Hi all,I am a newer in DSP. I have a frequency resolution problem, need your suggestions and comments. My problem depends on frequency resolution. Basically I need the frequency resolution around 0.01-0.02 at least to make the error smaller. But my useful signal is roughly 10s which means the frequency resolution is 0.1Hz, this is far away from my requirement. Does anybody know if there is method can solve this issue? One of my friends suggested me to patch the "good connected signal" from the original signal to the end of the time series to make the signal very long. I don't think this will work, but I don't know how to argue with him. Anybody can give me a theory for this so that I can argue with him. I also want to try use longer time series to get the frequency fM, then for the shorter time series I can extract the frequency component for fM. The problem is there is no frequency from FFT exactly equal to fM. So how can I extract the component from the shorter time series based on fM calculated by longer time series. I know we can interpolate by zero-padding, But I feel I can not extract the exact component from this. Hope I made my problem clear. Thank you all
frequency resolution issue
Started by ●July 21, 2008
Reply by ●July 22, 20082008-07-22
On Jul 21, 5:50�pm, "biantai" <wrxd...@gmail.com> wrote:> Hi all,I am a newer in DSP. I have a frequency resolution problem, need > your suggestions and comments. > > My problem depends on frequency resolution. Basically I need the frequency > resolution around 0.01-0.02 at least to make the error smaller. But my > useful signal is roughly 10s which means the frequency resolution is 0.1Hz, > this is far away from my requirement. Does anybody know if there is method > can solve this issue?Frequency resolution depends not only on the length of the "useful signal" but also on the signal-to-noise ratio. In the pure zero noise case, you can get a perfect frequency measurement with only 3 (non-aliased) sample points. And in a high noise situation, you may need a lot more data just to determine whether your signal is present, much less measure its frequency to even 1 Hz. There are lots of frequency estimation methods which may work for signal-to-noise ratios within certain ranges. I have a big list of various estimation methods, some of which may or may not be useful, on one of my web pages: http://www.nicholson.com/rhn/dsp.html IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
>On Jul 21, 5:50=A0pm, "biantai" <wrxd...@gmail.com> wrote: >> Hi all,I am a newer in DSP. I have a frequency resolution problem,need>> your suggestions and comments. >> >> My problem depends on frequency resolution. Basically I need thefrequenc=>y >> resolution around 0.01-0.02 at least to make the error smaller. But my >> useful signal is roughly 10s which means the frequency resolution is0.1H=>z, >> this is far away from my requirement. Does anybody know if there ismetho=>d >> can solve this issue? > >Frequency resolution depends not only on the length of the >"useful signal" but also on the signal-to-noise ratio. In the >pure zero noise case, you can get a perfect frequency measurement >with only 3 (non-aliased) sample points. And in a high noise >situation, you may need a lot more data just to determine >whether your signal is present, much less measure its frequency >to even 1 Hz. > >There are lots of frequency estimation methods which may work >for signal-to-noise ratios within certain ranges. I have a big >list of various estimation methods, some of which may or may not >be useful, on one of my web pages: > http://www.nicholson.com/rhn/dsp.html > > >IMHO. YMMV. >-- >rhn A.T nicholson d.0.t C-o-M >============ Thank you Ron for your response. I will check your site to see what method is good for me. By the way, how do I know signal/noise? basically, I measure the wave propagating into ice in a wave tank. Because I only concern about the beginning part. So there is no reflection but the amplitude may change with time and assume only one frequency generated.
