprussdrv.so causes this problem, so I change the file after I successfully compile app_loader.
But this problem still happens, could you give me some suggestions?
I use build.sh to build your example and should I modify top.mk?
My host is ubuntu 12.04 LTS 32-bit OS.
Thanks for your help!
routine.
It is my fault, now, I can compile successfully.
Anyone else having issues with the compiler?
Bob
Thanks for the info. You can contact TI using the community forums:
http://e2e.ti.com/support/arm/sitara_arm/default.aspx
When you have it, please post here the URL of your forum thread so
that others can know about the bugs you are mentioning, and the
eventual fixes.
Thanks !
You created an _at version of the exec functions, but it seems there is a way to force the linker to put the entry point at 0 (the latest TI examples show it)
putting the following in the linker command file (or using the latest example from TI) removes the need for presetting the PRU program counter, and allows the prudebug command line functions to work properly as well. (I'm debugging remotely)
.text:_c_int00* > 0x0, PAGE 0
I set up the build to create the header file so I can use the exec_code functions (the new compiler won't create them like pasm did)
this might make a good addition to your example code.
Bob
a todo to my repo so that I can work on it when I find some time.
While compiling the code code i am getting lot of file inclusion error, because i am using ccs toolchain for ARM.
where can i download the toolchain arm-buildroot-linux-uclibcgnueabi . Please help me.
Navin
it depends on the platform you are on (Windows, Linux, 32 bits or not ...). A good
starting point to get a precompiled toolchain for Linux is:
http://elinux.org/ARMCompilers
You can also compile it by hand. I do it using crosstool-ng:
crosstool-ng.org/
you with a default one.
After successful compilation, I copied the files to BBB and I run the script run.sh. After I got the below error
FATAL: kernel too old
Segmentation fault
My BBB version ==> Linux beaglebone 3.8.13-bone50 #1 SMP Tue May 13 13:24:52 UTC 2014 armv7l GNU/Linux
Please help me.
Regards,
Navin
you must link against a C library that complies with your kernel. I can not help you
much on this particular point, sorry.
Texane.
shm_write_uint32(0x0120, 0xdeadbeef);
shm_write_uint32(0x0124, 0x2b2b2c2d);
shm_write_float(0x0128, x);
and not changing host_main at all, I built it and ran it and the answers were the same as if I had not written it to a different offset. I'm looking for the reference for how to read the registers from the c function calls. Or any hints to make some progress. Even what my mistake in thinking is?
Thanks
I do not know what the error is. Why are you using 0x120 offset to write your values ?
I am now working on host to pru interrupts using WBS.
Thank you for all of your hard work
http://e2e.ti.com/support/embedded/linux/f/354.aspx
I am trying to figure out how to clear an interrupt and I know what I wrote above isn't right, but it won't compile.
I am trying to clear the ARM_PRU0_INTERRUPT once pru0 responds to it. and I don't know if it is the right logic or if the compile is giving me grief. It seems easy enough.
The ARM_PRU0_INTERRUPT is 21
The STATCLRINT0 offset is 0x280
and what I want to do is:
" LDI R14, 21 \n"
" LDI R15, 0x280 \n"
" SBCO R14, C0, R15, 4 \n"
But the last line won't compile
From the README:
6. Operands with a '&' prefix
The existing PASM assembler accepts operands with or without the &
symbol: LBBO &r0 or LBBO r0. The assembler in this release requires the
& for these operands.
You need the & if you're writing inline assembly. Try " SBCO &R14, C0, R15, 4 \n" and it should compile.
" SBCO R14, c0, 0x24, 4 \n"
this is used often to clear system interrupts but it won't compile for me. The read me talks about some instructions, like MOV that can't be used in specific circumstances. Is there a place to look to find how to alter the instruction to work?
please have a look at the PRU manual here:
https://github.com/texane/pru_sdk/blob/master/doc/am335xPruReferenceGuide.pdf
Cheers,
I am trying to compile your example directly on the Beaglebone Black (rev C). I downloaded the standalone compiler to the bbb as well as your repository. When I run your build script I am running into the following error:
/usr/bin/ld: error: main uses VFP register arguments, /home/..../pru_sdk/lib/libprussdrv.a(prussdrv.o) does not
/usr/bin/ld: failed to merge target specific data of file /home/...pru_sdk/lib/libprussdrv.a(prussdrv.o)
I tried compiling with gcc with different options such as -mfloat-abi=soft but it doesn't seem to make a difference.
