Amplitude compression
Started by Richard Owlett ●August 17, 2008
I'm plotting a time series of fft's, similar to spectrograms but in 3D.
If I use a linear scale I clearly see details of primary signal.
But If I use a log scale I can now see the existence of much smaller
features but at the expense of losing detail of the larger features.
Are there any common methods for dealing with this problem?
As I'm looking at only the magnitude of the fft, my data is _strictly_
positive. I've experimented with simplistic compression.
For an input "x" I've experimented with a gain of form
gain = k*((max(x)-x)/max(x))^n
The results weren't great, but they were encouraging.
It did highlight a potential complication.
I will want something similar to the attack and release(???) settings of
  AGC. But it will have to be dependent on time and frequency. To really
mix metaphors, it will be dependent on radial distance in the time vs
frequency plane. (as I have stored data, looking to the future is allowed ;)
Comments?
Richard Owlett wrote:
> > I'm plotting a time series of fft's, similar to spectrograms but in 3D. > If I use a linear scale I clearly see details of primary signal. > But If I use a log scale I can now see the existence of much smaller > features but at the expense of losing detail of the larger features. > > Are there any common methods for dealing with this problem?
It isn't clear what "this problem" is. Statements like "primary signal" and "smaller features" sound like value judgments. My guess is your criteria for those judgments is time. Is the primary signal something you perceive as lasting a while and the smaller features are more transient and appear only for a short while?. If so perhaps a running average of the log scale representation would be the way achieve a happier median between smaller and larger features. Of course the ideal length for the running average would need to be determined. The longer your running average the more the long term features would be enhanced at the expense of short term features. -jim
> > As I'm looking at only the magnitude of the fft, my data is _strictly_ > positive. I've experimented with simplistic compression. > > For an input "x" I've experimented with a gain of form > > gain = k*((max(x)-x)/max(x))^n > > The results weren't great, but they were encouraging. > It did highlight a potential complication. > I will want something similar to the attack and release(???) settings of > AGC. But it will have to be dependent on time and frequency. To really > mix metaphors, it will be dependent on radial distance in the time vs > frequency plane. (as I have stored data, looking to the future is allowed ;) > > Comments?
----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= - Total Privacy via Encryption =---
jim wrote:
> > Richard Owlett wrote: > >>I'm plotting a time series of fft's, similar to spectrograms but in 3D. >>If I use a linear scale I clearly see details of primary signal. >>But If I use a log scale I can now see the existence of much smaller >>features but at the expense of losing detail of the larger features. >> >>Are there any common methods for dealing with this problem? > > > It isn't clear what "this problem" is. Statements like "primary > signal" and "smaller features" sound like value judgments.
*Definitely* > My guess is your criteria for those judgments is time. No ;) It's more like "hmm there's something going on in the "background" that I didn't expect but may be important". Its amplitude is much smaller than the primary feature but it's also displaced in both time and frequency. Rune had pointed out that he had used spectrograms of the call of an artic loon to illustrate (among other things) overtones. I didn't see it with my presentation method and source recording. While waiting for a better recording I attempted to improve my plot. The strong portion of the loon's call is from 1000-1500 Hz. But there is also something starting near 2200 Hz but offset in time by ~.1 sec. I'm trying to investigate that.
