Hi all, I have a doubt regarding complex exponential in white noise. Almost all of the statistical DSP books state the following. The signal is of the form x(n) = |A|exp(j(nw + phi)) + w(n) and we have to estimate 'w' & 'A' Here 'A'(amplitude) is not a random variable nor is 'w'(freq) phi is mostly taken to be a random variable uniformly distributed between -pi to +pi while w(n) is white gaussian noise with some variance. My doubt is : 1)why phi is always taken as a Uniform RV between limits -pi to +pi? Why phi cannot be a gaussian RV like w(n). Further if phi is a URV between -pi to +pi then the height of pdf is 1/2*pi ie all the phase values between -pi to +pi are equiprobable with probability 1/2*pi.Is this the case with real world signals also or is it only a theoretical convenience? How can a phase error of -pi+/-delta (or +pi+/-delta) be having same probablility as 0+/-delta in a real world signal? 2)Is there any method to check the underlying pdf ( or at least estimate it ) of 'phi' if i have some sample realisations of x(n) with me? Regards, Yogesh P.G.
complex exponential embedded in white noise
Started by ●August 20, 2008
Reply by ●August 20, 20082008-08-20
On Aug 20, 9:29 am, "ypg" <yogesh_ghar...@yahoo.com> wrote:> Hi all, > I have a doubt regarding complex exponential in white noise. Almost > all of the statistical DSP books state the following. > The signal is of the form > x(n) = |A|exp(j(nw + phi)) + w(n) and we have to estimate 'w' & > 'A' > > Here 'A'(amplitude) is not a random variable nor is > 'w'(freq) > phi is mostly taken to be a random variable uniformly distributed > between -pi to +pi while w(n) is white gaussian noise with some variance. > > My doubt is : > 1)why phi is always taken as a Uniform RV between limits -pi to +pi? Why > phi cannot be a gaussian RV like w(n). Further if phi is a URV between -pi > to +pi then the height of pdf is 1/2*pi ie all the phase values between -pi > to +pi are equiprobable with probability 1/2*pi.Is this the case with real > world signals also or is it only a theoretical convenience? How can a phase > error of -pi+/-delta (or +pi+/-delta) be having same probablility as > 0+/-delta in a real world signal?Typically that model is used for communication applications where the transmitter and the receiver have different clocks. So the phase difference is pretty much uniformly distributed, because it's dictated by the relative clocks and the propagation delay. Your model seems to be more for a measurement or acquisition system where there's a lot more synchronicity.> > 2)Is there any method to check the underlying pdf ( or at least estimate > it ) of 'phi' if i have some sample realisations of x(n) with me?Possible, assuming that w[n] is sufficiently small such that the effect of noise on your estimate of \phi is small enough. This is a common problem in modeling, which is that your estimation system has to be sufficiently accurate that it does not dilute the model.
On Wed, 20 Aug 2008 08:17:49 -0700 (PDT), julius <juliusk@gmail.com> wrote:>On Aug 20, 9:29 am, "ypg" <yogesh_ghar...@yahoo.com> wrote: >> Hi all, >> I have a doubt regarding complex exponential in white noise. Almost >> all of the statistical DSP books state the following. >> The signal is of the form >> x(n) = |A|exp(j(nw + phi)) + w(n) and we have to estimate 'w' & >> 'A' >> >> Here 'A'(amplitude) is not a random variable nor is >> 'w'(freq) >> phi is mostly taken to be a random variable uniformly distributed >> between -pi to +pi while w(n) is white gaussian noise with some variance. >> >> My doubt is : >> 1)why phi is always taken as a Uniform RV between limits -pi to +pi? Why >> phi cannot be a gaussian RV like w(n). Further if phi is a URV between -pi >> to +pi then the height of pdf is 1/2*pi ie all the phase values between -pi >> to +pi are equiprobable with probability 1/2*pi.Is this the case with real >> world signals also or is it only a theoretical convenience? How can a phase >> error of -pi+/-delta (or +pi+/-delta) be having same probablility as >> 0+/-delta in a real world signal? > >Typically that model is used for communication applications where >the transmitter and the receiver have different clocks. So the phase >difference is pretty much uniformly distributed, because it's >dictated by the relative clocks and the propagation delay. > >Your model seems to be more for a measurement or acquisition >system where there's a lot more synchronicity.Even if the clocks are perfect and perfectly synchronized, the phase will changed at the receiver as the distance between the transmitter and receiver changes (in perfect LOS conditions). Increasing the range by a wavelength will traverse 2pi of carrier phase spatially. Since range, in terms of wavelength, tends to be uniformly random, phi is random with uniform distribution. Then there's uncertainty in clocks, LO frequencies, multipath, cable lengths, etc., etc., and it's just more clear that phase is completely random with uniform distribution. Another way to look at it is that if phi weren't uniformly random it'd mean that some phase was more likely than the rest. What phase would it be and why is that one more likely? Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Aug 20, 12:29 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> On Wed, 20 Aug 2008 08:17:49 -0700 (PDT), julius <juli...@gmail.com> > wrote: > > > > >On Aug 20, 9:29 am, "ypg" <yogesh_ghar...@yahoo.com> wrote: > >> Hi all, > >> I have a doubt regarding complex exponential in white noise. Almost > >> all of the statistical DSP books state the following. > >> The signal is of the form > >> x(n) = |A|exp(j(nw + phi)) + w(n) and we have to estimate 'w' & > >> 'A' > > >> Here 'A'(amplitude) is not a random variable nor is > >> 'w'(freq) > >> phi is mostly taken to be a random variable uniformly distributed > >> between -pi to +pi while w(n) is white gaussian noise with some variance. > > >> My doubt is : > >> 1)why phi is always taken as a Uniform RV between limits -pi to +pi? Why > >> phi cannot be a gaussian RV like w(n). Further if phi is a URV between -pi > >> to +pi then the height of pdf is 1/2*pi ie all the phase values between -pi > >> to +pi are equiprobable with probability 1/2*pi.Is this the case with real > >> world signals also or is it only a theoretical convenience? How can a phase > >> error of -pi+/-delta (or +pi+/-delta) be having same probablility as > >> 0+/-delta in a real world signal? > > >Typically that model is used for communication applications where > >the transmitter and the receiver have different clocks. So the phase > >difference is pretty much uniformly distributed, because it's > >dictated by the relative clocks and the propagation delay. > > >Your model seems to be more for a measurement or acquisition > >system where there's a lot more synchronicity. > > Even if the clocks are perfect and perfectly synchronized, the phase > will changed at the receiver as the distance between the transmitter > and receiver changes (in perfect LOS conditions). Increasing the > range by a wavelength will traverse 2pi of carrier phase spatially. > > Since range, in terms of wavelength, tends to be uniformly random, phi > is random with uniform distribution. > > Then there's uncertainty in clocks, LO frequencies, multipath, cable > lengths, etc., etc., and it's just more clear that phase is completely > random with uniform distribution. > > Another way to look at it is that if phi weren't uniformly random it'd > mean that some phase was more likely than the rest. What phase would > it be and why is that one more likely? > > Eric Jacobsen > Minister of Algorithms > Abineau Communicationshttp://www.ericjacobsen.org > > Blog:http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.phpThat's right. Another way to argue is that even if the phenomena causing the phase mismatch were not uniformly distributed, the variance of this phenomena is more than likely sufficient such that the remainder after taking modulo 2\pi yields a uniform distribution. Julius
