Problem with IFFT, any idea?
Started by rapidiablo ●July 17, 2008
Hi everybody... i am new in signal processing.
something about me... i am a student of software Engineering, My name is
Juan and i live in Argentina.
I am migrating one application developed in VEE (Agilent) to c++. This is
my new task in my work. This application analyzes signals and then... use
that info to set some alarms..  Nothing complicated... so far..
everything goes fine.. until i have to use ifft. I did make a fft
algorithm to do everything... but when i do the ifft... the output data
from VEE (agilent) was not the same as my algorithm. So... I decide to
implement FFTW. And i have the same problem...
i have this input data. (size = 2048)
     Agilent(VEE)                      c++
magnitude     phase
    0        ,     @0              0      ,    0
    0        ,     @0              0      ,    0
    0        ,     @0              0      ,    0
    0        ,     @0              0      ,    0
    0.276  ,     @121.5        0.276 ,    121.5
    0.2061,     @-72.03       0.2061,   -72.03
    0        ,     @0              0       ,    0
    0        ,     @0              0      ,    0
    0        ,     @0              0      ,    0
    0        ,     @0              0      ,    0
and the output data from the VEE (agilent)
-7.860034643685586E-005
-7.871299096183408E-005
-7.88070606286872E-005
-7.888302098921511E-005
-7.894133976812804E-005
-7.898248647698485E-005
-7.900693202945827E-005
-7.901514835816201E-005
-7.900760803327236E-005
-7.898478388317609E-005
-7.894714861737379E-005
-7.889517445186702E-005
-7.882933273725408E-005
-7.875009358975982E-005
-7.865792552541923E-005
-7.855329509763516E-005
-7.843666653832641E-005
and this is the output from c++ (FFTW)
0: 0.000235391 : 0.0241332
1: -0.000100984 : 0.0241359
2: -0.000437429 : 0.0241348
3: -0.000773924 : 0.0241297
4: -0.00111045 : 0.0241208
5: -0.00144697 : 0.024108
6: -0.00178348 : 0.0240913
I think that could be the type of the input data... because in agilent is
a waveform. And in my c++ application is real data..
In/out (FFTW)
data=(fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * (SIZE/2+1) );
ifft_result=(fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * (SIZE)
I am relative new in the Signal Processing... so i would need some help...
and if you know some books.. And excuse me for my English :D
have a nice day...:cool:
rapidiablo wrote:
> Hi everybody... i am new in signal processing. > > something about me... i am a student of software Engineering, My name is > Juan and i live in Argentina. > > I am migrating one application developed in VEE (Agilent) to c++. This is > my new task in my work. This application analyzes signals and then... use > that info to set some alarms.. Nothing complicated... so far.. > > everything goes fine.. until i have to use ifft. I did make a fft > algorithm to do everything... but when i do the ifft... the output data > from VEE (agilent) was not the same as my algorithm. So... I decide to > implement FFTW. And i have the same problem... > > i have this input data. (size = 2048) > > Agilent(VEE) c++ > > magnitude phase > 0 , @0 0 , 0 > 0 , @0 0 , 0 > 0 , @0 0 , 0 > 0 , @0 0 , 0 > 0.276 , @121.5 0.276 , 121.5 > 0.2061, @-72.03 0.2061, -72.03 > 0 , @0 0 , 0 > 0 , @0 0 , 0 > 0 , @0 0 , 0 > 0 , @0 0 , 0 > ... ... ... ... > > and the output data from the VEE (agilent) > > -7.860034643685586E-005 > -7.871299096183408E-005 > -7.88070606286872E-005 > -7.888302098921511E-005 > -7.894133976812804E-005 > -7.898248647698485E-005 > -7.900693202945827E-005 > -7.901514835816201E-005 > -7.900760803327236E-005 > -7.898478388317609E-005 > -7.894714861737379E-005 > -7.889517445186702E-005 > -7.882933273725408E-005 > -7.875009358975982E-005 > -7.865792552541923E-005 > -7.855329509763516E-005 > -7.843666653832641E-005 > .. > > and this is the output from c++ (FFTW) > > 0: 0.000235391 : 0.0241332 > 1: -0.000100984 : 0.0241359 > 2: -0.000437429 : 0.0241348 > 3: -0.000773924 : 0.0241297 > 4: -0.00111045 : 0.0241208 > 5: -0.00144697 : 0.024108 > 6: -0.00178348 : 0.0240913 > .. > > I think that could be the type of the input data... because in agilent is > a waveform. And in my c++ application is real data.. > > In/out (FFTW) > data=(fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * (SIZE/2+1) ); > > ifft_result=(fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * (SIZE) > ); > > I am relative new in the Signal Processing... so i would need some help... > and if you know some books.. And excuse me for my English :D > > have a nice day...:cool: > >
