symbol synchronisation
Started by cpshah99 July 31, 2008
Hello People
I would like to develope a adaptive symbol synchronisation assuming I have
got perfect phase synchronisation.
Can you please suggest some techniques.? I have looked into some books but
the treatment is not enough.
Your guidance will be greatly appreciated.
Thanking you,
Chintan
On Thu, 31 Jul 2008 15:39:54 -0500, "cpshah99"
<cpshah99@rediffmail.com> wrote:
>Hello People > >I would like to develope a adaptive symbol synchronisation assuming I have >got perfect phase synchronisation. > >Can you please suggest some techniques.? I have looked into some books but >the treatment is not enough. > >Your guidance will be greatly appreciated. > >Thanking you, > >Chintan
Phase-locked loop with a Timing Error Detector. Usually, though, timing locks first and then phase. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Aug 1, 4:39&#4294967295;am, "cpshah99" <cpsha...@rediffmail.com> wrote:
> Hello People > > I would like to develope a adaptive symbol synchronisation assuming I have > got perfect phase synchronisation. > > Can you please suggest some techniques.? I have looked into some books but > the treatment is not enough. > > Your guidance will be greatly appreciated.
When you say "phase synchronisation" I assume you mean carrier phase rather than symbol phase. Most symbol sync techniques don't actually care too much about carrier sync., and are typically placed before it. Learning how to do symbol sync sucks. Every comms book covers the topic, but none really get to grips with it. They all describe simple techniques that work in simple cases, but generally avoid the serious real world cases, and how the various algorithms can fail. You didn't say anything about the kind of symbols you are trying to sync to. It matters a lot. If there is significant excess bandwidth in the signal, and it is PSK, simple techniques like a Gardner timing error detector (which if you've looked at any digital comms book you must know about) work really well. If there is lots of excess bandwidth, and you are able to use slow tracking, Gardner can even work well with high order QAM. You just need to consider the average of a number of Gardner tests, rather than considering each individual test to be meaningful. However, simple techniques like this tend to fall apart, or suffer from multiple minima (i.e. they can settle to certain wrong places just as easily as to the right one) when the excess bandwidth is small - i.e. the typical real world condition, for anything moderately advanced. Techniques based on cross correlating the two band edges takes more compute power, but are very predictable. This is a common basis for symbol sync in things like V.34 modems, where the bandwidth of the channel is very close to the underlying bandwidth of the signal. Regards, Steve
On Jul 31, 4:39&#4294967295;pm, "cpshah99" <cpsha...@rediffmail.com> wrote:
> Hello People > > I would like to develope a adaptive symbol synchronisation assuming I have > got perfect phase synchronisation. > > Can you please suggest some techniques.? I have looked into some books but > the treatment is not enough. > > Your guidance will be greatly appreciated. > > Thanking you, > > Chintan
The best references for this are D'Andrea and Mengali's book, and Meyr and Ascheid's book. Meyr has a second book with Moeneclaey that is very digitally-oriented, and is worth a look. Like Eric said, typically symbol synchronization is done in two parts: a timing error detector/estimator, and a timing filter to smooth out the estimates. Then you need a timing compensator to take the smoothed estimate, and use it to correct the next (batch of) symbols. There are several timing error detectors, with their pros and cons. The two books I mention above have this information. Julius
cpshah99 wrote:
> Hello People
Hello pupil,
This is trivial and impractical situation. If you have the perfect carrier synchronization, you already have the symbol synchronization (unless there is a frequency shift in the channel). Carrier sync and symbol sync are directly related; the only thing to find out is the phase of the symbol sync wrt carrier.
There are many. It largely depends on what is the signal and what are the other requirements: speed of tracking, processing power, algoritmic delay, bandwidth, SNR. For the simple cases, Gardner's algorithm works well. For the complex cases, I like to extract the timing information from the equalizer.
Viterbi & Omura "Digital Communication" Heinrich Meyr; Marc Moeneclaey; Stefan Fechtel "Digital Communication Receivers : Synchronization, Channel Estimation"
How great exactly is the great appreciacion?
> Thanking you, > Chintan
Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Hello All
Thanks a lot for responses.
