Hi, I was trying to reuse my old RAKE receiver matlab code which also includes delay acquisition and channel estimation. It still works fine for AWGN, but it doesn't work at all when I try to use it with a fading channel generated by using the 'rayleighchan' function from Matlab. So I tried a few tests: 1) Instead of using the estimated channel coefficients, I let the RAKE receiver have perfect CSI. 2) I used integer number of delays for multi-paths, so that my RAKE receiver has accurate information of the delays as well. No delay acquisition. Even then I could not get the RAKE receiver to work. I should mention that the doppler frequency I used was close to 10 Hz, which is too small to be a problem. When I created the multipath channel myself (using the tapped delay line model), I could get my RAKE receiver to work perfectly (see matlab code below). So what the heck is 'rayleighchan' doing that is different from building a TDL model? I am also including some matlab test code that might help anyone who is interested in this problem to better understand it. Thanks in advance for any inputs! BR, Prasanna %============= %Matlab code: %============= clear all SF = 128; % Generate OVSF codes ovsf_codes = hadamard(SF); % Generate Gold code sequence % Sequence in the file is generated using the m-script |gold_seq_gen.m| load ScramblingCodes.mat scr; % Constellation for QPSK mapping qpskcon = [1+i, -1+i, 1-i, -1-i]; dpch_mod = qpskcon(randint(1, 2560/SF, 4)+1); dpch_spread = kron(dpch_mod,ones(1,SF)).*kron(ones(1,2560/SF),ovsf_codes(2,:)); pich_spread = (1+i)*ones(1,2560); % using all one ovsf code tx_signal = (dpch_spread + pich_spread) .* scr(1:2560); ChannelCoeff = 0.5*[1+i, 1-i]; delay = [0,8]; %% Uncomment the following four lines to use 'rayleighchan' % doppler_freq = 10; % Hz % fading_channel = rayleighchan(1/3.84e6, doppler_freq, delay/3.84e6); % faded_signal = filter(fading_channel, tx_signal); % ChannelCoeff = fading_channel.PathGains; %% Comment the following line to use 'rayleighchan' faded_signal = ChannelCoeff(1)*tx_signal + ChannelCoeff(2)*[zeros(1,8), tx_signal(1:end-8)]; rx_signal = faded_signal; % RAKE finger1 = rx_signal .* conj(scr(1:2560)); dpch_despread1 = sum ( reshape(finger1, 128, 2560/128) .* repmat(ovsf_codes(2,:).',1,2560/128), 1) / 128; pich_despread1 = sum ( reshape(finger1, 128, 2560/128) , 1) / 128; finger2 = [zeros(1,8), rx_signal(1:end-8)] .* conj(scr(1:2560)); dpch_despread2 = sum ( reshape(finger2, 128, 2560/128) .* repmat(ovsf_codes(2,:).',1,2560/128), 1) / 128; pich_despread2 = sum ( reshape(finger2, 128, 2560/128) , 1) / 128; dpch_demod = dpch_despread1 * conj(ChannelCoeff(1)) + dpch_despread2 * conj(ChannelCoeff(2)); %% Compare dpch_mod and dpch_demod in whatever way you choose. I do it by a constellation plot.
Matlab 'rayleighchan' and RAKE receiver.
Started by ●September 17, 2008
Reply by ●September 17, 20082008-09-17
>% RAKE >finger1 = rx_signal .* conj(scr(1:2560)); >dpch_despread1 = sum ( reshape(finger1, 128, 2560/128) .* >repmat(ovsf_codes(2,:).',1,2560/128), 1) / 128; >pich_despread1 = sum ( reshape(finger1, 128, 2560/128) , 1) / 128; >finger2 = [zeros(1,8), rx_signal(1:end-8)] .* conj(scr(1:2560));I should have had this as finger2 = [rx_signal(9:end) zeros(1,8)] .* conj(scr(1:2560)); Then it works fine. I now have to go figure out why my old RAKE doesn't work... may be it has a similar problem. BR, Prasanna
