Hi all, long time reader, first time posting as a member. My query relates to MFCC calculation. Generally speaking I have an ok verbal understanding of MFCC's, however I never had a detailed understanding. Firstly, im trying to implement this in MATLAB (this being MFCC calculation). Im fairly all right at MATLAB, so the previous steps to MFCC calculation such as windowing and framing are of no trouble to me. Im not asking/looking for MFCC MATLAB code (although that does sound nice if its well commented) as I have came across MFCC MATLAB code already on the internet. What I am looking for is a good step by step explanation of how to generate MFCC's. The end result would be that I understand the explanation enough to code it myself in MATLAB. Now I have googled MFCCs before, but I was wondering if anyone knows where a good explanation exists (or if they have one themselves). All going well, I'd be happy to post up my MFCC code once I've understood and coded it. I hope I have explained myself well, Thank you for your time, Mark
MFCC
Started by ●July 30, 2008
Reply by ●July 30, 20082008-07-30
On Jul 30, 12:30 pm, "nerdlinger" <nerdlinger.gene...@gmail.com> wrote:> I hope I have explained myself well,I think you should probably define the acronym "MFCC". It's not one that is all that common.> Im not asking/looking for MFCC MATLAB code (although that does sound nice > if its well commented) as I have came across MFCC MATLAB code already on > the internet. What I am looking for is a good step by step explanation of > how to generate MFCC's. The end result would be that I understand the > explanation enough to code it myself in MATLAB.Assuming you mean "Mel-frequency cepstrum coefficient,", from http://en.wikipedia.org/wiki/Mel_frequency_cepstral_coefficient: --- MFCCs are commonly derived as follows:[1] 1. Take the Fourier transform of (a windowed excerpt of) a signal. 2. Map the powers of the spectrum obtained above onto the mel scale, using triangular overlapping windows. 3. Take the logs of the powers at each of the mel frequencies. 4. Take the discrete cosine transform of the list of mel log powers, as if it were a signal. 5. The MFCCs are the amplitudes of the resulting spectrum. --- Seems pretty straightforward. Jason
Reply by ●March 24, 20112011-03-24
> Im not asking/looking for MFCC MATLAB code (although that does sound > niceTry here: http://labrosa.ee.columbia.edu/matlab/rastamat/ or here http://www.aquaphoenix.com/research/matlab/ Please note that they produce different results. Hope that helps Erich