My signal is QPSK modulated at carrier frequency of 12 KHz and with
bandwidth of 8 KHz. Now as I am modeling doppler in my system, I also have
doppler correction at receiver which uses Linear Interpolation. That
algorithm works very well, in the sense that it estimates the delay from
the equaliser and I use that delay to correct symbol timing and to correct
the carrier phase.
But this technique doesn't help me with turbo decoding. So I was thinking
that when we use turbo decoding do we just correct the symbol timing once
and for all.
I also implemented joint equaliser and PLL given by Godard's algorithm.
But it doesnt work well when my doppler is more than 0.2 m/s.
Thanks a lot.
To Vladimir: Sir, your help is greatly appreciated :-)
Chintan
cpshah99 wrote:
> Hello All > > Thanks a lot for responses.
You'd better start with getting to work the basic Costas and Gardner before jumping into the complicated things.
> My signal is QPSK modulated at carrier frequency of 12 KHz and with > bandwidth of 8 KHz. Now as I am modeling doppler in my system, I also have > doppler correction at receiver which uses Linear Interpolation.
Come on. What kind of doppler can be at 12kHz ?
> That > algorithm works very well, in the sense that it estimates the delay from > the equaliser and I use that delay to correct symbol timing and to correct > the carrier phase.
Incredible.
> But this technique doesn't help me with turbo decoding. So I was thinking > that when we use turbo decoding do we just correct the symbol timing once > and for all.
There is no relation between sync and decoding. Unless you are using some sort of the non-causal decision directed algorithm. Of course, sync should be good enough not to impair the performance of the decoder, which can be challenging at low SNR.
Wow.
Which means that the system simply doesn't work.
> Thanks a lot.
Go to hell.
Your appreciation is cheap and worseless.
> Chintan
> > >cpshah99 wrote: > >> Hello All >> >> Thanks a lot for responses. > >You'd better start with getting to work the basic Costas and Gardner >before jumping into the complicated things. > >> My signal is QPSK modulated at carrier frequency of 12 KHz and with >> bandwidth of 8 KHz. Now as I am modeling doppler in my system, I also
have
>> doppler correction at receiver which uses Linear Interpolation. > >Come on. What kind of doppler can be at 12kHz ? > >> That >> algorithm works very well, in the sense that it estimates the delay
from
correct
>> the carrier phase. > >Incredible. > >> But this technique doesn't help me with turbo decoding. So I was
thinking
once
>> and for all. > >There is no relation between sync and decoding. Unless you are using >some sort of the non-causal decision directed algorithm. Of course, sync
>should be good enough not to impair the performance of the decoder, >which can be challenging at low SNR. > >> I also implemented joint equaliser and PLL given by Godard's
algorithm.
> >Wow. > >> But it doesnt work well when my doppler is more than 0.2 m/s. > >Which means that the system simply doesn't work. > >> Thanks a lot. > >Go to hell. > >> To Vladimir: Sir, your help is greatly appreciated :-) > >Your appreciation is cheap and worseless. > >> Chintan > > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com >
%%%% Hello Thanks again. Ok I will start again from basics. But just wanted to ask, how does it relate doppler and carrier frquency. I can introduce any sort of doppler. From what I have seen from real time experiment that even doppler of 0.3 m/s can cuase hell lot of trouble. Now that joint PLL of Godard does not work above certain cases, that doesnt mean it doesnt work at all. Just for the fun, I was laughing abt 'Go to hell'. Few days back somebody asked me: do u believe in hell or heaven? I said : Yes. Then he asked: where will u go? I said : Hell. Thanks again. Chintan
On Aug 1, 2:30&#4294967295;pm, "cpshah99" <cpsha...@rediffmail.com> wrote:
