>SteveSmith <Steve.Smith1@SpectrumSDI.com> wrote: > >>Hi Steve, > >>I had the same idea, but after some thought there is a point that Ireally>>don't understand. > >>Say we start with x[n], and run it through a low-pass filter to create >>xl[n]. We then could form the matching high-pass filter by calculating >>xh[n] = x[n] - xl[n]. Since x[n] = xl[n] + xh[n], the frequencyresponses>>of the two filters should add to unity, as we would like. > >>The problem is, working through the algebra, the energy in xl[n] plusthe>>energy in xh[n] doesn't seem to add up to the energy in the originalsignal>>x[n]. What am I missing here? > >If the low-pass filter were zero-phase, then the energy would >be equal. > >However if there is phase shift through the low-pass filter, then you >are right it does not add up. To illustrate this, consider the >case of a frequency at which the lowpass filter has a gain >of 0.1 and a phase shift of 180 degrees. > >Depending on your application and your signal, if using this approach >you may need to use a zero-phase-shift filter, or you may get away >with a (simpler) filter that has some phase shift but does >not give too much of an incorrect result. > >Steve >Ah yes, the Phase problem. It seems I forget this every few years and try to rediscover the wheel. Thanks!
spectral band energy detection
Started by ●September 17, 2008
Reply by ●September 18, 20082008-09-18
