scrambling/whitening
Started by ashu August 13, 2008
I am trying to understand, how does scrambling and whitening work in
my system.
From what I understand its also called whitening and used for clock
recovery.
Any good books or articles on this subject ?
Can some one tell me how can we find out which scrambling algorithm is
being used in a system by some reverse engineering ?
regards
ashu
On Aug 13, 9:54&#4294967295;am, ashu <ashutosh.ghildi...@gmail.com> wrote:
> I am trying to understand, how does scrambling and whitening work in > my system. > > From what I understand its also called whitening and used for clock > recovery. > > Any good books or articles on this subject ? > > Can some one tell me how can we find out which scrambling algorithm is > being used in a system by some reverse engineering ? > > regards > ashu
What is "your system"? Dirk
Its wireless transceiver where data is scrambled, after the reed
solomon and crc.
I just want to know how can we determine the scrambling algorithm of a
given system.
Any literature or tutorial on this subject is also welcome :)
thanks
On Aug 13, 4:41 pm, dbell <bellda2...@cox.net> wrote:
> On Aug 13, 9:54 am, ashu <ashutosh.ghildi...@gmail.com> wrote: > > > I am trying to understand, how does scrambling and whitening work in > > my system. > > > From what I understand its also called whitening and used for clock > > recovery. > > > Any good books or articles on this subject ? > > > Can some one tell me how can we find out which scrambling algorithm is > > being used in a system by some reverse engineering ? > > > regards > > ashu > > What is "your system"? > > Dirk
My suggestion would be to first identify the system and then search
the documentation for that system.   If it's a standardized system
(e.g., WiFi, BlueTooth, Intelsat, DVB, whatever), then the scrambler
will be defined in the standard documents.   If it's a generic silicon
solution the scrambler should be defined in the product documentation.
On Wed, 13 Aug 2008 08:40:39 -0700 (PDT), ashu
<ashutosh.ghildiyal@gmail.com> wrote:
>Its wireless transceiver where data is scrambled, after the reed >solomon and crc. > >I just want to know how can we determine the scrambling algorithm of a >given system. > >Any literature or tutorial on this subject is also welcome :) > >thanks > >On Aug 13, 4:41 pm, dbell <bellda2...@cox.net> wrote: >> On Aug 13, 9:54 am, ashu <ashutosh.ghildi...@gmail.com> wrote: >> >> > I am trying to understand, how does scrambling and whitening work in >> > my system. >> >> > From what I understand its also called whitening and used for clock >> > recovery. >> >> > Any good books or articles on this subject ? >> >> > Can some one tell me how can we find out which scrambling algorithm is >> > being used in a system by some reverse engineering ? >> >> > regards >> > ashu >> >> What is "your system"? >> >> Dirk
Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
ashu wrote:
> I am trying to understand, how does scrambling > and whitening work in my system.
It spreads out the spectrum. Take the Fourier transform before and after the scrambler, especially for the case of a very simple signal. If the data stream has, for example, a long string of zeros the output might be a single sine wave with no transitions. Scrambling adds transitions which allow the clock recovery logic to sync to those transitions. Whitening spreads out the spectrum and reduces the problems of interference. -- glen
Eric Jacobsen wrote:
> My suggestion would be to first identify the system and then search > the documentation for that system. If it's a standardized system > (e.g., WiFi, BlueTooth, Intelsat, DVB, whatever), then the scrambler > will be defined in the standard documents. If it's a generic silicon > solution the scrambler should be defined in the product documentation.
And if it's a secure telephone, NSA might have some declassifies papers. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
My thanks to all of you.
Well my system is a medical transceiver, but they haven't given the
specifications of how they implement scrambling.
All they say is, they use some pseudo noise method to implement
scrambling at the transmission end , to ensure we recover clock at the
receiving end.
I can by pass this scrambling block and see the normal packet(without
scrambling) by setting some bits in configuration register of my chip.