> >cpshah99 wrote: > > >> Hello All > > >> Thanks a lot for responses. > > >You'd better start with getting to work the basic Costas and Gardner > >before jumping into the complicated things. > > >> My signal is QPSK modulated at carrier frequency of 12 KHz and with > >> bandwidth of 8 KHz. Now as I am modeling doppler in my system, I also > have > >> doppler correction at receiver which uses Linear Interpolation. > > >Come on. What kind of doppler can be at 12kHz ? > > >> That > >> algorithm works very well, in the sense that it estimates the delay > from > >> the equaliser and I use that delay to correct symbol timing and to > correct > >> the carrier phase. > > >Incredible. > > >> But this technique doesn't help me with turbo decoding. So I was > thinking > >> that when we use turbo decoding do we just correct the symbol timing > once > >> and for all. > > >There is no relation between sync and decoding. Unless you are using > >some sort of the non-causal decision directed algorithm. Of course, sync > >should be good enough not to impair the performance of the decoder, > >which can be challenging at low SNR. > > >> I also implemented joint equaliser and PLL given by Godard's > algorithm. > > >Wow. > > >> But it doesnt work well when my doppler is more than 0.2 m/s. > > >Which means that the system simply doesn't work. > > >> Thanks a lot. > > >Go to hell. > > >> To Vladimir: Sir, your help is greatly appreciated :-) > > >Your appreciation is cheap and worseless. > > >> Chintan > > >Vladimir Vassilevsky > >DSP and Mixed Signal Design Consultant > >http://www.abvolt.com > > %%%% > > Hello > > Thanks again. > > Ok I will start again from basics. > > But just wanted to ask, how does it relate doppler and carrier frquency. I > can introduce any sort of doppler. From what I have seen from real time > experiment that even doppler of 0.3 m/s can cuase hell lot of trouble. > > Now that joint PLL of Godard does not work above certain cases, that > doesnt mean it doesnt work at all. >
[snip] Since you haven't told us yet what the specs are (jitter, drift, excess bandwidth, SNR, modulation, fc, fs, etc.) it's hard to guess what will or will not work, except trivial cases :-P. Just like most things in real life, there are many solutions, but the regimes where each solution is reasonable often do not overlap.
>On Aug 1, 2:30=A0pm, "cpshah99" <cpsha...@rediffmail.com> wrote: >> >cpshah99 wrote: >> >> >> Hello All >> >> >> Thanks a lot for responses. >> >> >You'd better start with getting to work the basic Costas and Gardner >> >before jumping into the complicated things. >> >> >> My signal is QPSK modulated at carrier frequency of 12 KHz and with >> >> bandwidth of 8 KHz. Now as I am modeling doppler in my system, I
also
>> have >> >> doppler correction at receiver which uses Linear Interpolation. >> >> >Come on. What kind of doppler can be at 12kHz ? >> >> >> That >> >> algorithm works very well, in the sense that it estimates the delay >> from >> >> the equaliser and I use that delay to correct symbol timing and to >> correct >> >> the carrier phase. >> >> >Incredible. >> >> >> But this technique doesn't help me with turbo decoding. So I was >> thinking >> >> that when we use turbo decoding do we just correct the symbol
timing
>> once >> >> and for all. >> >> >There is no relation between sync and decoding. Unless you are using >> >some sort of the non-causal decision directed algorithm. Of course,
sync
>> >should be good enough not to impair the performance of the decoder, >> >which can be challenging at low SNR. >> >> >> I also implemented joint equaliser and PLL given by Godard's >> algorithm. >> >> >Wow. >> >> >> But it doesnt work well when my doppler is more than 0.2 m/s. >> >> >Which means that the system simply doesn't work. >> >> >> Thanks a lot. >> >> >Go to hell. >> >> >> To Vladimir: Sir, your help is greatly appreciated :-) >> >> >Your appreciation is cheap and worseless. >> >> >> Chintan >> >> >Vladimir Vassilevsky >> >DSP and Mixed Signal Design Consultant >> >http://www.abvolt.com >> >> %%%% >> >> Hello >> >> Thanks again. >> >> Ok I will start again from basics. >> >> But just wanted to ask, how does it relate doppler and carrier
frquency. =
>I >> can introduce any sort of doppler. From what I have seen from real
time
>> experiment that even doppler of 0.3 m/s can cuase hell lot of trouble. >> >> Now that joint PLL of Godard does not work above certain cases, that >> doesnt mean it doesnt work at all. >> >[snip] > >Since you haven't told us yet what the specs are (jitter, drift, >excess >bandwidth, SNR, modulation, fc, fs, etc.) it's hard to guess what will >or will >not work, except trivial cases :-P. > >Just like most things in real life, there are many solutions, but the >regimes >where each solution is reasonable often do not overlap. >
%%%%%% Hi I am doing this simulation for underwater comms, mt fc=12 KHz, fs= 48 KHz, QPSK Modulation, signal bandwidth 8 KHz. I will still look into basics again like Gardener or Costas loop. Thanks again. Chintan