Do you know how to compile your example on the bbb directly using gcc?
I have the same problem. It looks the pre-built libraries in pru_sdk/lib are incorrect. Try entering pru_sdk/am335x_pru_package/pru_sw/app_loader/interface and running make. This should produce new libraries (in ../lib) which you copy into pru_sdk/lib. Then recompile the example - the linking stage should not fail this time.
Have anyone tried to compile the example using the linaro toolchain? I tried to crosscompile the example under ubuntu 14.04 LTS and get a list of warnings/errors:
sergej@ubuntu:~/pru_sdk/example/pruss_c$ ./build.sh
Translating to Binary format...
"./pru_main.elf" .text ==> .text
rm -f host_main.o ../common/mio.o
rm -f
rm -f pru_enable-00A0.dtbo
rm -f main
/home/sergej/qt-bbb/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/gcc -DSTART_ADDR=0x0000032c -Wall -O2 -mtune=cortex-a8 -march=armv7-a -I/home/sergej/pru_sdk/include -c -o host_main.o host_main.c
host_main.c: In function main:
host_main.c:78:3: warning: implicit declaration of function prussdrv_load_datafile [-Wimplicit-function-declaration]
host_main.c: At top level:
host_main.c:13:13: warning: zero_words defined but not used [-Wunused-function]
/home/sergej/qt-bbb/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/gcc -DSTART_ADDR=0x0000032c -Wall -O2 -mtune=cortex-a8 -march=armv7-a -I/home/sergej/pru_sdk/include -c -o ../common/mio.o ../common/mio.c
/home/sergej/qt-bbb/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/gcc -static -o main host_main.o ../common/mio.o -L/home/sergej/pru_sdk/lib -lprussdrv
/home/sergej/qt-bbb/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/../../../../arm-linux-gnueabihf/bin/ld: error: main uses VFP register arguments, /home/sergej/pru_sdk/lib/libprussdrv.a(prussdrv.o) does not
/home/sergej/qt-bbb/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file /home/sergej/pru_sdk/lib/libprussdrv.a(prussdrv.o)
host_main.o: In function `main':
host_main.c:(.text.startup+0xaa): undefined reference to `prussdrv_load_datafile'
collect2: error: ld returned 1 exit status
make: *** [main] Error 1
What does it want?
Thank you Fabien for your extremely useful job.
do not mind programming in assembly. And the PRU assembly is quite simple,
which makes it even more appealing to them. Also, the C compiler PRU support
is relatively recent.
That being said, I see more and more physics institutes interested in
using the PRU to replace MCU + DSP/FPGA based solutions. The main reasons
being costs reduction and the simplicity of hard and soft resource sharing
between the PRU and the MCU.
I hope the beagleboard platform will democratize this approach to more open
source projects. When needed, this is much more powerful than the competition
(RPI...)
Could you please share the GCC version used in crosstool-ng while building compiler.
ubuntu 12.04
At the time, I used this version:
texane@debian:~$ ~/repo/lfs/_work_bbb_home/src/crosstool-ng/ct-ng version
This is crosstool-NG version 1.18.0
The base configuration file is:
armv6-rpi-linux-gnueabi
thanks for the tutorials and the source code. It works on my bbb, compiled directly on bbb!
Here is the summary of the issues I had:
- libs in pru_sdk/lib dont contain the load function (had to recompile and replace the libs)
- prus_sdk/dtc_src doesn't like the dts file - even recompiled (had to use more up-to-date dtc version 1.4.0)
- after copying pru_enable-00A0.dtbo into /lib/firmware and when running sudo ./run.sh I got error: prussdrv_open open failed. The solution is to restart the BBB (hasn't been mentioned) !
