Simple DirectX development platform?
Started by Rob ●August 18, 2008
Someone must have coded a simple framework for testing DSP code under
Windows. Seems like it should be possible to simply set a buffer size,
then trigger a user-coded function to work on the buffer when it was
filled.
Does this exist?
Rob wrote:
> Someone must have coded a simple framework for testing DSP code under > Windows. Seems like it should be possible to simply set a buffer size, > then trigger a user-coded function to work on the buffer when it was > filled. > > Does this exist?
The WinAmp DSP-Plugin interface is as easy as it can get.. Regards, Nils
Rob wrote:
> Someone must have coded a simple framework for testing DSP code under > Windows. Seems like it should be possible to simply set a buffer size, > then trigger a user-coded function to work on the buffer when it was > filled. > > Does this exist? >
What's the significance for you of DirectX? The standard audio plugin API within that is DirectSound (and DirectShow for plugins), and the newer ("simpler") DMO interface. Nobody generally regards those as "simple" however! Do you (a) know about and (b) like COM? By far the easiest and quickest way to get real-time audio effects going on Windows is to use VST (Steinberg). You don't need to write a GUI as all hosts are required to be able to supply a default one; loads of free hosts are available. Initialize the effect in Resume(), and implement the dsp in ProcessReplacing(), add Set/GetParameter() code as you need. (NB VST is now up to v3.0 and in a very different more COM-like form (not backwards-compatible) from before. You may well prefer to get hold of 2.4 or even 2.3, which fit my description above). It all depends on exactly what you want to do. There are other solutions, such as PD (wire up elements, or write an external) and Csound (write an opcode, or create a User-Defined opcode or UDO), where you can step through the host code too if need be. Not particularly trivial to build those, however. You can even do it just using Portaudio; put your dsp code in the callback function and run the whole thing e.g. as a combo soundfile player + effect. Would take more work to do an interactive one though. Richard Dobson
On Mon, 18 Aug 2008 12:12:38 +0100, Richard Dobson
<richarddobson@blueyonder.co.uk> wrote:
>Rob wrote: >> Someone must have coded a simple framework for testing DSP code under >> Windows. Seems like it should be possible to simply set a buffer size, >> then trigger a user-coded function to work on the buffer when it was >> filled. >> >> Does this exist? >> >What's the significance for you of DirectX? The standard audio plugin >API within that is DirectSound (and DirectShow for plugins), and the >newer ("simpler") DMO interface. Nobody generally regards those as >"simple" however! Do you (a) know about and (b) like COM?
(a) = yes. (b) = no. No one likes COM. <g> I've worked with DShow via C# interface, and it's a world of difference. I was hoping for something like that. I could probably write it without too much trouble, but would prefer not to, given a choice. I'd love to figure out how to get DSP code running in C#, but of course it wouldn't be portable. Richard Grimes (C++/C# guru) got impressive benchmarks with Fourier transform code in C#.
>By far the easiest and quickest way to get real-time audio effects going >on Windows is to use VST (Steinberg). You don't need to write a GUI as >all hosts are required to be able to supply a default one; loads of free >hosts are available. Initialize the effect in Resume(), and implement >the dsp in ProcessReplacing(), add Set/GetParameter() code as you need.
I've been meaning to learn about the VST interface anyway. So maybe that's the way to go then. I doubt the transition to .NET/C# code would be possible, but there are other advantages.
>(NB VST is now up to v3.0 and in a very different more COM-like form >(not backwards-compatible) from before. You may well prefer to get hold >of 2.4 or even 2.3, which fit my description above).
Why would they do that in 3.0? Sounds like a step backwards.
>It all depends on exactly what you want to do. There are other >solutions, such as PD (wire up elements, or write an external) and
PD stands for...?
>Csound (write an opcode, or create a User-Defined opcode or UDO), where >you can step through the host code too if need be. Not particularly >trivial to build those, however.
Yeah, less interested in CSound.
>You can even do it just using Portaudio; put your dsp code in the >callback function and run the whole thing e.g. as a combo soundfile >player + effect. Would take more work to do an interactive one though. > >Richard Dobson
I'll check Portaudio as well. Thanks for the detailed reply, Richard. Sounds like you've written VST's then?