I suspect two things: First, everyone likes to scale their FFT and IFFT algorithms differently. Each one is the best -- just ask the author. So the fact that they're scaled differently is no big surprise. Check to see if they're off by 2048, 2048^2, or sqrt(2048), or any of those three with a factor of pi thrown in. Second, the fact that your Agilent program gives back a single column of numbers implies that it's a real FFT. If you're sticking your data into a complex FFT then you'd get back complex results, which isn't what you're looking for. See if taking these notions into consideration helps. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
To be clear, the above is the data you need to ifft, so you have a complex array in C++ that looks like data = 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 -0.14420960 : 0.23532869 0.06358576 : -0.19604607 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 ... If the array is conjugate symmetric it will finish like this: ... 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.06358576 : 0.19604607 -0.14420960 : -0.23532869 0.00000000 : 0.00000000 0.00000000 : 0.00000000 0.00000000 : 0.00000000 With the conjugate symmetry shown above, a 2048-point ifft in scipy (a python package that uses either FFTPACK or FFTW) outputs the following: -7.87342198e-05 : -1.43836172e-12 -7.86143723e-05 : -1.44809333e-12 -7.84881940e-05 : -1.45767790e-12 ... -7.90531139e-05 : -1.40828912e-12 -7.89538571e-05 : -1.41845944e-12 -7.88474702e-05 : -1.42848388e-12 which agrees close enough with your VEE result for my money.
Are you sure you stored your data properly in the array and are setting up your fftw_plan properly? Why is one array SIZE/2+1 in length while the other is SIZE? They should both have 2048 elements, no? (well, 4096 doubles, counting the real/imaginary components separately) A quick Google search pulled up this tutorial on FFTW: http://www-cecpv.u-strasbg.fr/Documentations/FFTW/v3.0.1/Complex-One-Dimensional-DFTs.html#Complex%20One-Dimensional%20DFTs By the way, you should be able to reinterpret_cast a C++ complex<double> * rather than use fftw_malloc. Both should just be a 2048x2 array of doubles. For example: const int SIZE = 2048; complex<double> *data = new complex<double>[SIZE]; complex<double> *ifft_result = new complex<double>[SIZE]; // ... fftw_plan p; p = fftw_plan_dft_1d( SIZE, reinterpret_cast<fftw_complex*>(data), reinterpret_cast<fftw_complex*>(ifft_result), FFTW_BACKWARD, FFTW_ESTIMATE); fftw_execute(p); // ... delete[] data; delete[] ifft_result;
The Scientist and Engineer's Guide to DSP, a free online book, might be just what you need: http://www.dspguide.com/pdfbook.htm There's also the dspGuru site: http://www.dspguru.com -Eric
Hi everybody again!!  and thanx! everyone who have the time to help me..
Tim Wescott: The first thing you suspect may be my problem... but i dont
know how to determine what scale use Agilent VEE ??..
by the second thought.. I don&acute;t know how to do it with the fftw library.
May be this is my problem... but i don't know how to do it with fftw
library... which method i have to use.. to calculate fft with complex input
and expect real output?. If you know!!  PLEASE HELP!!
eric: thanks for your post!!  you did well!! but... i cant get the result
that i expect.. :S
How do you get this results?
by the way... i use those results in my ifft program and... i have
different output than yours. So may be my code wrong?? Here is the code...
