Zigbee capacity?
Started by Ginu ●August 7, 2008
On Aug 13, 8:44&#4294967295;am, Eric Jacobsen <eric.jacob...@ieee.org> wrote:
> [...] > A defined maximum data rate of 250kbps sets the max data rate, and the > Modulation and Coding Scheme used to achieve that rate sets the > performance, less any implementation losses. &#4294967295; If a > capacity-approaching code is not used (and Zigbee does not use a > capacity-approaching code), then it does not achieve Shannon capacity. > I don't recall off the top of my head what coding Zigbee uses, but > there's probably at least a 3-6dB gap to capacity at typically > measured error rates. &#4294967295; That would also assume a continuous stream, > which Zigbee doesn't do. > > Bottom line: I don't think Shannon capacity is relevant to a defined > standard unless one just cares about how big the gap is to capacity.
I think the measure you just gave is pretty relevant. With the best transmission schemes getting close to capacity, your measure is basically "how much performance does this standard sacrifice in the name of reduced complexity/power consumption/cost/whatever", which seems a pretty interesting thing to know, Steve
On Aug 12, 8:44&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:
> On Tue, 12 Aug 2008 10:49:38 -0700 (PDT), Ginu <osheik...@gmail.com> > wrote: > > > > > > >On Aug 8, 12:54&#4294967295;am, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> On Thu, 07 Aug 2008 22:02:08 -0400, Randy Yates <ya...@ieee.org> > >> wrote: > > >> >ste...@coppice.org writes: > > >> >> On Aug 8, 7:47&#4294967295;am, Randy Yates <ya...@ieee.org> wrote: > >> >>> Eric Jacobsen <eric.jacob...@ieee.org> writes: > >> >>> > On Thu, 7 Aug 2008 14:17:10 -0700 (PDT), Ginu <osheik...@gmail.com> > >> >>> > wrote: > > >> >>> >>Hello, > > >> >>> >>I'm trying to compute the Zigbee capacity between two nodes. Is there > >> >>> >>a physical layer Shannon capacity representation for a Zigbee? Doing a > >> >>> >>search, I don't see any meaningful results for Zigbee Shannon Capacity > >> >>> >>or Zigbee Capacity which seems strange. Is there something I'm > >> >>> >>missing? > > >> >>> >>Thanks, > >> >>> >>Omar > > >> >>> > Computing channel capacity doesn't mean much when one is using a > >> >>> > standardized implementation. &#4294967295; Do you mean you're looking for the > >> >>> > maximum data rates achievable with a Zigbee system? &#4294967295; Or do you mean > >> >>> > you're looking for performance curves for a Zigbee system? > > >> >>> > If the latter, you're not likely to find such things. &#4294967295; Performance > >> >>> > for any wireless system varies among implementations, but varies > >> >>> > hugely across environments. &#4294967295; It doesn't make much sense for > >> >>> > manufacturers to publish performance curves when practical channel > >> >>> > conditions are not controlled or predictable. > > >> >>> Surely there must be some assumptiong on channel conditions, > >> >>> otherwise how could you plan a system? > > >> >> ZigBee uses the same band as 802.11. When you use 802.11 indoors do > >> >> you have any clue in advance how well its going to work? > > >> >You have a pretty good idea what the ranges will be. > > >> Yes, but not the channel conditions. &#4294967295; The variation in fading in > >> PAN/LAN environments is very broad, and it's anybody's bet what sort > >> of throughput/performance one will get for a given link at whatever > >> expected range. &#4294967295; e.g., basic low-power Zigbee is only really expected > >> to work for ranges of about 3ft to maybe 10m. &#4294967295; Whether one gets the > >> 3ft or the 10m just depends on the environment. &#4294967295;Likewise with 802.11; > >> how many walls, how close are they, what's the reflective environment, > >> etc., etc. &#4294967295; It all makes a big difference from one link to the next. > > >> >> Its easy to produce performance curves for open air > >> >> operation. However, if you ask its developers how well ZigBee is going > >> >> to work in a real house or office they shrug their shoulders and say > >> >> "let's see". > > >> >> I don't think anyone has yet planned a ZigBee system. > > >> >Surely someone has. I think TI has parts based on the standard. (Their > >> >site seems to be down right now). > > >> Yes, there are Zigbee products on the market. &#4294967295; They basically work, > >> but performance seems to be all over the place. &#4294967295; You can get them > >> with 100mW PAs (or more) and try to make them do long range, too. &#4294967295; No > >> guarantees, though. &#4294967295;;) > > >> Eric Jacobsen > >> Minister of Algorithms > >> Abineau