On 22 Jul, 02:50, "biantai" <wrxd...@gmail.com> wrote:> Hi all,I am a newer in DSP. I have a frequency resolution problem, need > your suggestions and comments. > > My problem depends on frequency resolution. Basically I need the frequency > resolution around 0.01-0.02 at least to make the error smaller. But my > useful signal is roughly 10s which means the frequency resolution is 0.1Hz, > this is far away from my requirement. Does anybody know if there is method > can solve this issue?It depends on the exact problem you try to solve. "Resolution" can mean two things, either the ability to find the frequeny of *one* sinusoidal with high accuracy, or to separate *two* sinusoidals at similar frequencies. The available solution methods depend on what you try to do and why.> One of my friends suggested me to patch the "good connected signal" from > the original signal to the end of the time series to make the signal very > long. I don't think this will work, but I don't know how to argue with him. > Anybody can give me a theory for this so that I can argue with him.It's an interesting exercise if you try it, but it will not solve your problem since you do not introduce new information to the signal. Try this in matlab: s=randn(100,1); stem((0:length(s)-1)/length(s),abs(fft(s)),'b'); hold on S=[s;s]; stem((0:length(S)-1)/length(S),abs(fft(S))/2,'r') It should be no surprise that you get all the same coefficients in the extended signal as in the original signal (save a scale factor). Since you did not add any new information, the 'extra' coefficients in the spectrum of the extended sequence are 0.> I also want to try use longer time series to get the frequency fM, then > for the shorter time series I can extract the frequency component for fM.So what you *really* want to do is to decode an FM signal?> The problem is there is no frequency from FFT exactly equal to fM. So how > can I extract the component from the shorter time series based on fM > calculated by longer time series. I know we can interpolate by > zero-padding, But I feel I can not extract the exact component from this. > > Hope I made my problem clear. Thank you allNo, you haven't. What do you try to do? Estimate the frequency of one sinusoidal? Separate two sinusoidals? Demodulate an FM signal? Rune
>On 22 Jul, 02:50, "biantai" <wrxd...@gmail.com> wrote: >> Hi all,I am a newer in DSP. I have a frequency resolution problem,need>> your suggestions and comments. >> >> My problem depends on frequency resolution. Basically I need thefrequency>> resolution around 0.01-0.02 at least to make the error smaller. But my >> useful signal is roughly 10s which means the frequency resolution is0.1Hz,>> this is far away from my requirement. Does anybody know if there ismethod>> can solve this issue? > >It depends on the exact problem you try to solve. "Resolution" can >mean >two things, either the ability to find the frequeny of *one* >sinusoidal >with high accuracy, or to separate *two* sinusoidals at similar >frequencies. > >The available solution methods depend on what you try to do and why. > >> One of my friends suggested me to patch the "good connected signal"from>> the original signal to the end of the time series to make the signalvery>> long. I don't think this will work, but I don't know how to argue withhim.>> Anybody can give me a theory for this so that I can argue with him. > >It's an interesting exercise if you try it, but it will not solve >your >problem since you do not introduce new information to the signal. > >Try this in matlab: > >s=randn(100,1); >stem((0:length(s)-1)/length(s),abs(fft(s)),'b'); >hold on >S=[s;s]; >stem((0:length(S)-1)/length(S),abs(fft(S))/2,'r') > >It should be no surprise that you get all the same coefficients >in the extended signal as in the original signal (save a scale >factor). Since you did not add any new information, the 'extra' >coefficients in the spectrum of the extended sequence are 0. > >> I also want to try use longer time series to get the frequency fM,then>> for the shorter time series I can extract the frequency component forfM.> >So what you *really* want to do is to decode an FM signal? > >> The problem is there is no frequency from FFT exactly equal to fM. Sohow>> can I extract the component from the shorter time series based on fM >> calculated by longer time series. I know we can interpolate by >> zero-padding, But I feel I can not extract the exact component fromthis.>> >> Hope I made my problem clear. Thank you all > >No, you haven't. What do you try to do? Estimate the frequency of >one sinusoidal? Separate two sinusoidals? Demodulate an FM signal? > >Rune >===============Thank you Rune, To clarify my problem, I want to estimate accurately the frequency of one sinusoidal, not separate two sinusoidals because there is only one main frequency in my signal. My problem is strongly depends on the frequency resolution, which means small frequency change will introduce big error in my problem. basically, I need the resolution about 0.01-0.02Hz. The wave signal I recorded is about 40-50s. But because it is hard to separate the reflected wave and incident wave for my situation, I need use only the beginning part to analysis (7s to 10s). So my second question is trying get the frequency from the whole signal which give the resolution about 0.02Hz, then use this frequency(lets say fM) to analysis the beginning part. Since 7s to 10s signal may not give extact fM component, how can I extract the fM component from this short period. Ray