> > Is the primary signal something you perceive as lasting a while and > the smaller features are more transient and appear only for a short > while?. If so perhaps a running average of the log scale > representation would be the way achieve a happier median between > smaller and larger features. Of course the ideal length for the > running average would need to be determined. The longer your running > average the more the long term features would be enhanced at the > expense of short term features. > > -jim > > > >>As I'm looking at only the magnitude of the fft, my data is _strictly_ >>positive. I've experimented with simplistic compression. >> >>For an input "x" I've experimented with a gain of form >> >>gain = k*((max(x)-x)/max(x))^n >> >>The results weren't great, but they were encouraging. >>It did highlight a potential complication. >>I will want something similar to the attack and release(???) settings of >> AGC. But it will have to be dependent on time and frequency. To really >>mix metaphors, it will be dependent on radial distance in the time vs >>frequency plane. (as I have stored data, looking to the future is allowed ;) >> >>Comments? > > > > ----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==---- > http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 Newsgroups > ---= - Total Privacy via Encryption =---
On 17 Aug, 13:29, Richard Owlett <rowl...@atlascomm.net> wrote:
> I'm plotting a time series of fft's, similar to spectrograms but in 3D. > If I use a linear scale I clearly see details of primary signal. > But If I use a log scale I can now see the existence of much smaller > features but at the expense of losing detail of the larger features. > > Are there any common methods for dealing with this problem? > > As I'm looking at only the magnitude of the fft, my data is _strictly_ > positive. I've experimented with simplistic compression. > > For an input "x" I've experimented with a gain of form > > gain = k*((max(x)-x)/max(x))^n > > The results weren't great, but they were encouraging. > It did highlight a potential complication. > I will want something similar to the attack and release(???) settings of > &#4294967295; AGC. But it will have to be dependent on time and frequency. To really > mix metaphors, it will be dependent on radial distance in the time vs > frequency plane. (as I have stored data, looking to the future is allowed ;) > > Comments?
Not that it's common practice, but what about a monotonic increasing function based on a sample amplitude histogram? cheers jacko
> jim wrote: > >> >> Richard Owlett wrote: >> >>> I'm plotting a time series of fft's, similar to spectrograms but in 3D. >>> If I use a linear scale I clearly see details of primary signal. >>> But If I use a log scale I can now see the existence of much smaller >>> features but at the expense of losing detail of the larger features. >>> >>> Are there any common methods for dealing with this problem? >> >> >> >> It isn't clear what "this problem" is. Statements like "primary >> signal" and "smaller features" sound like value judgments. > > > *Definitely* > > > My guess is your criteria for those judgments is time. > > No ;) It's more like "hmm there's something going on in the "background" > that I didn't expect but may be important". Its amplitude is much > smaller than the primary feature but it's also displaced in both time > and frequency. > > Rune had pointed out that he had used spectrograms of the call of an > artic loon to illustrate (among other things) overtones. I didn't see it > with my presentation method and source recording. While waiting for a > better recording I attempted to improve my plot. The strong portion of > the loon's call is from 1000-1500 Hz. But there is also something > starting near 2200 Hz but offset in time by ~.1 sec. I'm trying to > investigate that. >
My ride came so I had to end my last post. While I was out your comment about a "running average" got me thinking on different paths.
>> >> Is the primary signal something you perceive as lasting a while and >> the smaller features are more transient and appear only for a short >> while?.
The projection onto the time-frequency plane are comparable. The only thing definite is that the amplitude of the "smaller" features are smaller.
>> If so perhaps a running average of the log scale >> representation would be the way achieve a happier median between >> smaller and larger features. Of course the ideal length for the >> running average would need to be determined. The longer your running >> average the more the long term features would be enhanced at the >> expense of short term features.
Don't think so. HOWEVER it suggests an idea. For an area whose amplitude is less than some value, give higher gain to a region with a peak whose amplitude is a absolute amount different that the average of a larger surrounding area. [Compare to using a magnifying glass to examine the immediate area of a blip on a topographic map.]
>> >> -jim >> >> >> >>> As I'm looking at only the magnitude of the fft, my data is _strictly_ >>> positive. I've experimented with simplistic compression. >>> >>> For an input "x" I've experimented with a gain of form >>> >>> gain = k*((max(x)-x)/max(x))^n >>> >>> The results weren't great, but they were encouraging. >>> It did highlight a potential complication. >>> I will want something similar to the attack and release(???) settings of >>> AGC. But it will have to be dependent on time and frequency. To really >>> mix metaphors, it will be dependent on radial distance in the time vs >>> frequency plane. (as I have stored data, looking to the future is >>> allowed ;) >>> >>> Comments? >> >> >> >> >> ----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet >> News==---- >> http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 >> Newsgroups >> ---= - Total Privacy via Encryption =---
On Aug 17, 5:29 am, Richard Owlett <rowl...@atlascomm.net> wrote:
> I'm plotting a time series of fft's, similar to spectrograms but in 3D. > If I use a linear scale I clearly see details of primary signal. > But If I use a log scale I can now see the existence of much smaller > features but at the expense of losing detail of the larger features. > > Are there any common methods for dealing with this problem? > > As I'm looking at only the magnitude of the fft, my data is _strictly_ > positive. I've experimented with simplistic compression. > > For an input "x" I've experimented with a gain of form > > gain = k*((max(x)-x)/max(x))^n > > The results weren't great, but they were encouraging. > It did highlight a potential complication. > I will want something similar to the attack and release(???) settings of > AGC. But it will have to be dependent on time and frequency. To really > mix metaphors, it will be dependent on radial distance in the time vs > frequency plane. (as I have stored data, looking to the future is allowed ;) > > Comments?
