Hello, I am currently doing a research on the above subject. I am not sure about the level of decomposition during wavelet transform. What is the reasonable number of levels to decompose for image denoising? Thanks.
Image Denoising and Wavelet Thresholding
Started by ●August 16, 2008
Reply by ●September 2, 20082008-09-02
On 16 Srp, 13:38, Bumbala <bumb...@gmail.com> wrote:> Hello, > > I am currently doing a research on the above subject. I am not sure > about the level of decomposition during wavelet transform. What is the > reasonable number of levels to decompose forimagedenoising? > > Thanks.Hi there, it depends on wavelet you use. I used BayesShrink method with daubechies7 wavelets and the level 5 was enough. Btw wavelet denoising is not the state-of-the-art. Better is for example NonLocalMeans. My implementation is at www.adptools.com Filip
Reply by ●September 11, 20082008-09-11
>On 16 Srp, 13:38, Bumbala <bumb...@gmail.com> wrote: >> Hello, >> >> I am currently doing a research on the above subject. I am not sure >> about the level of decomposition during wavelet transform. What is the >> reasonable number of levels to decompose forimagedenoising? >> >> Thanks. > >Hi there, > it depends on wavelet you use. I used BayesShrink method with >daubechies7 wavelets and the level 5 was enough. Btw wavelet denoising >is not the state-of-the-art. Better is for example NonLocalMeans. My >implementation is at www.adptools.com > >Filip >Hi Please do trail and error method until you get minimum Mean Square Error.Once you cant get more less than previous MSE then stop at that level. Different will work differently, for different wavelets it is different. Thanks Naresh
Reply by ●September 15, 20082008-09-15
> Hi > Please do trail and error method until you get minimum Mean Square > Error.Once you cant get more less than previous MSE then stop at that > level. Different will work differently, for different wavelets it is > different. > > Thanks > NareshHi, do you want to minimize MSE to what? MSE is zero to noised image and you dont know denoised image ... Well, I dont really understand what you mean. F.
