hi everyone.. i tried spectral subtraction method for removal of noise from speech signal but the sound that i hear now seems more like sound of "Alvin and Chipmunks".can someone diagnose the problem this is my code for the program.i hope you could help out clc %function [ss]=specsub1(si,fs) [s,fs]=wavread('west.wav'); %specsub(noi,fr); ti=16e-3;% desired frame increment (16 ms) of=2; % overlap factor = (fft length)/(frame increment) ri=0; if ri ni=pow2(nextpow2(ti*fs*sqrt(0.5))); else ni=round(ti*fs); % frame increment in samples end tinc=ni/fs; % true frame increment time no=round(of); % integer overlap factor nf=ni*no; % fft length w=sqrt(hamming(nf+1))'; w(end)=[]; % for now always use sqrt hamming window w=w/sqrt(sum(w(1:ni:nf).^2)); % normalize to give overall gain of 1 y=enframe(s,w,ni); yf=fft(y,nf,2); %yf=rfft(y,nf,2); yp=yf.*conj(yf); [nr,nf2]=size(yp) %noise estimation yet to be made.... [dp,ze]=estnoisem(yp,tinc); ssv=zeros(ni*(no-1),1); ypf=sum(yp,2);%what is this?? dpf=sum(dp,2); %noisy segmental noise ratio for i=1:length(yp) nsnr(i)=10*log10(ypf(i)/dpf(i)); if(nsnr(i)>=20) alpha(i)=1; elseif(nsnr(i)>=-6 && nsnr(i)<20) alpha(i)=4-(3*nsnr(i)/20); else alpha(i)=4.9; end end %for i=1:length(yp) sp_eh_sp=yp(:,:)-dp(:,:); %end beta=0.005; for i=1:size(sp_eh_sp,1) for j=1:size(sp_eh_sp,2) if(sp_eh_sp(i,j)>beta*dp(i,j)) sp_eh_sp(i,j)=yp(i,j)-alpha(i)*dp(i,j); else sp_eh_sp(i,j)=beta*dp(i,j); end end end sp_eh_sp=sqrt(sp_eh_sp); sp_eh=exp(sqrt(-1)*angle(yf)).*sp_eh_sp; se=ifft(sp_eh,nf,2).*repmat(w,nr,1); % se=(irfft((sp_eh_sp).',nf).').*repmat(w,nr,1); ss=zeros(ni*(nr+no-1),no); % space for overlapped output speech ss(1:ni*(no-1),end)=ssv; for i=1:no nm=nf*(1+floor((nr-i)/no)); % number of samples in this set ss(1+(i-1)*ni:nm+(i-1)*ni,i)=reshape(se(i:no:nr,:)',nm,1); end ss=sum(ss,2); %s=sum(abs(s),2) wavplay(abs(ss),fs) Thanks Khurram Hameed
something went wrong
Started by ●July 16, 2008
