Rune Allnor wrote:> On 12 Aug, 17:16, c...@claysturner.com wrote:...>> On solar observing I've never gone beyond the simple situation with >> using a dark filter and seeing the sunspots. > > How do you do that? Of course, one needs filters, but do you > see the sunspots with otherwise unaided eyes? Or do you use > telescopes? The only time I saw sunspots was when I served > with the AAA. In those days I used a (filtered) telescope > of 10-15x magnification to spot incoming aircraft.I use some some optical-quality aluminized Mylar as a sus filter. I mount two layers metal-to-metal in an embroidery frame (wrinkles don't matter) that fits my 125-mm scope (a Celestron C5) and also in front of my binoculars. I can see sunspots either way. I can also display sunspots with my 80-mm refractor using eyepiece projection. Check any metalized Mylar that comes your way. Some sole for packaging works very well. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
OT Perseids tonight
Started by ●August 11, 2008
Reply by ●August 12, 20082008-08-12
clay@claysturner.com wrote: ...> But with my 10 inch scope I just project (using an eyepiece) the sun > onto a white card. Typically I project the image where it is around 4 > to 6 inches in diameter and the spots are quite visable.Is that a 10" refractor? I thought tracking the sun with a reflector would fry the secondary.> There are comercial filters that go in front of the scope that > effectively reduce the light level down to a safe one. But I haven't > invested in one of those. Although some are reasonably priced.Baader makes Mylar filters and Thousand Oaks makes glass for a bit more. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 13, 20082008-08-13
On Aug 12, 8:46�pm, Jerry Avins <j...@ieee.org> wrote:> c...@claysturner.com wrote: > > � �... > > > But with my 10 inch scope I just project (using an eyepiece) the sun > > onto a white card. Typically I project the image where it is around 4 > > to 6 inches in diameter and the spots are quite visable. > > Is that a 10" refractor? I thought tracking the sun with a reflector > would fry the secondary. > > > There are comercial filters that go in front of the scope that > > effectively reduce the light level down to a safe one. But I haven't > > invested in one of those. Although some are reasonably priced. > > Baader makes Mylar filters and Thousand Oaks makes glass for a bit more. > > � �... > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������Mine is a 10 inch reflector - actually a Schmidt Newtonian. The secondary is large and I haven't had an issue with overheating. But I'll keep that in mind. Maybe I'll make a cap with a three inch hole in it which will effectively reduce the scope not only to a Herschel design but will alleviate the potential overheating. Clay
On 12 Aug, 21:46, c...@claysturner.com wrote:> comments mixed in below > > > > > If you ever get to see the *really* spectacular Aurora, that will > > be a show you will never forget. I were travelling in the far north > > during the previous sunspot maximum around 2000, and got to see > > some stuff that can only be compared to the neon signd in one > > of the big cities. But we were at one of the remote, almost > > uninhabited islands far out to sea. > > > If you have the chance, go see it. But do time a trip correctly, > > during a sunspot maximum, and go somewhere inland, where the > > climate and weather is favorable for astronomy. > > I'll have to plan a trip to Alaska with the sunspot cycle in mind. > I've always wanted to visit Alaska anyway. This will be an additional > reason.Just remember that the latitudes where the Aurora is visible is so far north that there will be midnight sun (or at least 'almost daylight') in the summer. The Aurora is almost exclusively visible in winter time. It can be a bit cold under clear skies at night in winter... Rune
