Hi all: I want to implement a Decimation with D=6 to decimate from 5Mhz to 833Khz, but all the 833Khz content is with interest, so the priori low-pass filter seem to have a very sharp transition width, which is hard to implement. so anyone got some ideas?
How to implement an efficient ALL-PASS decimation?
Started by ●July 19, 2008
Reply by ●July 19, 20082008-07-19
liubenyuan wrote:> Hi all: > I want to implement a Decimation with D=6 to decimate from 5Mhz to > 833Khz, but all the 833Khz content is with interest, so the priori > low-pass filter seem to have a very sharp transition width, which is > hard to implement. so anyone got some ideas?There is no silver bullet. The reasonable upper band for the decimation filter is no higher then 0.8...0.9 of Nyquist. So, with 833kHz sample rate the cutoff will be at 375kHz. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
liubenyuan wrote:> Hi all: > I want to implement a Decimation with D=6 to decimate from 5Mhz to > 833Khz, but all the 833Khz content is with interest, so the priori > low-pass filter seem to have a very sharp transition width, which is > hard to implement. so anyone got some ideas?You want a signal that's not oversampled at all. That's bad news. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
liubenyuan wrote:> Hi all: > I want to implement a Decimation with D=6 to decimate from 5Mhz to > 833Khz, but all the 833Khz content is with interest, so the priori > low-pass filter seem to have a very sharp transition width, which is > hard to implement. so anyone got some ideas? > > >Use a long comb filter first, taking advantage of the fact that most of the coefficients are zero. Then use a relatively short LP filter. All it has to do is to attenuate the hgher-order responses, so can have a fairly wide transition band. Then decimate. Regards, John