On 22 Jul, 19:11, "biantai" <wrxd...@gmail.com> wrote:> >On 22 Jul, 02:50, "biantai" <wrxd...@gmail.com> wrote: > >> Hi all,I am a newer in DSP. I have a frequency resolution problem, > need > >> your suggestions and comments. > > >> My problem depends on frequency resolution. Basically I need the > frequency > >> resolution around 0.01-0.02 at least to make the error smaller. But my > >> useful signal is roughly 10s which means the frequency resolution is > 0.1Hz, > >> this is far away from my requirement. Does anybody know if there is > method > >> can solve this issue? > > >It depends on the exact problem you try to solve. "Resolution" can > >mean > >two things, either the ability to find the frequeny of *one* > >sinusoidal > >with high accuracy, or to separate *two* sinusoidals at similar > >frequencies. > > >The available solution methods depend on what you try to do and why. > > >> One of my friends suggested me to patch the "good connected signal" > from > >> the original signal to the end of the time series to make the signal > very > >> long. I don't think this will work, but I don't know how to argue with > him. > >> Anybody can give me a theory for this so that I can argue with him. > > >It's an interesting exercise if you try it, but it will not solve > >your > >problem since you do not introduce new information to the signal. > > >Try this in matlab: > > >s=randn(100,1); > >stem((0:length(s)-1)/length(s),abs(fft(s)),'b'); > >hold on > >S=[s;s]; > >stem((0:length(S)-1)/length(S),abs(fft(S))/2,'r') > > >It should be no surprise that you get all the same coefficients > >in the extended signal as in the original signal (save a scale > >factor). Since you did not add any new information, the 'extra' > >coefficients in the spectrum of the extended sequence are 0. > > >> I also want to try use longer time series to get the frequency fM, > then > >> for the shorter time series I can extract the frequency component for > fM. > > >So what you *really* want to do is to decode an FM signal? > > >> The problem is there is no frequency from FFT exactly equal to fM. So > how > >> can I extract the component from the shorter time series based on fM > >> calculated by longer time series. I know we can interpolate by > >> zero-padding, But I feel I can not extract the exact component from > this. > > >> Hope I made my problem clear. Thank you all > > >No, you haven't. What do you try to do? Estimate the frequency of > >one sinusoidal? Separate two sinusoidals? Demodulate an FM signal? > > >Rune > >=============== > > Thank you Rune, > To clarify my problem, I want to estimate accurately the frequency of one > sinusoidal, not separate two sinusoidals because there is only one main > frequency in my signal. My problem is strongly depends on the frequency > resolution, which means small frequency change will introduce big error in > my problem. basically, I need the resolution about 0.01-0.02Hz.You need 50-100 s of data to get that.> The wave signal I recorded is about 40-50s. But because it is hard to > separate the reflected wave and incident wave for my situation, I need use > only the beginning part to analysis (7s to 10s). So my second question is > trying get the frequency from the whole signal which give the resolution > about 0.02Hz, then use this frequency(lets say fM) to analysis the > beginning part. Since 7s to 10s signal may not give extact fM component, > how can I extract the fM component from this short period.What type of signal is this? You talk about 'pulse' and 'reflection'. Those are usually transients, meaning that frequency estimation is more or less meaningless since you transmitted the signal yourself and - presumably - already know what you sent. Could you please decribe the experiment and application? Rune
>On 22 Jul, 19:11, "biantai" <wrxd...@gmail.com> wrote: >> >On 22 Jul, 02:50, "biantai" <wrxd...@gmail.com> wrote: >> >> Hi all,I am a newer in DSP. I have a frequency resolution problem, >> need >> >> your suggestions and comments. >> >> >> My problem depends on frequency resolution. Basically I need the >> frequency >> >> resolution around 0.01-0.02 at least to make the error smaller. Butmy>> >> useful signal is roughly 10s which means the frequency resolutionis>> 0.1Hz, >> >> this is far away from my requirement. Does anybody know if there is >> method >> >> can solve this issue? >> >> >It depends on the exact problem you try to solve. "Resolution" can >> >mean >> >two things, either the ability to find the frequeny of *one* >> >sinusoidal >> >with high accuracy, or to separate *two* sinusoidals at similar >> >frequencies. >> >> >The available solution methods depend on what you try to do and why. >> >> >> One of my friends suggested me to patch the "good connected signal" >> from >> >> the original