And in the bottom i put the link to the files. CH00 and CH01 are the input
to my program.
IN IFFT(agilent).txt and IFFT out (agilent).txt: are the input to ifft in
agilent and the output from it.
Note: Agilent make the same calculations that my program... and have the
same result until ifft. After ifft, everything goes to hell. :(
CODE:
#include <fftw3.h>
#include <cmath>
#include <iostream>
#include <fstream>
#include <conio.h>
#define SIZE 2048
#define span 4
#define fcorte 1.4
using namespace std;
void mag (fftw_complex *result, long asize);
void phase ( fftw_complex *result, long asize);
void magpha ( fftw_complex *result, long asize);
long mapi ( double vspan, double asize);
void dco (fftw_complex *result, fftw_complex *result2, long vmapi);
void alloc ( fftw_complex *result, long asize);
void fsave (fftw_complex *result, long asize);
double pha[1+(SIZE/2)];
double magn[1+(SIZE/2)];
long hifrec, lowfrec;
int main( int argc, char** argv )
    double asize,vspan,vmapi;
    char tmp [100];
    fftw_complex    *data, *fft_result, *ifft_result,*data2, *fft_result2,
*ifft_result2;
    fftw_plan       plan_forward, plan_backward, plan_forward2,
plan_backward2;
    int             i,n;
                                                           /* IN/OUT */
data=( fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * SIZE );
data2=( fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * SIZE );
fft_result=( fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * SIZE
fft_result2=( fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * SIZE
ifft_result=( fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * SIZE
ifft_result2=( fftw_complex* ) fftw_malloc( sizeof( fftw_complex ) * SIZE
                                                           /* make plans
    plan_forward  = fftw_plan_dft_1d( SIZE, data, fft_result,
FFTW_FORWARD, FFTW_ESTIMATE );
    plan_forward2 = fftw_plan_dft_1d( SIZE, data2, fft_result2,
    plan_backward = fftw_plan_dft_1d( SIZE, fft_result, ifft_result,
FFTW_BACKWARD, FFTW_ESTIMATE );
    plan_backward2= fftw_plan_dft_1d( SIZE, fft_result2, ifft_result2,
                                                      /* Read CH1 & CH2*/
    ifstream archivo;
    archivo.open ("ch00.txt", ifstream::in);
    if (archivo.is_open())
    n = 0;
    while (SIZE>=n)
       //while (!archivo.eof()
     archivo.getline (tmp,100);
     data[n][0] = atof (tmp);
     data[n][1] = 0.0;
     n++;
     else
      cout << "Error al abrir el archivo";
      archivo.close ();
    ifstream archiv;
    archiv.open ("ch01.txt", ifstream::in);
    if (archiv.is_open())
    n = 0;
    while (SIZE>=n)
     archiv.getline (tmp,100);
     data2[n][0] = atof (tmp);
     data2[n][1] = 0.0;
     n++;
     else
      archiv.close ();
                                                   /* print initial data
    for( i = 0 ; i < (SIZE) ; i++ ) {
      cout << i << ": " << data[i][0] << " : "<< data[i][1] <<endl;
    getch();
      cout << i << ": " << data2[i][0] << " : "<< data2[i][1] <<endl;
    getch();
                                                         /*execute ffts*/
    fftw_execute( plan_forward ); //Ejecuta el plan A
    fftw_execute( plan_forward2); //Ejecuta el plan A.1
                                                    /* print fft result
    for( i = 0 ; i < SIZE/2+1 ; i++ ) {