Richard The common passive sonar approach is to estimate the 'background' of the (possibly time averaged) power spectrum. This has been done across frequency with: 1) boxcar window 2) split window 3) thresholded split window 4) windowed thresholded split window 5) thresholded windowed thresholded split window ... N) median This assumes that the signals of interest are narrower in spectral width than the background features to be removed. The window might be made the full passband. The background estimate can also be averaged in the time domain. For reasons of efficiency, the most common method may have been the exponential averager because of it's controlled variability while requiring minimal storage of history data. Others no doubt work better at greater processing and storage cost. The power spectrum is divided by the background estimate to give an estimate of signal to noise ratio plus 1.0 as: (Sinal + Noise) / Noise-est. => S/N + 1 This assumes the data is still in the linear domain. The plus one is a convenience to assure that the data can then be converted to dB. Plot as you wish. The US and NATO navies have used the above methods. YMMV Dale B. Dalrymple http://dbdimages.com
> > Richard Owlett wrote: > > jim wrote: > > > >> > >> Richard Owlett wrote: > >> > >>> I'm plotting a time series of fft's, similar to spectrograms but in 3D. > >>> If I use a linear scale I clearly see details of primary signal. > >>> But If I use a log scale I can now see the existence of much smaller > >>> features but at the expense of losing detail of the larger features. > >>> > >>> Are there any common methods for dealing with this problem? > >> > >> > >> > >> It isn't clear what "this problem" is. Statements like "primary > >> signal" and "smaller features" sound like value judgments. > > > > > > *Definitely* > > > > > My guess is your criteria for those judgments is time. > > > > No ;) It's more like "hmm there's something going on in the "background" > > that I didn't expect but may be important". Its amplitude is much > > smaller than the primary feature but it's also displaced in both time > > and frequency. > > > > Rune had pointed out that he had used spectrograms of the call of an > > artic loon to illustrate (among other things) overtones. I didn't see it > > with my presentation method and source recording. While waiting for a > > better recording I attempted to improve my plot. The strong portion of > > the loon's call is from 1000-1500 Hz. But there is also something > > starting near 2200 Hz but offset in time by ~.1 sec. I'm trying to > > investigate that. > > > > My ride came so I had to end my last post. While I was out your comment > about a "running average" got me thinking on different paths. > > >> > >> Is the primary signal something you perceive as lasting a while and > >> the smaller features are more transient and appear only for a short > >> while?. > > The projection onto the time-frequency plane are comparable. The only > thing definite is that the amplitude of the "smaller" features are smaller.
I thought you were looking at human voice recordings - I missed that you were looking at a recording of a loon.
> > >> If so perhaps a running average of the log scale > >> representation would be the way achieve a happier median between > >> smaller and larger features. Of course the ideal length for the > >> running average would need to be determined. The longer your running > >> average the more the long term features would be enhanced at the > >> expense of short term features. > > Don't think so. > HOWEVER it suggests an idea. For an area whose amplitude is less than > some value, give higher gain to a region with a peak whose amplitude is > a absolute amount different that the average of a larger surrounding > area. [Compare to using a magnifying glass to examine the immediate area > of a blip on a topographic map.]
