Hi there, I calculate SINR for OFDM system as: (TP. pathloss.|CG|^2)/(cov + TP_ou. pathloss_ou.|CG_ou|^2) where, TP: Transmit Power TP_ou: Transmit Power of other users CG: Channel Gain CG_OU: Channel Gain of other users cov: Covariance of AWGN Then, how can I calculate SINR for OFDMA systems. What will be the effect of multiple access on SINR? Thank you!
SINR (OFDM and OFDMA)
Started by ●September 15, 2008
Reply by ●September 16, 20082008-09-16
On 15 Sep., 20:19, "patrick_dbg" <sanindl...@gmail.com> wrote:> Hi there, > > I calculate SINR for OFDM system as: > > (TP. pathloss.|CG|^2)/(cov + TP_ou. pathloss_ou.|CG_ou|^2) > > where, > TP: � �Transmit Power > TP_ou: Transmit Power of other users > CG: � �Channel Gain > CG_OU: Channel Gain of other users > cov: � Covariance of AWGN > > Then, how can I calculate SINR for OFDMA systems. What will be the effect > of multiple access on SINR? > > Thank you!Hi, If I am not wrong, the multiple access would not necessarily influence your SINR formula. Infact, ISI and Intercarrier interference and interference from the other users or base stations can be included in your OFDM itself. I hope it helps. Saint