      cout << i << ": " << fft_result[i][0] << " : " << fft_result[i][1]
<< endl;
    getch();
      cout << i << ": " << fft_result2[i][0] << " : " << fft_result2[i][1]
<< endl;
    getch();
    asize=SIZE/2+1;
    mag (fft_result,asize);
    phase(fft_result,asize);
    magpha(fft_result,asize);
    mag (fft_result2,asize);
    phase(fft_result2,asize);
    magpha(fft_result2,asize);
    for( i = 0 ; i < asize ; i++ ) {
<< endl;
    getch();
<< endl;
    getch();
    vspan = asize/span;  /*Calcula el Stop del Star/Stop del agilent*/
    vmapi = mapi(vspan,asize);
    dco (fft_result,fft_result2,vmapi);
    alloc(fft_result,asize);
    alloc(fft_result2,asize);
    fsave(fft_result,asize);
<< endl;
    getch();
<< endl;
    getch();
    fftw_execute( plan_backward );  //Ejecuta el plan B
    fftw_execute( plan_backward2 ); //Ejecuta el plan B.1
                                                   /* print ifft result
    for( i = 0 ; i < SIZE ; i++ ) {
        cout << i << ": " << ifft_result[i][0] / SIZE << " : " <<
fft_result[i][1] << endl;
    getch();
        cout << i << ": " << ifft_result2[i][0] / SIZE << " : " <<
fft_result2[i][1] << endl;
    getch();
                                                         /* free memory
    fftw_destroy_plan( plan_forward );
    fftw_destroy_plan( plan_backward );
    fftw_destroy_plan( plan_forward2);
    fftw_destroy_plan( plan_backward2);
    fftw_free( data );
    fftw_free( fft_result );
    fftw_free( ifft_result );
    fftw_free( data2 );
    fftw_free( fft_result2 );
    fftw_free( ifft_result2 );
    return 0;
//////////////////////////////////////////////////PHASE////////////////////////
/* this function calculate phase.*/
long n;
double atan;
for ( n = 0; n < asize ; n++ )
 atan=atan2(result[n][1], result[n][0]);
 pha[n]=atan*(180/3.14159265);
//////////////////////////////////////////////////MAGNITUD////////////////
/* this function calculate  sqrt(a^2+b^2).*/
long n;
magn[n]=sqrt(pow(result[n][0],2) + pow(result[n][1],2));
//////////////////////////////////////////////MAG-PHASE///////////////////
/*this function use mag and phase to make a new array with magnitude and
phase data*/
long n;
double atan;
    result[n][0] = magn[n];
    result[n][1] = pha[n];
///////////////////////////////MAP A INDEX//////////////////////////
double resultado, intpart, fractpart;
resultado = fcorte*(asize/vspan);
fractpart = modf(resultado,&intpart);
if (fractpart>0.5)
intpart = intpart + 1;
return intpart;
/////////////////////////////////////////CUT///////////////////////////////////
/*this function and "map a index" finds hifrec and lowfrec. With this
values i set up the new array*/
long a, pico;
int hifrec1, hifrec2, lowfrec1, lowfrec2, n, flag;
//maxIndex([x[a-1],x[a],x[a+1]])+a-1
if (result[vmapi-1][0]>=result[vmapi][0]) a=0;
else a=1;
if (result[vmapi][0]>=result[vmapi+1][0]) a=1;
else a=2;
pico = a + vmapi - 1;
hifrec1 = pico;
hifrec2 = pico;
lowfrec1 = pico;
lowfrec2 = pico;
n = pico;
flag = 0;
while (flag==0)
 if (result[n+1][0] <= result[n][0]) n=n+1;
 else
  lowfrec1=n;
  flag=1;
flag=0;
n = pico;
while (flag==0)
 if (result2[n+1][0] <= result2[n][0]) n=n+1;
 else
  lowfrec2=n;
  flag=1;
flag = 0;
n = pico;
while (flag==0)
 if (result[n-1][0] <= result[n][0])
  n=n-1;
  if (n==0)
   hifrec1=n;
   flag=1;
 else
  hifrec1=n;
  flag=1;
flag = 0;
n = pico;
while (flag==0)
 if (result2[n-1][0] <= result2[n][0])