After that the pruss_c example compiles works fine. Thanks again.
thanks,
Jim
I'm trying to fight with the arm to pru memory writing. Your examples work fine and now I try to use shm_read function in this way (modifying your 1st c example):
shm_write_uint32(0, 0xdeadbeef);
shm_write_uint32(4, shm_read(0));
shm_write_float(8, x);
and I get the following output:
0x206f6f54 (0.000000)
0x155e0900 (0.000000)
0x45db452b (7016.645996)
What's the reason?
I'm absolutely new for the asm and currently it is hard for me to find the problem.
I am trying to compile your sample example code using PRU C Compiler. But i'm facing the following issue,
On running ./build.sh, the script throws up error complaining about the missing top.mk file.
Error log below:
./build.sh
Makefile:6: /home/ti/ccsv6/tools/compiler//build/top.mk: No such file or directory
make: *** No rule to make target `/home/ti/ccsv6/tools/compiler//build/top.mk'. Stop.
But the ccsv6 installed doesn't have any build directory at all where your script is looking for top.mk file.Please let me know if i have missed anything and help me in solving this.
Thanks
Keshav
I have some very specific needs that seem possible but would like confirmation, if possible, before I start digging:
I need to run a long sequence of hard-real-time events (output on GPIO).
The list contains periods between outputting things on GPIO and the GPIOs to output what on.
The list would be too long to reside in the PRU memory but could be buffered by it (circular buffer?).
The main processor would have the whole list and feed it to the PRU as it runs through the list.
The main processor would need to be able to synchronize other things (send SPI data for example) with the sequence. (Or the PRU could send data over SPI but it would need to get it from the main processor)
The whole sequence could run for a few days.
I need the timing to stay "correct" down to the clock cycle (no variable latency, etc)
Os this doable on the BBB?
Thanks,
Cat
There are 2 things to consider.
First, you can use the PRU dedicated GPIOs to solve the communication realtimeness problem. It applies for the SPI.
Regarding the memory space issue, you can put your list of actions into the DDR that is accessible from both the CPU and the PRU. However, note that the DDR accesses are not realtime since the bus is shared with the CPU. In practice, I doubt this is an issue for your application ...
I am facing one strange issue while compiling my code. I downloaded ti-processor-sdk-linux-am335x-evm-01.00.00.03-Linux-x86-Install.bin from ti for my development . while compiling i am getting the following error.
rm -f
rm -f main
/opt/linux-devkit/sysroots/i686-arago-linux/usr/arm-linux-gnueabihf/bin/gcc -DSTART_ADDR=0x0000032c -Wall -O2 -mtune=cortex-a8 -march=armv7-a -I/opt/pru_sdk-master//include -c -o host_main.o host_main.c
gcc: error trying to exec 'cc1': execvp: No such file or directory
make: *** [host_main.o] Error 1
I know it is the compiler preprocessing stage for converting c file to assembly . cc1 is available in my directory but compiler is not able to include . Did anyone faced this issue or please let me know how to give the reference for this.
I am using BBB revision 3 and ubuntu 12.04 for cross platform.
Thanks
Navin
I am facing problem while linking with dtc
rm -f
rm -f main
/opt/ti/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf-gcc -DSTART_ADDR=0x0000032c -Wall -O2 -mtune=cortex-a8 -march=armv7-a -I/opt/pru_sdk-master//include -c -o host_main.o host_main.c
/opt/ti/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf-gcc -DSTART_ADDR=0x0000032c -Wall -O2 -mtune=cortex-a8 -march=armv7-a -I/opt/pru_sdk-master//include -c -o ../common/mio.o ../common/mio.c
/opt/ti/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf-gcc -static -o main host_main.o ../common/mio.o -L/opt/pru_sdk-master//lib -lprussdrv
/opt/ti/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf-strip main
/opt/pru_sdk-master//bin/dtc -@ -O dtb -o pru_enable-00A0.dtbo pru_enable-00A0.dts
/opt/pru_sdk-master//bin/dtc: 1: /opt/pru_sdk-master//bin/dtc: Syntax error: "(" unexpected
make: *** [pru_enable-00A0.dtbo] Error 2
Please let me know how to resolve this issue.
regards,
Navin
I have one really silly doubt, that I cant find pruss_c or ./build.sh file any where in your repo!! and I am not able to follow anything!! can you help me with that? I have a BBB I have installed Ti's default PRU c compiler and have downloaded your repository, but I am stuck now!! I cant find my way out.