That description sounds like an unsharp mask (AKA unsharp filter). Basically you would subtract some weighted amount of the mean in the neighborhood surrounding each point. It's a image processing technique, but what you have is equivalent to a grayscale bitmap. I assume your 3d surface is a uniform 2d grid with each point having its own z height. -jim ----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= - Total Privacy via Encryption =---
jim wrote:
> > Richard Owlett wrote: > >>Richard Owlett wrote: >> >>>jim wrote: >>> >>> >>>>Richard Owlett wrote: >>>> >>>> >>>>>I'm plotting a time series of fft's, similar to spectrograms but in 3D. >>>>>If I use a linear scale I clearly see details of primary signal. >>>>>But If I use a log scale I can now see the existence of much smaller >>>>>features but at the expense of losing detail of the larger features. >>>>> >>>>>Are there any common methods for dealing with this problem? >>>> >>>> >>>> >>>>It isn't clear what "this problem" is. Statements like "primary >>>>signal" and "smaller features" sound like value judgments. >>> >>> >>>*Definitely* >>> >>> > My guess is your criteria for those judgments is time. >>> >>>No ;) It's more like "hmm there's something going on in the "background" >>>that I didn't expect but may be important". Its amplitude is much >>>smaller than the primary feature but it's also displaced in both time >>>and frequency. >>> >>>Rune had pointed out that he had used spectrograms of the call of an >>>artic loon to illustrate (among other things) overtones. I didn't see it >>>with my presentation method and source recording. While waiting for a >>>better recording I attempted to improve my plot. The strong portion of >>>the loon's call is from 1000-1500 Hz. But there is also something >>>starting near 2200 Hz but offset in time by ~.1 sec. I'm trying to >>>investigate that. >>> >> >>My ride came so I had to end my last post. While I was out your comment >>about a "running average" got me thinking on different paths. >> >> >>>> Is the primary signal something you perceive as lasting a while and >>>>the smaller features are more transient and appear only for a short >>>>while?. >> >>The projection onto the time-frequency plane are comparable. The only >>thing definite is that the amplitude of the "smaller" features are smaller. > > > I thought you were looking at human voice recordings - I missed that > you were looking at a recording of a loon.
This is a rabbit trail did start with an interest in speech recognition.
> > > >>>>If so perhaps a running average of the log scale >>>>representation would be the way achieve a happier median between >>>>smaller and larger features. Of course the ideal length for the >>>>running average would need to be determined. The longer your running >>>>average the more the long term features would be enhanced at the >>>>expense of short term features. >> >>Don't think so. >>HOWEVER it suggests an idea. For an area whose amplitude is less than >>some value, give higher gain to a region with a peak whose amplitude is >>a absolute amount different that the average of a larger surrounding >>area. [Compare to using a magnifying glass to examine the immediate area >>of a blip on a topographic map.] > > > That description sounds like an unsharp mask (AKA unsharp filter). > Basically you would subtract some weighted amount of the mean in the > neighborhood surrounding each point. It's a image processing > technique, but what you have is equivalent to a grayscale bitmap. I > assume your 3d surface is a uniform 2d grid with each point having its > own z height. > > -jim >
That gives me some key words to Google with. Thanks.
dbd wrote:
> On Aug 17, 5:29 am, Richard Owlett <rowl...@atlascomm.net> wrote: > >>I'm plotting a time series of fft's, similar to spectrograms but in 3D. >>If I use a linear scale I clearly see details of primary signal. >>But If I use a log scale I can now see the existence of much smaller >>features but at the expense of losing detail of the larger features. >> >>Are there any common methods for dealing with this problem? >> >>As I'm looking at only the magnitude of the fft, my data is _strictly_ >>positive. I've experimented with simplistic compression. >> >>For an input "x" I've experimented with a gain of form >> >>gain = k*((max(x)-x)/max(x))^n >> >>The results weren't great, but they were encouraging. >>It did highlight a potential complication. >>I will want something similar to the attack and release(???) settings of >> AGC. But it will have to be dependent on time and frequency. To really >>mix metaphors, it will be dependent on radial distance in the time vs >>frequency plane. (as I have stored data, looking to the future is allowed ;) >> >>Comments? > > > Richard > > The common passive sonar approach is to estimate the 'background' of > the (possibly time averaged) power spectrum. This has been done across > frequency with: > 1) boxcar window > 2) split window > 3) thresholded split window > 4) windowed thresholded split window > 5) thresholded windowed thresholded split window > ... > N) median
What is "split window"?
> > This assumes that the signals of interest are narrower in spectral > width than the background features to be removed. The window might be > made the full passband.