  n=n-1;
  if (n==0)
   hifrec2=n;
   flag=1;
 else
  hifrec2=n;
  flag=1;
if (lowfrec1>lowfrec2) lowfrec=lowfrec2;
else lowfrec=lowfrec1;
if (hifrec1>hifrec2) hifrec=hifrec1;
else hifrec=hifrec2;
//////////////////////////////ALLOC////////////////////////////////
/*this function make a new array with all values at 0.0 and copy the
hifrec and lowfrec from the original fft array (magnitude,phase)*/
 int n=0;
 double tmp1,tmp2;
 while (asize>=n)
  if (n==hifrec){}
  else
      if (n==lowfrec){}
      else
      result[n][0] = 0.0;
      result[n][1] = 0.0;
  n=n+1;
 tmp1=result[hifrec][0];
 tmp2=result[hifrec][1];
 result[hifrec][0]=result[lowfrec][0];
 result[hifrec][1]=result[lowfrec][1];
 result[lowfrec][0]=tmp1;
 result[lowfrec][1]=tmp2;*/
//////////////////////////////SAVE////////////////////////
int n;
ofstream fsalida;
fsalida.open("salida.TXT");
    fsalida << result[n][0] << "," << result[n][1] << endl;
fsalida.close();
Files:
IN IFFT(agilent).txt:
http://www.4shared.com/file/55678120/d91bbce1/IN_IFFT_agilent_.html
http://www.4shared.com/file/55678126/307819d4/IFFT_out__agilent_.html
CHO1:
http://www.4shared.com/file/55678122/3715ddcd/CH01.html
CH00:
http://www.4shared.com/file/55678124/de7678f8/CH00.html
Hope you understand my English and THANKS FOR EVERY HELP... I NEED IT...!
Have a nice day!!
eric!! now i know how you get this results
You FFT them.. :)
But.. i cant get the results form agilen... :(
HELP!!!!
thanxs!
I forgot some info about agilent vee... This info about the input, could be
my problem??
Type: Spectrum
shape: Array 1D
mapping: LIN:0 ... 256.25
Thanks again and again..
On Jul 18, 11:08&#4294967295;am, "rapidiablo" <juan0...@hotmail.com> wrote:
> eric!! now i know how you get this results > > &#4294967295;0.00000000 : &#4294967295;0.00000000 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > -0.14420960 : &#4294967295;0.23532869 > &#4294967295;0.06358576 : -0.19604607 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > &#4294967295;0.00000000 : &#4294967295;0.00000000 > > You FFT them.. :) > > But.. i cant get the results form agilen... :( > > HELP!!!! > > thanxs!
Those were your numbers. I simply took the amplitude/phase data you gave me and recreated the array so I could test it using the ifft in scipy. Now I have the precise numbers from IN IFFT(agilent).txt: fft_result = 0: 0.00000000 : 0.00000000 1: 0.00000000 : 0.00000000 2: 0.00000000 : 0.00000000 3: 0.00000000 : 0.00000000 4: 0.00000000 : 0.00000000 5: 0.00000000 : 0.00000000 6:-0.14404949: 0.23546151 7: 0.06356274 : -0.19600286 8: 0.00000000 : 0.00000000 ... 2040: 0.00000000 : 0.00000000 2041: 0.06356274 : 0.19600286 2042:-0.14404949: -0.23546151 2043: 0.00000000 : 0.00000000 2044: 0.00000000 : 0.00000000 2045: 0.00000000 : 0.00000000 2046: 0.00000000 : 0.00000000 2047: 0.00000000 : 0.00000000 ifft_result: -7.86003464e-05 : 0.00000000e+00 -7.87129910e-05 : -4.06575815e-20 -7.88070606e-05 : -1.35525272e-20 ... -7.81463489e-05 : -3.72112162e-19 -7.83174838e-05 : -3.86816124e-19 -7.84686641e-05 : -4.15979204e-19 For reference, these are the corresponding values from IFFT out (agilent).txt : -7.860034643685586E-005 -7.871299096183408E-005 -7.88070606286872E-005 ... -7.814634892479629E-005 -7.831748379365282E-005 -7.846866406201685E-005 Unsurprisingly, they agree, which means the problem is in the C code.
