Dear all, I have to develop an application with the following basic requirements: - 40 analog channels of Voltage/Current - ADC with 16 bits of resolution - at least 96 sample point per cycle (50 and 60Hz), which means 4800 and 5760Hz of sampling frequency - simultaneous sampling of all channels The main concern is data acquisition. It is a like a data logger. Since a lot of math must be performed per cycle using the acquired data, I start looking for a DSP solution, but it is important to integrate with a uC in order to provide further features of an embedded system, such as keypad, LCD, Ethernet, GPIO, etc. My question is: does any one knows a good start/development kit with good availability of tools that integrate the ADC capabilities as mentioned before? Or I have to start looking for separate ADC capabilities? Thanks for your attention. Best regards, Roger
Data Acquisition
Started by ●August 13, 2008
Reply by ●August 13, 20082008-08-13
rogerdff wrote:> I have to develop an application with the following basic requirements: > - 40 analog channels of Voltage/Current > - ADC with 16 bits of resolution > - at least 96 sample point per cycle (50 and 60Hz), which > means 4800 and 5760Hz of sampling frequency > - simultaneous sampling of all channels > > The main concern is data acquisition. > It is a like a data logger. > > Since a lot of math must be performed per cycle using the acquired data, I > start looking for a DSP solution, but it is important to integrate with a > uC in order to provide further features of an embedded system, such as > keypad, LCD, Ethernet, GPIO, etc. > > My question is: does any one knows a good start/development kit with good > availability of tools that integrate the ADC capabilities as mentioned > before? Or I have to start looking for separate ADC capabilities? > > Thanks for your attention. > Best regards, RogerIf you can tolerate working in Labview and you don't need large quantities, you might want to consider NI's compactRIO. http://www.ni.com/compactrio/ Lots of configuration, FPGA an option, trade-off is dev. time vs cost, (it ain't cheap).
On Aug 13, 11:47 am, "rogerdff" <roger...@hotmail.com> wrote:> Dear all, > > I have to develop an application with the following basic requirements: > - 40 analog channels of Voltage/Current > - ADC with 16 bits of resolution > - at least 96 sample point per cycle (50 and 60Hz), which > means 4800 and 5760Hz of sampling frequency > - simultaneous sampling of all channels > > The main concern is data acquisition. > > It is a like a data logger. > > Since a lot of math must be performed per cycle using the acquired data, I > start looking for a DSP solution, but it is important to integrate with a > uC in order to provide further features of an embedded system, such as > keypad, LCD, Ethernet, GPIO, etc. > > My question is: does any one knows a good start/development kit with good > availability of tools that integrate the ADC capabilities as mentioned > before? Or I have to start looking for separate ADC capabilities? > > Thanks for your attention. > > Best regards, > > RogerHi Roger, Have you considered adding a set of data aquisition cards to a high- performance desktop PC? For example, maybe you could use four M-Audio cards (http://www.m-audio.com/products/en_us/Delta1010LT-main.html, $250 each) for data aquisition, though I'm not sure that this particular card would meet your simultaneous sampling requirement - but there are other ADC card options. A modern PC may have the horsepower to do the DSP at your low sample rates. There are DSP libraries that exploit the vector processing units of Intel processors. Obviously, a desktop PC is not a hard real- time system, but you may find it good enough, especially if you have a way of flagging and recovering from input buffer overflows. Darol Klawetter
Reply by ●August 14, 20082008-08-14
First of all, thanks for the replies so far. Actually, we need to develop a final product with all the embedded hardware designed in a case: PCB for the controller and for the input/output modules. The NI solution is very interesting and fast, but as far as I could understand I will have to start from "zero" to design the final hardware. For this reason, it is important to start working with a development kit that offers most of the needed devices. The Labview is being considered to develop a prototype. A DAC board is being considered to generate the analog signals (simulating a conditioned signal) used for the ADC inputs. Then, the digitalized signal is going to be fed (using SPI, Parallel, etc) to the controller. For the controller, I have seen so far two options: 1. From Atmel, the DIOPSIS 940HF 2. From TI, the TMS320F3812 cause both combine DSP and uC. For the ADC, I am looking for an evaluation board that offers simultaneous sampling for many channels (preferably as many as possible, since we need at least 40 analog channels). So far, I found some options from TI: - ADS8365, but uses parallel output - ADS1178, that uses SPI Since a lot of data is to be stored, it is also important to have at least 16-32Mb of SRAM, and a higher mass storage media such as SD cards of 2-4GB. Digital input varying from 24 to 250Vdc is also needed: at least 2 times the number of analog channels, which means at least 80 DI. Again, for the prototype, a DO board with Labview is being considered. Digital output for alarm purposes is also considered. Communications features (Ethernet, USB) is basic requirement, as it is also a keypad, LCD, etc. When the prototype with the "final" firmware is designed, then the final PCB input modules together with the controller PCB will be developed. The test will be carried out using a digital box capable to generate the real analog values coming from the field: currents ranging from 1 to 20pu (1 pu equals to 1 or 5A) and voltages ranging from 1 to 2pu (1 pu equals to 66 or 115V). But for prototyping, the ADC board and the controller are the critical hardware components that I need to define until next week. Well, that is the "architecture" we have envisaged so far. Any ideas are welcomed. Hope I was clear enough. Any other detail, please, just ask me. Thanks again for all.
