Re: Kalman filtering with multiplicative noise
Started by RRogers July 22, 2008
On Jul 21, 8:06 pm, d...@myallit.com wrote:
> On Jul 21, 5:35 pm, "Bruno Luong" <b.lu...@fogale.fr> wrote: > > > d...@myallit.com wrote in message > > > You might consider Extended Kalman filtering (EKF). Be aware > > about the eventual non-stability of the scheme. > > What do you mean by the eventual non-stability? I did look at the EKF, > there is some simple sample MATLAB code here:http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objec... > > But in the first few lines of this script it says: > > % for nonlinear dynamic system: > % x_k+1 = f(x_k) + w_k > % z_k = h(x_k) + v_k > % where w ~ N(0,Q) meaning w is gaussian noise with covariance Q > % v ~ N(0,R) meaning v is gaussian noise with covariance R > > so the EKF looks appropriate for non-linear process models and > measurement models that can be represented by any arbitrary functions > f(x) and h(x), but the noise is still assumed to be additive.
If you change the second equation to log's, and if the log(v2) was adequately described by a normal distribution then the noise would be additive and the non-linearity would pushed into the x2/z2 and it seems that the EKF could deal with it. In terms of the wikipedia article and your state equation z1=x1+v1 lz2=lx2+lv2 and presumptively x1'=dt*lx1+exp(lx2)+v1 lx2'=log(x1)+lv2 You should really presume these state equations are wrong! Without the differential equations including the noise terms I really can't get a handle on them mentally ( I usually get the first go round wrong anyway). RayR
