Fixed point PI control
Started by sorenbirk September 9, 2008
glen herrmannsfeldt wrote:
> Tim Wescott wrote: >> sorenbirk wrote: > (snip) > >> You have two problems: What mathematical scheme to use, and how to >> translate your parameters so they make sense in your scheme. You've >> further complicated your problem by expressing a time quantity (Ti) as >> a dimensionless number, when it has to have some time units behind it >> -- seconds? Sample intervals? Hours? If your Ti is in anything >> other than control sample intervals, then you need to know your >> sampling rate, too (and you should be questioning how you're going to >> convert your controller design in the Laplace domain into a z domain >> model that you can use to design your difference equations for your >> software). > > I thought the question was how to do scaled fixed point arithmetic. > That is at least one question before getting much farther along > in the design. > > -- glen >
As I read it the question was "How do I translate Kp and Ti using fixed point arithmetic". Since you can't translate Ti without knowing it's dimensions or your sampling rate, with or without fixed point arithmetic, I felt the OP needed more than a treatise on fixed point arithmetic. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