signal to the end of the time series to make thesignal>> very >> >> long. I don't think this will work, but I don't know how to arguewith>> him. >> >> Anybody can give me a theory for this so that I can argue with him. >> >> >It's an interesting exercise if you try it, but it will not solve >> >your >> >problem since you do not introduce new information to the signal. >> >> >Try this in matlab: >> >> >s=randn(100,1); >> >stem((0:length(s)-1)/length(s),abs(fft(s)),'b'); >> >hold on >> >S=[s;s]; >> >stem((0:length(S)-1)/length(S),abs(fft(S))/2,'r') >> >> >It should be no surprise that you get all the same coefficients >> >in the extended signal as in the original signal (save a scale >> >factor). Since you did not add any new information, the 'extra' >> >coefficients in the spectrum of the extended sequence are 0. >> >> >> I also want to try use longer time series to get the frequency fM, >> then >> >> for the shorter time series I can extract the frequency componentfor>> fM. >> >> >So what you *really* want to do is to decode an FM signal? >> >> >> The problem is there is no frequency from FFT exactly equal to fM.So>> how >> >> can I extract the component from the shorter time series based onfM>> >> calculated by longer time series. I know we can interpolate by >> >> zero-padding, But I feel I can not extract the exact component from >> this. >> >> >> Hope I made my problem clear. Thank you all >> >> >No, you haven't. What do you try to do? Estimate the frequency of >> >one sinusoidal? Separate two sinusoidals? Demodulate an FM signal? >> >> >Rune >> >=============== >> >> Thank you Rune, >> To clarify my problem, I want to estimate accurately the frequency ofone>> sinusoidal, not separate two sinusoidals because there is only onemain>> frequency in my signal. My problem is strongly depends on thefrequency>> resolution, which means small frequency change will introduce big errorin>> my problem. basically, I need the resolution about 0.01-0.02Hz. > >You need 50-100 s of data to get that. > >> The wave signal I recorded is about 40-50s. But because it is hard to >> separate the reflected wave and incident wave for my situation, I needuse>> only the beginning part to analysis (7s to 10s). So my second questionis>> trying get the frequency from the whole signal which give theresolution>> about 0.02Hz, then use this frequency(lets say fM) to analysis the >> beginning part. Since 7s to 10s signal may not give extact fMcomponent,>> how can I extract the fM component from this short period. > >What type of signal is this? You talk about 'pulse' and 'reflection'. >Those are usually transients, meaning that frequency estimation >is more or less meaningless since you transmitted the signal >yourself and - presumably - already know what you sent. > >Could you please decribe the experiment and application? > >Rune >===============================Rune, I measure the gravity water wave propagating into ice cover in the lab. The wave will reflect from the beach. Because the wave damps under ice cover, it is hard to separate the incident wave and reflected wave. For my analysis, I need use the pure incident wave which means there is no reflection, I call it the beginning part in my last post. I assume that the wave paddle only generate one frequency.
"biantai" <wrxdlut@gmail.com> wrote in message news:uumdnXJXkuhWsxjVnZ2dnUVZ_sninZ2d@giganews.com...> Hi all,I am a newer in DSP. I have a frequency resolution problem, need > your suggestions and comments. > > My problem depends on frequency resolution. Basically I need the frequency > resolution around 0.01-0.02 at least to make the error smaller. But my > useful signal is roughly 10s which means the frequency resolution is > 0.1Hz, > this is far away from my requirement. Does anybody know if there is method > can solve this issue? > > One of my friends suggested me to patch the "good connected signal" from > the original signal to the end of the time series to make the signal very > long. I don't think this will work, but I don't know how to argue with > him. > Anybody can give me a theory for this so that I can argue with him. >Sure. If you concatenate copies of the signal with itself it will be periodic won't it? If it's periodic, then it's represented by harmonics which are spaced exactly the same as the original frequency samples. Because the splice points are likely discontinous, there will be some energy between the harmonic samples but that's "noise" to you. If you were able to capture a perfect integer number of periods and then splice those you would generate less transient noise at the edges and the interim samples would be closer to zero. I once tried to generate a submarine noise signature using a rather short memory (of time length T) that would play in a "loop". It sounded great after I adjusted the length to match the fundamental beats so there was no discernible transient. BUT: No surprise now that I learned its spectrum was quite discrete - i.e. made up of lines separated by 1/T. Same idea ..... Fred
Reply by ●July 23, 20082008-07-23