Rob wrote:
> I'd love to figure out how to get DSP code running in C#, but of > course it wouldn't be portable.
Portability is essential for what I do (working on both Windows and OS X, as well as Linux occasionally). I have never looked at C#; presumably it at least as efficient as Java, but I would still expect code in C ("closer to the hardware") to be faster. To say nothing here about hand-assembly! ..
>> (NB VST is now up to v3.0 and in a very different more COM-like form >> (not backwards-compatible) from before. You may well prefer to get hold >> of 2.4 or even 2.3, which fit my description above). > > Why would they do that in 3.0? Sounds like a step backwards. >
You may very well ask. There was plenty of debate on the vst-dev list when it was launched. I think it would be fair to say opinions are divided. 3.0 does give a better separation between dsp thread(s) and editor thread(s), which matters these days when plugins may be running across multiple machines. It also defines side-chains properly in a way that previous versions did not. I have not yet progressed beyond 2.4 myself!
>> It all depends on exactly what you want to do. There are other >> solutions, such as PD (wire up elements, or write an external) and > > PD stands for...? >
Sorry - Pure Data - a free (GPL) alternative to MAX/MSP (graphical audio/MIDI programming system), developed and maintained by Miller Puckette plus others: http://puredata.info ..
> I'll check Portaudio as well. Thanks for the detailed reply, Richard. > Sounds like you've written VST's then?
Yes, mostly using the phase vocoder. There are a few freebies of mine floating around cyberspace. Done some commercial work too, from time to time (i.e. stuff bundled with some app). Next upcoming challenge is AudioUnits and CoreAudio on the Mac, which will probably mean getting into Objective C. The main inhibiting factor for me (aside from being a dsp novice) is designing GUIs, as I am rubbish at graphic design. Slowly learning Photoshop at the moment. Good luck with your projects! Richard Dobson
Rob wrote:
> On Mon, 18 Aug 2008 12:12:38 +0100, Richard Dobson > <richarddobson@blueyonder.co.uk> wrote: > >> Rob wrote: >>> Someone must have coded a simple framework for testing DSP code under >>> Windows. Seems like it should be possible to simply set a buffer size, >>> then trigger a user-coded function to work on the buffer when it was >>> filled. >>> >>> Does this exist? >>> >> What's the significance for you of DirectX? The standard audio plugin >> API within that is DirectSound (and DirectShow for plugins), and the >> newer ("simpler") DMO interface. Nobody generally regards those as >> "simple" however! Do you (a) know about and (b) like COM? > > (a) = yes. (b) = no. No one likes COM. <g>
That's why I recommended the winamp plugin interface. It's all C language if you want to. All you have to do is to export three functins from a DLL and that's it. You can open a window to tweak parameters if you want to, but that's not required. The bare minimum are two dummy-functions and one process-function. The workflow is nice as well if you're willing to add a post-build step. It's my prefered platform if I tinker around with sound. You're also not limited to playback of media-files. If you want to you can use line-in as the audio-source and connect whatever signal-generator you want to your "work in progress"-plugin. Nils
On Tue, 19 Aug 2008 21:26:00 +0200, Nils <n.pipenbrinck@cubic.org>
wrote:
>Rob wrote:
>> (re: Do you (a) know about and (b) like COM?) >> >> (a) = yes. (b) = no. No one likes COM. <g>
>That's why I recommended the winamp plugin interface. > >It's all C language if you want to. All you have to do is to export >three functins from a DLL and that's it. You can open a window to tweak >parameters if you want to, but that's not required. The bare minimum are >two dummy-functions and one process-function.
That certainly sounds about as simple as it could get. I admit to being put off by Winamp after a couple bad experiences with intrusive installs. Have they corrected that? Any opinion on the best version to use?
>The workflow is nice as well if you're willing to add a post-build step. > >It's my prefered platform if I tinker around with sound. You're also not >limited to playback of media-files. If you want to you can use line-in >as the audio-source and connect whatever signal-generator you want to >your "work in progress"-plugin.
Also good to know. I didn't realize that there was a line in. Thanks, Nils.