Communicationshttp://www.ericjacobsen.org > > >> Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php-Hide quoted text - > > >> - Show quoted text - > > >Well, by Shannon Capacity of Zigbee networks, I mean the maximum > >achievable data rate for the Zigbee standard. Zigbee has rates up to > >250 kbps. Surely there's a physical layer representation of the > >maximum achievable date rate for Zigbee considering it's a wireless > >technology, uses power and bandwidth. Would it use the common R = w * > >log2 ( 1 + P*G/(w*N + I)) bits/sec formula? For the maximum possible > >transmit power of 1 mW for the Zigbee standard, distances of say 50 > >metres, I'm getting astonishingly high rates in the order of 10^6, not > >10^3. > > I still don't think the Shannon capacity has any bearing on a defined > standard, unless you're interested in how closely the implementation > may be able to approach capacity. > > A defined maximum data rate of 250kbps sets the max data rate, and the > Modulation and Coding Scheme used to achieve that rate sets the > performance, less any implementation losses. &#4294967295; If a > capacity-approaching code is not used (and Zigbee does not use a > capacity-approaching code), then it does not achieve Shannon capacity. > I don't recall off the top of my head what coding Zigbee uses, but > there's probably at least a 3-6dB gap to capacity at typically > measured error rates. &#4294967295; That would also assume a continuous stream, > which Zigbee doesn't do. > > Bottom line: I don't think Shannon capacity is relevant to a defined > standard unless one just cares about how big the gap is to capacity. > > Eric Jacobsen > Minister of Algorithms > Abineau Communicationshttp://www.ericjacobsen.org > > Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php- Hide quoted text - > > - Show quoted text -
Then maybe you can help me Eric. I have a multi-technology network where I analyze Zigbee, Ultrawideband and WiMax technologies from a routing perspective in software radio networks. I'm optimizing a path from a source node of one technology (say Zigbee) to a destination that uses another technology (say WiMax) and the nodes in between convert transmissions from one technology to another as software radios. I'm optimizing transmit power and rate, and am using the Shannon capacity to estimate the transmission rates as a physical layer representation. I'm able to estimate rates using the Shannon formula R = w*log2(1 + P*G(f)/(w*N + I)), but my rates are significantly off for Zigbee using the Zigbee parameters for w, max transmit power P and frequency f. Can I not use the Shannon formula to estimate the transmission rates from a physical layer perspective for Zigbee? What about Ultrawideband and WiMax? I haven't been able to find any literature on this. Thanks, Omar
On Wed, 13 Aug 2008 09:24:27 -0700 (PDT), Ginu <osheikh81@gmail.com>
wrote:
>On Aug 12, 8:44&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: >> On Tue, 12 Aug 2008 10:49:38 -0700 (PDT), Ginu <osheik...@gmail.com> >> wrote: >> >> >> >> >> >> >On Aug 8, 12:54&#4294967295;am, Eric Jacobsen <eric.jacob...@ieee.org> wrote: >> >> On Thu, 07 Aug 2008 22:02:08 -0400, Randy Yates <ya...@ieee.org> >> >> wrote: >> >> >> >ste...@coppice.org writes: >> >> >> >> On Aug 8, 7:47&#4294967295;am, Randy Yates <ya...@ieee.org> wrote: >> >> >>> Eric Jacobsen <eric.jacob...@ieee.org> writes: >> >> >>> > On Thu, 7 Aug 2008 14:17:10 -0700 (PDT), Ginu <osheik...@gmail.com> >> >> >>> > wrote: >> >> >> >>> >>Hello, >> >> >> >>> >>I'm trying to compute the Zigbee capacity between two nodes. Is there >> >> >>> >>a physical layer Shannon capacity representation for a Zigbee? Doing a >> >> >>> >>search, I don't see any meaningful results for Zigbee Shannon Capacity >> >> >>> >>or Zigbee Capacity which seems strange. Is there something I'm >> >> >>> >>missing? >> >> >> >>> >>Thanks, >> >> >>> >>Omar >> >> >> >>> > Computing channel capacity doesn't mean much when one is using a >> >> >>> > standardized implementation. &#4294967295; Do you mean you're looking for the >> >> >>> > maximum data rates achievable with a Zigbee system? &#4294967295; Or do you mean >> >> >>> > you're looking for performance curves for a Zigbee system? >> >> >> >>> > If the latter, you're not likely to find such things. &#4294967295; Performance >> >> >>> > for any wireless system varies among implementations, but varies >> >> >>> > hugely across environments. &#4294967295; It doesn't make much sense for >> >> >>> > manufacturers to publish performance curves when practical channel >> >> >>> > conditions are not controlled or predictable. >> >> >> >>> Surely