I have XDS510 USB simulator, and it can work well with DM642. In my new project, the DM648 is used. While does it also support DM648? Need I buy another XDS560 simulator?
XDS510 supports DM648 or not?
Started by ●September 16, 2008
Reply by ●September 17, 20082008-09-17
Hi vcar, Don't know what you mean with "simulator" as XCS510 USB is the name of a JTAG programming interface (hardware) to the DSP. It has at first nothing to do with a "simulator". But I suggest it should work also for DM648. Regards, Greg "vcar" <hitsx@hit.edu.cn> schrieb im Newsbeitrag news:a2af3b72-2227-4085-b832-ab1e1886acf8@s1g2000pra.googlegroups.com...>I have XDS510 USB simulator, and it can work well with DM642. In my > new project, the DM648 is used. While does it also support DM648? Need > I buy another XDS560 simulator?
On Sep 17, 5:10�pm, "Greg" <G...@nospam.ca> wrote:> Hi vcar, > > Don't know what you mean with "simulator" as XCS510 USB is the name of a > JTAG programming interface (hardware) to the DSP. > It has at first nothing to do with a "simulator". > But I suggest it should work also for DM648. > > � � � � � � � � � � � � � � � � � � Regards, Greg > > "vcar" <hi...@hit.edu.cn> schrieb im Newsbeitragnews:a2af3b72-2227-4085-b832-ab1e1886acf8@s1g2000pra.googlegroups.com... > > > > >I have XDS510 USB simulator, and it can work well with DM642. In my > > new project, the DM648 is used. While does it also support DM648? Need > > I buy another XDS560 simulator?- Hide quoted text - > > - Show quoted text -I misuse the word "simulator", and what I mean is that I have XDS510 USB hardware emulator. The problem is that I do not know whether this emulator could work well with DM648.
Hi vcar, As the emulator connects via JTAG I suppose (actually I haven't tested DM648) that there is no difference. I would give it a try. (If there is a JTAG hook possibility on your target board). Regards.
vcar wrote:> I have XDS510 USB simulator, and it can work well with DM642. In my > new project, the DM648 is used. While does it also support DM648? Need > I buy another XDS560 simulator?Since this is a recent device you will need recent drivers. Download the latest emulation drivers from Spectrum Digital: http://support.spectrumdigital.com/ccs33/ It has a DM648 target defined for cc_setup. Brad