On 23 Jul, 00:24, "biantai" <wrxd...@gmail.com> wrote:> >On 22 Jul, 19:11, "biantai" <wrxd...@gmail.com> wrote: > >> >On 22 Jul, 02:50, "biantai" <wrxd...@gmail.com> wrote: > >> >> Hi all,I am a newer in DSP. I have a frequency resolution problem, > >> need > >> >> your suggestions and comments. > > >> >> My problem depends on frequency resolution. Basically I need the > >> frequency > >> >> resolution around 0.01-0.02 at least to make the error smaller. But > my > >> >> useful signal is roughly 10s which means the frequency resolution > is > >> 0.1Hz, > >> >> this is far away from my requirement. Does anybody know if there is > >> method > >> >> can solve this issue? > > >> >It depends on the exact problem you try to solve. "Resolution" can > >> >mean > >> >two things, either the ability to find the frequeny of *one* > >> >sinusoidal > >> >with high accuracy, or to separate *two* sinusoidals at similar > >> >frequencies. > > >> >The available solution methods depend on what you try to do and why. > > >> >> One of my friends suggested me to patch the "good connected signal" > >> from > >> >> the original signal to the end of the time series to make the > signal > >> very > >> >> long. I don't think this will work, but I don't know how to argue > with > >> him. > >> >> Anybody can give me a theory for this so that I can argue with him. > > >> >It's an interesting exercise if you try it, but it will not solve > >> >your > >> >problem since you do not introduce new information to the signal. > > >> >Try this in matlab: > > >> >s=randn(100,1); > >> >stem((0:length(s)-1)/length(s),abs(fft(s)),'b'); > >> >hold on > >> >S=[s;s]; > >> >stem((0:length(S)-1)/length(S),abs(fft(S))/2,'r') > > >> >It should be no surprise that you get all the same coefficients > >> >in the extended signal as in the original signal (save a scale > >> >factor). Since you did not add any new information, the 'extra' > >> >coefficients in the spectrum of the extended sequence are 0. > > >> >> I also want to try use longer time series to get the frequency fM, > >> then > >> >> for the shorter time series I can extract the frequency component > for > >> fM. > > >> >So what you *really* want to do is to decode an FM signal? > > >> >> The problem is there is no frequency from FFT exactly equal to fM. > So > >> how > >> >> can I extract the component from the shorter time series based on > fM > >> >> calculated by longer time series. I know we can interpolate by > >> >> zero-padding, But I feel I can not extract the exact component from > >> this. > > >> >> Hope I made my problem clear. Thank you all > > >> >No, you haven't. What do you try to do? Estimate the frequency of > >> >one sinusoidal? Separate two sinusoidals? Demodulate an FM signal? > > >> >Rune > >> >=============== > > >> Thank you Rune, > >> To clarify my problem, I want to estimate accurately the frequency of > one > >> sinusoidal, not separate two sinusoidals because there is only one > main > >> frequency in my signal. My problem is strongly depends on the > frequency > >> resolution, which means small frequency change will introduce big error > in > >> my problem. basically, I need the resolution about 0.01-0.02Hz. > > >You need 50-100 s of data to get that. > > >> The wave signal I recorded is about 40-50s. But because it is hard to > >> separate the reflected wave and incident wave for my situation, I need > use > >> only the beginning part to analysis (7s to 10s). So my second question > is > >> trying get the frequency from the whole signal which give the > resolution > >> about 0.02Hz, then use this frequency(lets say fM) to analysis the > >> beginning part. Since 7s to 10s signal may not give extact fM > component, > >> how can I extract the fM component from this short period. > > >What type of signal is this? You talk about 'pulse' and 'reflection'. > >Those are usually transients, meaning that frequency estimation > >is more or less meaningless since you transmitted the signal > >yourself and - presumably - already know what you sent. > > >Could you please decribe the experiment and application? > > >Rune > >=============================== > > Rune, I measure the gravity water wave propagating into ice cover in the > lab. The wave will reflect from the beach. Because the wave damps under ice > cover, it is hard to separate the incident wave and reflected wave. For my > analysis, I need use the pure incident wave which means there is no > reflection, I call it the beginning part in my last post. I assume that the > wave paddle only generate one frequency.Why do you think that the frequency of th ereflection will change? If it does not, then use the whole signal irrespective of reflections. Ih it does (for instance because of propagations in shallow waters) then use the whole signal. In the latter case the change in frequency is likely to be so large that the waves are well-separated in frquency domain. Rune