there must be some assumptiong on channel conditions, >> >> >>> otherwise how could you plan a system? >> >> >> >> ZigBee uses the same band as 802.11. When you use 802.11 indoors do >> >> >> you have any clue in advance how well its going to work? >> >> >> >You have a pretty good idea what the ranges will be. >> >> >> Yes, but not the channel conditions. &#4294967295; The variation in fading in >> >> PAN/LAN environments is very broad, and it's anybody's bet what sort >> >> of throughput/performance one will get for a given link at whatever >> >> expected range. &#4294967295; e.g., basic low-power Zigbee is only really expected >> >> to work for ranges of about 3ft to maybe 10m. &#4294967295; Whether one gets the >> >> 3ft or the 10m just depends on the environment. &#4294967295;Likewise with 802.11; >> >> how many walls, how close are they, what's the reflective environment, >> >> etc., etc. &#4294967295; It all makes a big difference from one link to the next. >> >> >> >> Its easy to produce performance curves for open air >> >> >> operation. However, if you ask its developers how well ZigBee is going >> >> >> to work in a real house or office they shrug their shoulders and say >> >> >> "let's see". >> >> >> >> I don't think anyone has yet planned a ZigBee system. >> >> >> >Surely someone has. I think TI has parts based on the standard. (Their >> >> >site seems to be down right now). >> >> >> Yes, there are Zigbee products on the market. &#4294967295; They basically work, >> >> but performance seems to be all over the place. &#4294967295; You can get them >> >> with 100mW PAs (or more) and try to make them do long range, too. &#4294967295; No >> >> guarantees, though. &#4294967295;;) >> >> >> Eric Jacobsen >> >> Minister of Algorithms >> >> Abineau Communicationshttp://www.ericjacobsen.org >> >> >> Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php-Hide quoted text - >> >> >> - Show quoted text - >> >> >Well, by Shannon Capacity of Zigbee networks, I mean the maximum >> >achievable data rate for the Zigbee standard. Zigbee has rates up to >> >250 kbps. Surely there's a physical layer representation of the >> >maximum achievable date rate for Zigbee considering it's a wireless >> >technology, uses power and bandwidth. Would it use the common R = w * >> >log2 ( 1 + P*G/(w*N + I)) bits/sec formula? For the maximum possible >> >transmit power of 1 mW for the Zigbee standard, distances of say 50 >> >metres, I'm getting astonishingly high rates in the order of 10^6, not >> >10^3. >> >> I still don't think the Shannon capacity has any bearing on a defined >> standard, unless you're interested in how closely the implementation >> may be able to approach capacity. >> >> A defined maximum data rate of 250kbps sets the max data rate, and the >> Modulation and Coding Scheme used to achieve that rate sets the >> performance, less any implementation losses. &#4294967295; If a >> capacity-approaching code is not used (and Zigbee does not use a >> capacity-approaching code), then it does not achieve Shannon capacity. >> I don't recall off the top of my head what coding Zigbee uses, but >> there's probably at least a 3-6dB gap to capacity at typically >> measured error rates. &#4294967295; That would also assume a continuous stream, >> which Zigbee doesn't do. >> >> Bottom line: I don't think Shannon capacity is relevant to a defined >> standard unless one just cares about how big the gap is to capacity. >> >> Eric Jacobsen >> Minister of Algorithms >> Abineau Communicationshttp://www.ericjacobsen.org >> >> Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php- Hide quoted text - >> >> - Show quoted text - > >Then maybe you can help me Eric. I have a multi-technology network >where I analyze Zigbee, Ultrawideband and WiMax technologies from a >routing perspective in software radio networks. I'm optimizing a path >from a source node of one technology (say Zigbee) to a destination >that uses another technology (say WiMax) and the nodes in between >convert transmissions from one technology to another as software >radios. I'm optimizing transmit power and rate, and am using the >Shannon capacity to estimate the transmission rates as a physical >layer representation. I'm able to estimate rates using the Shannon >formula R = w*log2(1 + P*G(f)/(w*N + I)), but my rates are >significantly off for Zigbee using the Zigbee parameters for w, max >transmit power P and frequency f. Can I not use the Shannon formula to >estimate the transmission rates from a physical layer perspective for >Zigbee? What about Ultrawideband and WiMax? I haven't been able to >find any literature on this. > >Thanks, >Omar
