Hi experts, I am working with TI DM6446 ( DaVinci EVM )which has a 64x+ core and ARM9 Core. I am developing an interrupt driven application in the 64x+ core ( Code Composer Studio project). In this context I see a strange behaviour when the CCS project uses TI Chip Support Library (CSL) for configuring Interrupt handlers. The interrupt latency is very huge, of the order of 3-4 microseconds. However, when DSP BIOS is used for Interrupt handler configuration, the latency is only 1-2 microseconds. Has any one seen such kind of latency? Interestingly, if I setup the Interrupt handler ( without CSL or DSP BIOS) by properly setting the relevant registers and vector table, I get still lower latency. FYI, the 64+ core is operating at 594Mhz and is expected to give only a latency of less than 15 clock cycles. I am calculating the latency by measuring the width of a pulse on a GPIO pin of the DSP, which is set high when interrupt event occurs, and reset the begining of the ISR. This ensures that whatever error occurs in measurement ( even if GPIO pin latency is encountered) would be applicable to all 3 modes of Interrupt vector setting mentioned above. Now my question is , has any one encountered such high Interrupt latency while using TI CSL? If not can some one give a possible explanation for the behaviour ? If this is not the right forum to ask this question can some one direct me to the right place. Thanks in advance, Cheers Vishnu Prasad S.N
High Interrupt Latency with TI Chip Support Library
Started by ●August 23, 2008
Reply by ●August 24, 20082008-08-24
vishnupsn wrote:> Hi experts, > > I am working with TI DM6446 ( DaVinci EVM )which has a 64x+ core and ARM9 > Core. I am developing an interrupt driven application in the 64x+ core ( > Code Composer Studio project). In this context I see a strange behaviour > when the CCS project uses TI Chip Support Library (CSL) for configuring > Interrupt handlers. The interrupt latency is very huge, of the order of 3-4 > microseconds. However, when DSP BIOS is used for Interrupt handler > configuration, the latency is only 1-2 microseconds. Has any one seen such > kind of latency? Interestingly, if I setup the Interrupt handler ( without > CSL or DSP BIOS) by properly setting the relevant registers and vector > table, I get still lower latency. FYI, the 64+ core is operating at 594Mhz > and is expected to give only a latency of less than 15 clock cycles. > > I am calculating the latency by measuring the width of a pulse on a GPIO > pin of the DSP, which is set high when interrupt event occurs, and reset > the begining of the ISR. This ensures that whatever error occurs in > measurement ( even if GPIO pin latency is encountered) would be applicable > to all 3 modes of Interrupt vector setting mentioned above. > > Now my question is , has any one encountered such high Interrupt latency > while using TI CSL? If not can some one give a possible explanation for the > behaviour ? > > If this is not the right forum to ask this question can some one direct me > to the right place. > > > Thanks in advance, > > Cheers > > Vishnu Prasad S.N >When looking at interrupt latency I think there are 2 main components you should consider: 1) Delay in taking the interrupt due to interrupts being disabled. I don't know what else is happening in your system but certain library routines, etc. will disable interrupts while they are processing. This can cause interrupt latency. Also, the 64x+ core is uninterruptible during the delay slots of a branch, so tight loops can cause the device to be uninterruptible. This is less of a problem than it used to be due to the SPLOOP hardware that was introduced in the 64x+ core. 2) Delay in the interrupt handler. In the case of DSP/BIOS you have the choice of using the HWI_dispatcher or plugging the interrupt directly into the table. Using the HWI_dispatcher is recommended but it will add a small amount more latency. You're talking about 1200 cycles of interrupt latency using DSP/BIOS and 2400 cycles of latency using CSL. Try to break that down further to figure out what the CPU is doing during all those cycles. Brad