ERIC!!!  YOU ARE A GENIUS!!! I DON&acute;T KNOW HOW TO THANKS YOU!!! ... The
answer of my problem was in front of me !!!  and i dint see it!!
when you say:
data =
following:
my problem was that i just have an array of the half of the size and i
never conjugate the values!!! so i have a 1025 arry in!!  with the half of
the data!!!  in your last post!!  i realized... what you told me in the
first... (in the beginning i belive you just turn the values... for alien
reason.. jeje) because you put the numbers of the elements (index).
=2E..
So... that was the problem!!! THANKS MEN!! ...
Sorry about my English again... i do the best i can!! jeje..
Thxk every body!! :) xD. (im happy)
On Jul 18, 10:47&#4294967295;am, "rapidiablo" <juan0...@hotmail.com> wrote:
> &#4294967295; &#4294967295; vspan = asize/span; &#4294967295;/*Calcula el Stop del Star/Stop del agilent*/ > &#4294967295; &#4294967295; vmapi = mapi(vspan,asize); > &#4294967295; &#4294967295; dco (fft_result,fft_result2,vmapi);
In the above code you're calculating the global variables hifrec and lowfrec, right?
> &#4294967295; &#4294967295; alloc(fft_result,asize); > &#4294967295; &#4294967295; alloc(fft_result2,asize);
Then you zero out everything but those two frequencies in the alloc function, right? But you only do that to elements 0 through 1025, leaving 1026 to 2047 unmodified. As an aside, I think your while loop exit condition in alloc() should have been (asize>n) rather than (asize>=n) since asize equals 1025. Element 0 is DC (0 Hz), and element 1024 is half the sampling frequency (digital frequency pi/2). For a real signal with 2048 sample points, elements 1025-2047 of the DFT (fft) are the conjugated mirror of elements 1-1023, so they don't provide any extra information, which is why they're often ignored.
> &#4294967295; &#4294967295; fftw_execute( plan_backward ); &#4294967295;//Ejecuta el plan B > &#4294967295; &#4294967295; fftw_execute( plan_backward2 ); //Ejecuta el plan B.1
Then you ifft your modified results. I think I see your problem. You need to zero out the conjugate symmetric frequencies in the 1025-2047 range, except the two at (SIZE - hifrec) and (SIZE - lowfrec). If you don't your result will not match VEE and will be complex valued. I hope this solves your problem. -Eric
I already did that... everything works just fine!!! thanks eric!!.. you are
a pro!!  jeje!
>On Jul 18, 10:47=A0am, "rapidiablo" <juan0...@hotmail.com> wrote: > >> =A0 =A0 vspan =3D asize/span; =A0/*Calcula el Stop del Star/Stop del
agil=
>ent*/ >> =A0 =A0 vmapi =3D mapi(vspan,asize); >> =A0 =A0 dco (fft_result,fft_result2,vmapi); > >In the above code you're calculating the global variables hifrec and >lowfrec, right? > >> =A0 =A0 alloc(fft_result,asize); >> =A0 =A0 alloc(fft_result2,asize); > >Then you zero out everything but those two frequencies in the alloc >function, right? But you only do that to elements 0 through 1025, >leaving 1026 to 2047 unmodified. > >As an aside, I think your while loop exit condition in alloc() should >have been (asize>n) rather than (asize>=3Dn) since asize equals 1025. >Element 0 is DC (0 Hz), and element 1024 is half the sampling >frequency (digital frequency pi/2). For a real signal with 2048 sample >points, elements 1025-2047 of the DFT (fft) are the conjugated mirror >of elements 1-1023, so they don't provide any extra information, which >is why they're often ignored. > >> =A0 =A0 fftw_execute( plan_backward ); =A0//Ejecuta el plan B >> =A0 =A0 fftw_execute( plan_backward2 ); //Ejecuta el plan B.1 > >Then you ifft your modified results. > >I think I see your problem. You need to zero out the conjugate >symmetric frequencies in the 1025-2047 range, except the two at (SIZE >- hifrec) and (SIZE - lowfrec). If you don't your result will not >match VEE and will be complex valued. I hope this solves your >problem. > >-Eric >