Why do you think the Shannon Capacity is a suitable benchmark for your task? Consider that the usual expression for the Shannon Capacity is in terms of only SNR, i.e., a memoryless AWGN channel, and then consider that the real-world channels experienced by Zigbee, Ultrawideband and WiMAX all have memory and fading. If your G(f) term is intended to describe a frequency selective channel such that water-filling can be considered, it should be noted that the mentioned technologies don't really do much waterfilling adaptation. WiMAX kinda sorta does sometimes in OFDMA, and Ultrawideband will occassionally turn off subcarriers, but mostly for interference purposes rather than propagation channel adaptation. As mentioned previously, I don't think Shannon Capacity is revelant to what you're trying to do. From what you've described it sounds like an OpNet simulation or other suitable simulation might be more appropriate for optimizing your system. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Aug 13, 1:52&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:
> On Wed, 13 Aug 2008 09:24:27 -0700 (PDT), Ginu <osheik...@gmail.com> > wrote: > > > > > > >On Aug 12, 8:44&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> On Tue, 12 Aug 2008 10:49:38 -0700 (PDT), Ginu <osheik...@gmail.com> > >> wrote: > > >> >On Aug 8, 12:54&#4294967295;am, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> >> On Thu, 07 Aug 2008 22:02:08 -0400, Randy Yates <ya...@ieee.org> > >> >> wrote: > > >> >> >ste...@coppice.org writes: > > >> >> >> On Aug 8, 7:47&#4294967295;am, Randy Yates <ya...@ieee.org> wrote: > >> >> >>> Eric Jacobsen <eric.jacob...@ieee.org> writes: > >> >> >>> > On Thu, 7 Aug 2008 14:17:10 -0700 (PDT), Ginu <osheik...@gmail.com> > >> >> >>> > wrote: > > >> >> >>> >>Hello, > > >> >> >>> >>I'm trying to compute the Zigbee capacity between two nodes. Is there > >> >> >>> >>a physical layer Shannon capacity representation for a Zigbee? Doing a > >> >> >>> >>search, I don't see any meaningful results for Zigbee Shannon Capacity > >> >> >>> >>or Zigbee Capacity which seems strange. Is there something I'm > >> >> >>> >>missing? > > >> >> >>> >>Thanks, > >> >> >>> >>Omar > > >> >> >>> > Computing channel capacity doesn't mean much when one is using a > >> >> >>> > standardized implementation. &#4294967295; Do you mean you're looking for the > >> >> >>> > maximum data rates achievable with a Zigbee system? &#4294967295; Or do you mean > >> >> >>> > you're looking for performance curves for a Zigbee system? > > >> >> >>> > If the latter, you're not likely to find such things. &#4294967295; Performance > >> >> >>> > for any wireless system varies among implementations, but varies > >> >> >>> > hugely across environments. &#4294967295; It doesn't make much sense for > >> >> >>> > manufacturers to publish performance curves when practical channel > >> >> >>> > conditions are not controlled or predictable. > > >> >> >>> Surely there must be some assumptiong on channel conditions, > >> >> >>> otherwise how could you plan a system? > > >> >> >> ZigBee uses the same band as 802.11. When you use 802.11 indoors do > >> >> >> you have any clue in advance how well its going to work? > > >> >> >You have a pretty good idea what the ranges will be. > > >> >> Yes, but not the channel conditions. &#4294967295; The variation in fading in > >> >> PAN/LAN environments is very broad, and it's anybody's bet what sort > >> >> of throughput/performance one will get for a given link at whatever > >> >> expected range. &#4294967295; e.g., basic low-power Zigbee is only really expected > >> >> to work for ranges of about 3ft to maybe 10m. &#4294967295; Whether one gets the > >> >> 3ft or the 10m just depends on the environment. &#4294967295;Likewise with 802.11; > >> >> how many walls, how close are they, what's the reflective environment, > >> >> etc., etc. &#4294967295; It all makes a big difference from one link to the next. > > >> >> >> Its easy to produce performance curves for open air > >> >> >> operation. However, if you ask its developers how well ZigBee is going > >> >> >> to work in a real house or office they shrug their shoulders and say > >> >> >> "let's see". > > >> >> >> I don't think anyone has yet planned a ZigBee system. > > >> >> >Surely someone has. I think TI has parts based on the standard. (Their > >> >> >site seems to be down right now). > > >> >> Yes, there are Zigbee products on the market. &#4294967295; They basically work, > >> >> but performance seems to be all over the place. &#4294967295; You can get them > >> >> with 100mW PAs (or more) and try to make them do