hello all, I work with EZ-Kit Lite 21161N and AD 1836, sample frequency in 48k ! how can I down the sample frequency to 8k ?? I know, I need decimate... but I don't know how !!! somebody know a article, book or something ?? thank's Henrique
decimating AD1836 (EZ-KIT Lite 21161N)
Started by ●July 22, 2008
Reply by ●July 22, 20082008-07-22
hbarcellos wrote:> hello all, > > I work with EZ-Kit Lite 21161N and AD 1836, sample frequency in 48k ! how > can I down the sample frequency to 8k ?? > > I know, I need decimate... but I don't know how !!! > > somebody know a article, book or something ?? >_Just_ decimation means taking one of every N samples -- in your case you'd need every 6th. Do you need to anti-alias filter as well? In that case you run your anti-alias filter (usually a FIR filter) over whatever span of samples it needs, at 1/6th the 48kHz sampling rate. Get a copy of Rick Lyons' "Understanding Digital Signal Processing", see if it helps out. In the mean time, here's a bit about sampling, which also applies to decimation if you hold your mouth right: http://www.wescottdesign.com/articles/Sampling/sampling.html. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
"hbarcellos" <henrique_barcellos@hotmail.com> writes:> hello all, > > I work with EZ-Kit Lite 21161N and AD 1836, sample frequency in 48k ! how > can I down the sample frequency to 8k ?? > > I know, I need decimate... but I don't know how !!! > > somebody know a article, book or something ??@BOOK{lyonsnew, title = "{Understanding Digital Signal Processing}", edition = "Second", author = "{Richard~G.~Lyons}", publisher = "Prentice Hall", year = "2004"} @BOOK{mitra, title = "{Digital Signal Processing: A Computer-Based Approach}", author = "Sanjit~K.~Mitra", publisher = "McGraw-Hill", edition = "second", year = "2001"}> > thank's > > Henrique-- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://www.digitalsignallabs.com
Reply by ●July 23, 20082008-07-23
hbarcellos wrote:> hello all, > > I work with EZ-Kit Lite 21161N and AD 1836, sample frequency in 48k ! how > can I down the sample frequency to 8k ??The decimation is a minor technical problem. The real question is why do you have to decimate.> I know, I need decimate... but I don't know how !!!Eh? Drop the clock rate on the codec then.> somebody know a article, book or something ??L. Rabiner "Multirate Signal Processing" Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
hbarcellos wrote:> hello all, > > I work with EZ-Kit Lite 21161N and AD 1836, sample frequency in 48k ! how > can I down the sample frequency to 8k ?? > I know, I need decimate... but I don't know how !!! > somebody know a article, book or something ?? >I like this one: http://www.dspguru.com/info/faqs/mrfaq.htm -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Being a good example is hard. I'm trying to serve as a horrible warning instead. - Brian Crane
>hello all, > >I work with EZ-Kit Lite 21161N and AD 1836, sample frequency in 48k !how>can I down the sample frequency to 8k ?? > >I know, I need decimate... but I don't know how !!!yes... now I think, I understood, my problem is, I need more time to process the algorithm between one sample and other... well, 48k of sample frequency is too much to me... so, an solution is downsample to 8k... so I need that my processor run my algorithm before read the next sample... and with 8k it is ok.... thank's... I'll read the articles and see what can I do !!!! I think, a possibilite is, when the interrupt call to read the next sample (ad1836), I put the condition (if) and a counter to read the sample six by six... what do you think ??? there is a overhead but I've more time between one sample and other... henrique> >somebody know a article, book or something ?? > >thank's > >Henrique >