Any thoughts on how to find out, what scrambling algorithm they use,
using some reverse engineering ? As I have mentioned earlier I can by
pass scrambling and see the unscrambled output on logic analyzer.
regards
ashu
Can I do some reverse engineering to find out how
On Aug 14, 1:37 am, Jerry Avins <j...@ieee.org> wrote:
> Eric Jacobsen wrote: > > My suggestion would be to first identify the system and then search > > the documentation for that system. If it's a standardized system > > (e.g., WiFi, BlueTooth, Intelsat, DVB, whatever), then the scrambler > > will be defined in the standard documents. If it's a generic silicon > > solution the scrambler should be defined in the product documentation. > > And if it's a secure telephone, NSA might have some declassifies papers. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Thu, 14 Aug 2008 01:46:29 -0700 (PDT), ashu
>My thanks to all of you. > >Well my system is a medical transceiver, but they haven't given the >specifications of how they implement scrambling. > >All they say is, they use some pseudo noise method to implement >scrambling at the transmission end , to ensure we recover clock at the >receiving end. > >I can by pass this scrambling block and see the normal packet(without >scrambling) by setting some bits in configuration register of my chip. > >Any thoughts on how to find out, what scrambling algorithm they use, >using some reverse engineering ? As I have mentioned earlier I can by >pass scrambling and see the unscrambled output on logic analyzer. > >regards >ashu >
Scramblers are typically LFSRs so it should be possible if you have copies of scrambled and unscrambled data. Can you control the contents of the data packets? i.e., can you put a known sequence through and get the scrambled and uncscrambled versions? Transmitting a low-weight packet, i.e., only a few, widely-spaced ones in a packet otherwise filled with zeroes might help find the length of the scrambler as a start. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Thu, 14 Aug 2008 10:05:00 -0700, Eric Jacobsen
<eric.jacobsen@ieee.org> wrote:
>On Thu, 14 Aug 2008 01:46:29 -0700 (PDT), ashu ><ashutosh.ghildiyal@gmail.com> wrote: > >>My thanks to all of you. >> >>Well my system is a medical transceiver, but they haven't given the >>specifications of how they implement scrambling. >> >>All they say is, they use some pseudo noise method to implement >>scrambling at the transmission end , to ensure we recover clock at the >>receiving end. >> >>I can by pass this scrambling block and see the normal packet(without >>scrambling) by setting some bits in configuration register of my chip. >> >>Any thoughts on how to find out, what scrambling algorithm they use, >>using some reverse engineering ? As I have mentioned earlier I can by >>pass scrambling and see the unscrambled output on logic analyzer. >> >>regards >>ashu >> > >Scramblers are typically LFSRs so it should be possible if you have >copies of scrambled and unscrambled data. Can you control the >contents of the data packets? i.e., can you put a known sequence >through and get the scrambled and uncscrambled versions? > >Transmitting a low-weight packet, i.e., only a few, widely-spaced ones >in a packet otherwise filled with zeroes might help find the length of >the scrambler as a start.
Or, better yet, an all-zero sequence, which might reveal the LFSR polynomial completely. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Eric Jacobsen <eric.jacobsen@ieee.org> wrote in
news:p749a49u3ngo7ft85bsq5cgpov1k1oheka@4ax.com:
> On Thu, 14 Aug 2008 10:05:00 -0700, Eric Jacobsen > <eric.jacobsen@ieee.org> wrote: > >>On Thu, 14 Aug 2008 01:46:29 -0700 (PDT), ashu >><ashutosh.ghildiyal@gmail.com> wrote: >> >>>My thanks to all of you. >>> >>>Well my system is a medical transceiver, but they haven't given the >>>specifications of how they implement scrambling. >>> >>>All they say is, they use some pseudo noise method to implement >>>scrambling at the transmission end , to ensure we recover clock at the >>>receiving end. >>> >>>I can by pass this scrambling block and see the normal packet(without >>>scrambling) by setting some bits in configuration register of my chip. >>> >>>Any thoughts on how to find out, what scrambling algorithm they use, >>>using some reverse engineering ? As I have mentioned earlier I can by >>>pass scrambling and see the unscrambled output on logic analyzer. >>> >>>regards >>>ashu >>> >> >>Scramblers are typically LFSRs so it should be possible if you have >>copies of scrambled and unscrambled data. Can you control the >>contents of the data packets? i.e., can you put a known sequence >>through and get the scrambled and uncscrambled versions? >> >>Transmitting a low-weight packet, i.e., only a few, widely-spaced ones >>in a packet otherwise filled with zeroes might help find the length of >>the scrambler as a start. > > Or, better yet, an all-zero sequence, which might reveal the LFSR > polynomial completely.
The Berlekamp-Massey algorithm can help here. http://en.wikipedia.org/wiki/Berlekamp-Massey_algorithm Regards, Allan