long range, too. &#4294967295; No > >> >> guarantees, though. &#4294967295;;) > > >> >> Eric Jacobsen > >> >> Minister of Algorithms > >> >> Abineau Communicationshttp://www.ericjacobsen.org > > >> >> Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php-Hidequoted text - > > >> >> - Show quoted text - > > >> >Well, by Shannon Capacity of Zigbee networks, I mean the maximum > >> >achievable data rate for the Zigbee standard. Zigbee has rates up to > >> >250 kbps. Surely there's a physical layer representation of the > >> >maximum achievable date rate for Zigbee considering it's a wireless > >> >technology, uses power and bandwidth. Would it use the common R = w * > >> >log2 ( 1 + P*G/(w*N + I)) bits/sec formula? For the maximum possible > >> >transmit power of 1 mW for the Zigbee standard, distances of say 50 > >> >metres, I'm getting astonishingly high rates in the order of 10^6, not > >> >10^3. > > >> I still don't think the Shannon capacity has any bearing on a defined > >> standard, unless you're interested in how closely the implementation > >> may be able to approach capacity. > > >> A defined maximum data rate of 250kbps sets the max data rate, and the > >> Modulation and Coding Scheme used to achieve that rate sets the > >> performance, less any implementation losses. &#4294967295; If a > >> capacity-approaching code is not used (and Zigbee does not use a > >> capacity-approaching code), then it does not achieve Shannon capacity. > >> I don't recall off the top of my head what coding Zigbee uses, but > >> there's probably at least a 3-6dB gap to capacity at typically > >> measured error rates. &#4294967295; That would also assume a continuous stream, > >> which Zigbee doesn't do. > > >> Bottom line: I don't think Shannon capacity is relevant to a defined > >> standard unless one just cares about how big the gap is to capacity. > > >> Eric Jacobsen > >> Minister of Algorithms > >> Abineau Communicationshttp://www.ericjacobsen.org > > >> Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php-Hide quoted text - > > >> - Show quoted text - > > >Then maybe you can help me Eric. I have a multi-technology network > >where I analyze Zigbee, Ultrawideband and WiMax technologies from a > >routing perspective in software radio networks. I'm optimizing a path > >from a source node of one technology (say Zigbee) to a destination > >that uses another technology (say WiMax) and the nodes in between > >convert transmissions from one technology to another as software > >radios. I'm optimizing transmit power and rate, and am using the > >Shannon capacity to estimate the transmission rates as a physical > >layer representation. I'm able to estimate rates using the Shannon > >formula R = w*log2(1 + P*G(f)/(w*N + I)), but my rates are > >significantly off for Zigbee using the Zigbee parameters for w, max > >transmit power P and frequency f. Can I not use the Shannon formula to > >estimate the transmission rates from a physical layer perspective for > >Zigbee? What about Ultrawideband and WiMax? I haven't been able to > >find any literature on this. > > >Thanks, > >Omar > > Why do you think the Shannon Capacity is a suitable benchmark for your > task? > > Consider that the usual expression for the Shannon Capacity is in > terms of only SNR, i.e., a memoryless AWGN channel, and then consider > that the real-world channels experienced by Zigbee, Ultrawideband and > WiMAX all have memory and fading. &#4294967295; > > If your G(f) term is intended to describe a frequency selective > channel such that water-filling can be considered, it should be noted > that the mentioned technologies don't really do much waterfilling > adaptation. &#4294967295; &#4294967295;WiMAX kinda sorta does sometimes in OFDMA, and > Ultrawideband will occassionally turn off subcarriers, but mostly for > interference purposes rather than propagation channel adaptation. > > As mentioned previously, I don't think Shannon Capacity is revelant to > what you're trying to do. > > From what you've described it sounds like an OpNet simulation or other > suitable simulation might be more appropriate for optimizing your > system. > > Eric Jacobsen > Minister of Algorithms > Abineau Communicationshttp://www.ericjacobsen.org > > Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php- Hide quoted text - > > - Show quoted text -
Hi Eric. I'll be using Opnet but interfacing it to Matlab. The reason I'm using Shannon Capacity is it gives me a physical layer representation, and allows me to optimize physical layer parameters and compute tradeoffs between physical layer resources (bandwidth, power, frequency) in utility functions.
