>On Aug 22, 5:57=A0am, "cpshah99" <cpsha...@rediffmail.com> wrote: >> >On Aug 21, 1:52 pm, "cpshah99" <cpsha...@rediffmail.com> wrote: >> >> >> HI Julius >> >> >> Thanks again. >> >> >> I used the same channel for QPSK and 16 QAM. >> >> >> Now, in the case of 16 QAM, just to see if my receiver right or not,I>> >> removed the noise and instead of channel I juts made it awgn. It >> worked >> >> nice, no errors. >> >> >> And also after adding channel and noise, I checked the raw scatter >> plot >> >> after the equalisation. It was very scary.... >> >> >> And can u please tell the factors to be considered. >> >> >> Thanks again. >> >> >> Chintan >> >> >Um. =A0How about just the channel and no noise? >> >> Hi >> >> No improvement.... > >Chintan, what do you mean "no improvement". Nobody can help >you unless they can understand what you are saying. >%%%% Hi Julius Extremely sorry for not replying properly. As u had said to run with channel effect and 'no noise', and I did the simulation, but still I am getting errors even at high SNRs. I think the adaptive equaliser is not working or 16 QAM is too sensitive to multipath. Thanks Chintan
Channel Modelling
Started by ●August 21, 2008
Reply by ●August 22, 20082008-08-22
On Aug 22, 8:44�am, "cpshah99" <cpsha...@rediffmail.com> wrote:> > Hi Julius > > Extremely sorry for not replying properly. > > As u had said to run with channel effect and 'no noise', and I did the > simulation, but still I am getting errors even at high SNRs. > > I think the adaptive equaliser is not working or 16 QAM is too sensitive > to multipath. > > Thanks > > ChintanOK, so what is the amount of ISI without equalization, and what is the amount of ISI after equalization? How does the channel look like after equalization?