>On 23 Jul, 00:24, "biantai" <wrxd...@gmail.com> wrote: >> >On 22 Jul, 19:11, "biantai" <wrxd...@gmail.com> wrote: >> >> >On 22 Jul, 02:50, "biantai" <wrxd...@gmail.com> wrote: >> >> >> Hi all,I am a newer in DSP. I have a frequency resolutionproblem,>> >> need >> >> >> your suggestions and comments. >> >> >> >> My problem depends on frequency resolution. Basically I need the >> >> frequency >> >> >> resolution around 0.01-0.02 at least to make the error smaller.But>> my >> >> >> useful signal is roughly 10s which means the frequencyresolution>> is >> >> 0.1Hz, >> >> >> this is far away from my requirement. Does anybody know if thereis>> >> method >> >> >> can solve this issue? >> >> >> >It depends on the exact problem you try to solve. "Resolution" can >> >> >mean >> >> >two things, either the ability to find the frequeny of *one* >> >> >sinusoidal >> >> >with high accuracy, or to separate *two* sinusoidals at similar >> >> >frequencies. >> >> >> >The available solution methods depend on what you try to do andwhy.>> >> >> >> One of my friends suggested me to patch the "good connectedsignal">> >> from >> >> >> the original signal to the end of the time series to make the >> signal >> >> very >> >> >> long. I don't think this will work, but I don't know how toargue>> with >> >> him. >> >> >> Anybody can give me a theory for this so that I can argue withhim.>> >> >> >It's an interesting exercise if you try it, but it will not solve >> >> >your >> >> >problem since you do not introduce new information to the signal. >> >> >> >Try this in matlab: >> >> >> >s=randn(100,1); >> >> >stem((0:length(s)-1)/length(s),abs(fft(s)),'b'); >> >> >hold on >> >> >S=[s;s]; >> >> >stem((0:length(S)-1)/length(S),abs(fft(S))/2,'r') >> >> >> >It should be no surprise that you get all the same coefficients >> >> >in the extended signal as in the original signal (save a scale >> >> >factor). Since you did not add any new information, the 'extra' >> >> >coefficients in the spectrum of the extended sequence are 0. >> >> >> >> I also want to try use longer time series to get the frequencyfM,>> >> then >> >> >> for the shorter time series I can extract the frequencycomponent>> for >> >> fM. >> >> >> >So what you *really* want to do is to decode an FM signal? >> >> >> >> The problem is there is no frequency from FFT exactly equal tofM.>> So >> >> how >> >> >> can I extract the component from the shorter time series basedon>> fM >> >> >> calculated by longer time series. I know we can interpolate by >> >> >> zero-padding, But I feel I can not extract the exact componentfrom>> >> this. >> >> >> >> Hope I made my problem clear. Thank you all >> >> >> >No, you haven't. What do you try to do? Estimate the frequency of >> >> >one sinusoidal? Separate two sinusoidals? Demodulate an FM signal? >> >> >> >Rune >> >> >=============== >> >> >> Thank you Rune, >> >> To clarify my problem, I want to estimate accurately the frequencyof>> one >> >> sinusoidal, not separate two sinusoidals because there is only one >> main >> >> frequency in my signal. My problem is strongly depends on the >> frequency >> >> resolution, which means small frequency change will introduce bigerror>> in >> >> my problem. basically, I need the resolution about 0.01-0.02Hz. >> >> >You need 50-100 s of data to get that. >> >> >> The wave signal I recorded is about 40-50s. But because it is hardto>> >> separate the reflected wave and incident wave for my situation, Ineed>> use >> >> only the beginning part to analysis (7s to 10s). So my secondquestion>> is >> >> trying get the frequency from the whole signal which give the >> resolution >> >> about 0.02Hz, then use this frequency(lets say fM) to analysis the >> >> beginning part. Since 7s to 10s signal may not give extact fM >> component, >> >> how can I extract the fM component from this short period. >> >> >What type of signal is this? You talk about 'pulse' and 'reflection'. >> >Those are usually transients, meaning that frequency estimation >> >is more or less meaningless since you transmitted the signal >> >yourself and - presumably - already know what you sent. >> >> >Could you please decribe the experiment and application? >> >> >Rune >> >=============================== >> >> Rune, I measure the gravity water wave propagating into ice cover inthe>> lab. The wave will reflect from the beach. Because the wave damps underice>> cover, it is hard to separate the incident wave and reflected wave. Formy>> analysis, I need use the pure incident wave which means there is no >> reflection, I call it the beginning part in my last post. I assume thatthe>> wave paddle only generate one frequency. > >Why do you think that the frequency of th ereflection will change? >If it does not, then use the whole signal irrespective of reflections. >Ih it does (for instance because of propagations in shallow waters) >then use the whole signal. In the latter case the change in frequency >is likely to be so large that the waves are well-separated in frquency >domain. > >Rune >=============Rune, thank you for your reply. Maybe I am not clear to describe this problem. I also think the frequency will not change, so I try to use the whole signal to determine the frequency. But because I also need get ride of the noise in my pure wave part which only means no reflection but noise, I need to extract the frequency component from it. So the problem becomes to how to extract the main frequency component for a short sequence when I know the main frequency?