I'm not sure if we use "feature" in the same sense. For each time slice, I FFT the input. A particular bin _may_ be in a feature if above a threshold value. To be a feature bin(s) in adjacent slice(s) must also be above threshold. [e.g. artic loon's call goes up in frequency with time]
> > The background estimate can also be averaged in the time domain. For > reasons of efficiency, the most common method may have been the > exponential averager because of it's controlled variability while > requiring minimal storage of history data. Others no doubt work better > at greater processing and storage cost.
I'm working with stored data so time is not a tight constraint. I can hold the equivalent of ~8-10 copies of data in memory.
> > The power spectrum is divided by the background estimate to give an > estimate of signal to noise ratio plus 1.0 as: > (Sinal + Noise) / Noise-est. => S/N + 1
That gives me an idea. If the value in a bin is below a threshold, I can set it to an "out of range" value. Scilab's plot command can be set to ignore those points.
> > This assumes the data is still in the linear domain. The plus one is a > convenience to assure that the data can then be converted to dB. Plot > as you wish. > > The US and NATO navies have used the above methods. > > YMMV > > Dale B. Dalrymple > http://dbdimages.com >
jim wrote:
> > Richard Owlett wrote: > >>Richard Owlett wrote: >> >>>jim wrote: >>> >>> >>>>Richard Owlett wrote: >>>> >>>> >>>>>I'm plotting a time series of fft's, similar to spectrograms but in 3D. >>>>>If I use a linear scale I clearly see details of primary signal. >>>>>But If I use a log scale I can now see the existence of much smaller >>>>>features but at the expense of losing detail of the larger features. >>>>> >>>>>Are there any common methods for dealing with this problem? >>>> >>>> >>>> >>>>It isn't clear what "this problem" is. Statements like "primary >>>>signal" and "smaller features" sound like value judgments. >>> >>> >>>*Definitely* >>> >>> > My guess is your criteria for those judgments is time. >>> >>>No ;) It's more like "hmm there's something going on in the "background" >>>that I didn't expect but may be important". Its amplitude is much >>>smaller than the primary feature but it's also displaced in both time >>>and frequency. >>> >>>Rune had pointed out that he had used spectrograms of the call of an >>>artic loon to illustrate (among other things) overtones. I didn't see it >>>with my presentation method and source recording. While waiting for a >>>better recording I attempted to improve my plot. The strong portion of >>>the loon's call is from 1000-1500 Hz. But there is also something >>>starting near 2200 Hz but offset in time by ~.1 sec. I'm trying to >>>investigate that. >>> >> >>My ride came so I had to end my last post. While I was out your comment >>about a "running average" got me thinking on different paths. >> >> >>>> Is the primary signal something you perceive as lasting a while and >>>>the smaller features are more transient and appear only for a short >>>>while?. >> >>The projection onto the time-frequency plane are comparable. The only >>thing definite is that the amplitude of the "smaller" features are smaller. > > > I thought you were looking at human voice recordings - I missed that > you were looking at a recording of a loon. > > > >>>>If so perhaps a running average of the log scale >>>>representation would be the way achieve a happier median between >>>>smaller and larger features. Of course the ideal length for the >>>>running average would need to be determined. The longer your running >>>>average the more the long term features would be enhanced at the >>>>expense of short term features. >> >>Don't think so. >>HOWEVER it suggests an idea. For an area whose amplitude is less than >>some value, give higher gain to a region with a peak whose amplitude is >>a absolute amount different that the average of a larger surrounding >>area. [Compare to using a magnifying glass to examine the immediate area >>of a blip on a topographic map.] > > > That description sounds like an unsharp mask (AKA unsharp filter). > Basically you would subtract some weighted amount of the mean in the > neighborhood surrounding each point. It's a image processing > technique, but what you have is equivalent to a grayscale bitmap. I > assume your 3d surface is a uniform 2d grid with each point having its > own z height. >
Googled. YES! http://tavmjong.free.fr/INKSCAPE/MANUAL/html/Filters-Pixel.html has a tantalizing description. The hits are either for canned programs of research discussions. Any suggestions for introductory material that's not tied to a specific program. Meanwhile I'll wander Scilab toolboxes for image manipulation routines.
