OFDM in flat fading
Started by Neetukath ●August 23, 2008
Can any body let me know whether the simulations to determine the BER Vs.
SNR for flat fading channels( May be rayleigh or Rician) are valid or not?
Thanks,
Neetu
On Aug 23, 12:18&#4294967295;pm, "Neetukath" <neetu.k...@gmail.com> wrote:
> Can any body let me know whether the simulations to determine the BER Vs. > SNR for flat fading channels( May be rayleigh or Rician) are valid or not? > > Thanks, > Neetu
Does not validity depend on what the simulation is supposed to simulate? :-). Is your channel of interest flat fading or not? :-)
> Can any body let me know whether the simulations to determine > the BER Vs. SNR for flat fading channels( May be rayleigh > or Rician) are valid or not?
"Flat fading" means the fade is across the entire band of interest, therefore all OFDM tones are attenuated equally, therefore the simulation is the same for AWGN, just with a lower SNR corresponding to the amount of fade. Unless they've invented a new definitin of "flat fading" recently, which is possible. The opposite of flat fading is frequency-selective fading. Steve
On Aug 27, 2:40 pm, spop...@speedymail.org (Steve Pope) wrote:
> On Aug 23, 12:18 pm, "Neetukath" <neetu.k...@gmail.com> wrote: > > > Can any body let me know whether the simulations to determine > > the BER Vs. SNR for flat fading channels( May be rayleigh > > or Rician) are valid or not? > > "Flat fading" means the fade is across the entire band of > interest, therefore all OFDM tones are attenuated equally, > therefore the simulation is the same for AWGN, just with > a lower SNR corresponding to the amount of fade. > > Unless they've invented a new definitin of "flat fading" > recently, which is possible. > > The opposite of flat fading is frequency-selective fading. > > Steve
Not new, just less general. How about slow and fast frequency flat fading? What you describe above is certainly one simulation approach for flat slow fading channels but how would the model the inter- carrier-interference in flat fast fading? col
>> "Flat fading" means the fade is across the entire band of >> interest, therefore all OFDM tones are attenuated equally, >> therefore the simulation is the same for AWGN, just with >> a lower SNR corresponding to the amount of fade.
>> Unless they've invented a new definitin of "flat fading" >> recently, which is possible.
>Not new, just less general. How about slow and fast frequency flat >fading? What you describe above is certainly one simulation approach >for flat slow fading channels but how would the model the inter- >carrier-interference in flat fast fading?
Let's see. "Medium-fast" flat fading would have fade levels which vary between OFDM symbols but which are constant within a symbol. Even faster flat-fading would vary within a symbol. To a first order the latter effect would just show up as more noise. You wouldn't need to ocnsider ICI unless it is frequency-selective. (Offhand opinion.) Steve
On Wed, 27 Aug 2008 19:17:51 +0000 (UTC), spope33@speedymail.org
(Steve Pope) wrote:
><cb135@hotmail.com> wrote: > >>On Aug 27, 2:40 pm, spop...@speedymail.org (Steve Pope) wrote: > >>> "Flat fading" means the fade is across the entire band of >>> interest, therefore all OFDM tones are attenuated equally, >>> therefore the simulation is the same for AWGN, just with >>> a lower SNR corresponding to the amount of fade. > >>> Unless they've invented a new definitin of "flat fading" >>> recently, which is possible. > >>> The opposite of flat fading is frequency-selective fading. > >>Not new, just less general. How about slow and fast frequency flat >>fading? What you describe above is certainly one simulation approach >>for flat slow fading channels but how would the model the inter- >>carrier-interference in flat fast fading? > >Let's see. "Medium-fast" flat fading would have fade levels >which vary between OFDM symbols but which are constant within >a symbol. Even faster flat-fading would vary within a symbol. >To a first order the latter effect would just show up as >more noise. > >You wouldn't need to ocnsider ICI unless it is frequency-selective. >(Offhand opinion.) > >Steve
Even if it were frequency selective ICI isn't a problem. That's the benefit of "orthogonality" between subcarriers. Frequency selectivity by itself doesn't disturb the orthogonality. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Aug 27, 4:54&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:
> > Even if it were frequency selective ICI isn't a problem. &#4294967295; That's the > benefit of "orthogonality" between subcarriers. &#4294967295; Frequency > selectivity by itself doesn't disturb the orthogonality. >
I think this is not quite correct. The orthogonalization comes from the FFT operator, which assumes periodic convolution. So if the channel length is larger than the cyclic prefix length, aka frequency selectivity is too severe, then ICI will happen, too, since the effect of convolving with the channel can no longer be modeled by periodic convolution.
On Wed, 27 Aug 2008 15:33:00 -0700 (PDT), julius <juliusk@gmail.com>
wrote:
>On Aug 27, 4:54&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: >> >> Even if it were frequency selective ICI isn't a problem. &#4294967295; That's the >> benefit of "orthogonality" between subcarriers. &#4294967295; Frequency >> selectivity by itself doesn't disturb the orthogonality. >> > >I think this is not quite correct. The orthogonalization comes from >the FFT operator, which assumes periodic convolution. So if the >channel length is larger than the cyclic prefix length, aka frequency >selectivity is too severe, then ICI will happen, too, since the effect >of convolving with the channel can no longer be modeled by periodic >convolution.
Yup. I was assuming the OFDM system was properly designed for the channel, i.e., there is adequate CP length, in which case there's no ICI due to the frequency selectivity. But frequency synchronization is never perfect, so there's always ICI in practice. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Well, here's my thinking, which is orthogonal to either of the above. If the channel is frequency-selective, then you have the possible scenario of energy from stronger tones spilling over onto the weaker tones. This is going to be more of a noticeable impairment than in the flat-fading case. You still will get ICI in the latter case (from non-linearities or from different FFT timebases if you fail to correct for this), but you won't get disproportionate ICI on weaker tones. Steve
On Aug 28, 5:02&#4294967295;am, spop...@speedymail.org (Steve Pope) wrote:
> julius &#4294967295;<juli...@gmail.com> wrote: > >On Aug 27, 4:54&#4294967295;pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> Even if it were frequency selective ICI isn't a problem. &#4294967295; That's the > >> benefit of "orthogonality" between subcarriers. &#4294967295; Frequency > >> selectivity by itself doesn't disturb the orthogonality. > >I think this is not quite correct. &#4294967295;The orthogonalization comes from > >the FFT operator, which assumes periodic convolution. &#4294967295;So if the > >channel length is larger than the cyclic prefix length, aka frequency > >selectivity is too severe, then ICI will happen, too, since the effect > >of convolving with the channel can no longer be modeled by periodic > >convolution. > > Well, here's my thinking, which is orthogonal to either of the above. > > If the channel is frequency-selective, then you have the possible > scenario of energy from stronger tones spilling over onto the weaker > tones. &#4294967295;This is going to be more of a noticeable impairment than > in the flat-fading case. &#4294967295;You still will get ICI in the latter > case (from non-linearities or from different FFT timebases if you fail > to correct for this), but you won't get disproportionate > ICI on weaker tones. > > Steve
That still wraps back to the adequate CP-length argument. If there's so large a variation in the channel from one tone to the other as to cause disproportionate increase in interference on a neighbouring tone, the sudden channel variation in frequency would result in the impulse response spreading out over a large time duration exceeding the designed CP. There's a limit to how much the CP can be increased, and that depends on the symbol duration, which in turn depends on the carrier spacing. A smaller carrier spacing produces an intermediate carrier which is not as disproportionately affected by a sudden channel fade, and allows for a larger CP.