I am completely new to this domain, I have just started off in realtime and embedded thing so my question might sound silly, pardon me for that.
Rathin
I presuppose we need CorssCompiling only if we are developing on another machine and target is different!! Is my understanding wrong?
Rathin
Though I am bit clueless, i will try finding my way,( some guidance would be helpful, though :)
Thanks a lot and hats off to such magnanimous efforts!
Rathin
you are right, cross compiling is needed only if you are on
a machine which is not the target one.
I can help you, but as you guessed it will be easier for me
to have precise questions.
Cheers !
Thank you VERY much for prompt reply.
Yes, true - I also believe in self learning, Hence let me work on it and if I get stuck I will "trouble" you :)
Thanks in advance..
I was finally able to setup the environment on my BBB. but I got stuck elsewhere, here is my status
I installed TI's PRU's cgt on BBB "ti_cgt_pru_2.1.1_armlinuxa8hf_busybox_installer.sh"
so I have all necessary headers, libs and compilers ( clpru, pasm etc).
Now I took your code repo and tried compiling the pruss_c files, using "./build.sh" but being designed for crossCompilaition, it gave me error for CGT & SDK paths, hence I manually passed parameters to my CLPRU like this "clpru --silicon_version=2 --hardware_mac=on -i/usr/lib/ -i/usr/include -c pru_hal.c".
I also tried simply compiling the code "clpru pru_main.c" (I know it sounds silly!! but I felt its worth a try)
but even after this i am not able to compile it, it says "/usr/include/features.h", line 323: fatal error: cannot open source file "bits/predefs.h"
or without argument it says " couldn't open source file 'stdint.h' "
Can you guide, where I am going wrong!
hope I am sufficiently clear, and I am really sorry If you find my query very novice, If so can you recommend me some resources as well to clear my basics as well!
Thanks a lot!
Regards
why the size of th? .text section in AM3359_PRU.cmd file is specified as 0x1000 ?
According to datasheet its size is 2 times bigger (8K). The same size is specified in cmd file for hexpru.
I guess this is an error ... Some files actually uses the whole size,
for instance:
https://github.com/deepakkarki/pruspeak/blob/master/src/pru-firmware/AM3359_PRU.cmd
Cheers,
I am trying to use your package but I am getting because of the soft float you used to build libprussdrv.a(prussdrv.o). I am using VFP and getting an error when run build.sh for pruss_c example.
How could I rebuild the binaries?
Thanks again!
And voilà. I am going to deploy to board now and see if everything went ok.
Thanks!
https://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/403440
Or search for "enable PRU Hex Utility".
This allows uio_pruss to be used out of the box with CCSv6; just drop the files on the BeagleBone and run them.
Great write-up!
Great post! Thank you so much.
I was wondering if someone can help me though...
I'm trying to get only the PRU-C compiler and i already visited the link you gave, and the compiler looks like it is doing its job but, i was wondering if i can get the latest no BETA version of it, so i've visited the C6000_Code_Generation_Tools_v8.3.1 page.
But after installation i can't find the /bin/clpru and the official pru-software-support-package looks like it depends on it or that is what i see in the Makefile of the Building Blocks.
#pru-software-support-package/examples/am335x/PRU_RPMsg_Echo_Interrupt0/Makefile $(GEN_DIR)/%.object: %.c @mkdir -p $(GEN_DIR) @echo '' @echo 'Building file: $<' @echo 'Invoking: PRU Compiler' $(PRU_CGT)/bin/clpru --include_path=$(PRU_CGT)/include $(INCLUDE) $(CFLAGS) -fe $@ $<
Does anyone knows where i can find the latest PRU-C compiler?
Does anyone know if the name of the PRU-C bin has changed?
Thanks,
