Hi, I like to know the procedure to subsample an image in frequency domain For example Image = 121 122 131 141 123 132 141 152 101 97 191 120 100 41 40 78 Sub sampled image is average of 2X2 sub matrix without overlap Result ------------ Sub sampled image = 124.5 141.25 84.75 107.25 The procedure 1. I have converted Image into frequency domain using Fast Fourier transform 2. Subsample in frequency domain (I like to know this part, pls help out to solve this problem) 3. Convert it to time domain , I like get result as I shown above I really appreciate if you refer me any website which gives detailed study of sub sampling in Fourier domain
Sub sampling in frequency domain
Started by ●September 16, 2008
Reply by ●September 17, 20082008-09-17
saravanan wrote:> Hi, > > I like to know the procedure to subsample an image in frequency domain > > For example > Image = > 121 122 131 141 > 123 132 141 152 > 101 97 191 120 > 100 41 40 78 > > Sub sampled image is average of 2X2 sub matrix without overlap > > Result > ------------ > Sub sampled image = > > 124.5 141.25 > 84.75 107.25 > > > The procedure > 1. I have converted Image into frequency domain using Fast Fourier > transform > 2. Subsample in frequency domain (I like to know this part, pls help > out to solve this problem) > 3. Convert it to time domain , I like get result as I shown above > > I really appreciate if you refer me any website which gives detailed > study of sub sampling in Fourier domainSubsampling or downsampling is well treated in comp.dsp, dspguru, etc. Most of what you'll find is for 1-D but the principles are the same: 1) Lowpass filter the data to avoid aliasing - so in your case this would be "lowpass" in the spatial domain or convolution in the frequency domain with a 2-D sinc-like function. A type of localized averaging... 2) Reduce the sample rate in frequency after having done the filtering. Some methods will be better than others for your purposes. Also check sci.image.processing. Sometimes practical image processing skips steps that signal processing folks would want to use. Fred