On Tue, 19 Aug 2008 10:51:50 +0100, Richard Dobson
>Rob wrote: >.. >> I'd love to figure out how to get DSP code running in C#, but of >> course it wouldn't be portable. > > >Portability is essential for what I do (working on both Windows and OS >X, as well as Linux occasionally). I have never looked at C#; presumably >it at least as efficient as Java, but I would still expect code in C >("closer to the hardware") to be faster. To say nothing here about >hand-assembly!
They say that C# can be faster than C for this reason: The "JIT" compiler checks the type of machine that it's currently running on, and then optimizes for the architecture of that machine. Apparently they've got some very clever optimizations in place, so this could be significant. The code gets compiled the first time it is run, so the initial run is sort of interpreted. But then all subsequent runs are executing tightly compiled machine code. The code can also be designated to be 'pre-compiled' so there is no impact on the initial execution. This is why Richard Grimes and others have reported good benchmarks with DSP-type code. Not sure if Java has anything like that in place.
>>> (NB VST is now up to v3.0 and in a very different more COM-like form >>> (not backwards-compatible) from before. You may well prefer to get hold >>> of 2.4 or even 2.3, which fit my description above). >> >> Why would they do that in 3.0? Sounds like a step backwards.
>You may very well ask. There was plenty of debate on the vst-dev list >when it was launched. I think it would be fair to say opinions are >divided. 3.0 does give a better separation between dsp thread(s) and >editor thread(s), which matters these days when plugins may be running >across multiple machines.
You'd think that they could have accounted for that with a separate dev environment or something. Sounds like they are back to what COM did in the first place, with attendant complications.
>> I'll check Portaudio as well. Thanks for the detailed reply, Richard. >> Sounds like you've written VST's then? > >Yes, mostly using the phase vocoder.
Cool. Did you write a phase vocoder, or were you referring to use of someone's existing code?
> There are a few freebies of mine >floating around cyberspace. Done some commercial work too, from time to >time (i.e. stuff bundled with some app). Next upcoming challenge is >AudioUnits and CoreAudio on the Mac, which will probably mean getting >into Objective C. The main inhibiting factor for me (aside from being a >dsp novice) is designing GUIs, as I am rubbish at graphic design. Slowly >learning Photoshop at the moment.
Now if Adobe could write a GUI. <g> I'm amazed at some of the quirks that have persisted with PS. Luckily, it is not as complex as even rudimentary DSP coding, so you'll be fine. Now that I'm thinking about VST code again: Do you know of any current source code for hosting a VSTi? I'd like to be able to generate note-on/off events from inside one of my programs and get them played back directly. Previous versions did generate MIDI, so the 'event' part is not a problem. IOW, I'd just like to host VSTi's and send MIDI-like commands to them.
On Tue, 19 Aug 2008 14:00:04 -0800, glen herrmannsfeldt
<gah@ugcs.caltech.edu> wrote:
>Rob wrote: >(snip) > >> They say that C# can be faster than C for this reason: The "JIT" >> compiler checks the type of machine that it's currently running on, >> and then optimizes for the architecture of that machine. Apparently >> they've got some very clever optimizations in place, so this could be >> significant. > >It used to be common to compare Java to C++, but not usually C. > >Memory allocation and deallocation tends to be slow, and >object-oriented programming tends to do a lot of it. >C usually doesn't do near as much, and so likely runs >faster for what is otherwise the same algorithm. > >JIT doesn't usually get around the need to do allocation >and deallocation of objects. > >-- glen
Correct, but there are optimization tricks for dealing with memory in C#. A couple of them specifically for 'pinning' allocated code blocks, which allows local handling and prevents the memory manager from moving them. That stuff is necessary when interfacing with legacy code that counts on blocks remaining stationary.
Rob wrote:
(snip)
> They say that C# can be faster than C for this reason: The "JIT" > compiler checks the type of machine that it's currently running on, > and then optimizes for the architecture of that machine. Apparently > they've got some very clever optimizations in place, so this could be > significant.
It used to be common to compare Java to C++, but not usually C. Memory allocation and deallocation tends to be slow, and object-oriented programming tends to do a lot of it. C usually doesn't do near as much, and so likely runs faster for what is otherwise the same algorithm. JIT doesn't usually get around the need to do allocation and deallocation of objects. -- glen
