Hi everyone, I am having a spectrum digital emulator board with TMS320c5416 dsp. I bought that and i installed the CCS in my desktop. When I connect the board and start the CCS, the USB is enumerated but then a error window is coming. It is like this title of the window: CPU_1- DSP DEVICE DRIVER. CONTENT: CAN'T INITIALIZE TARGET CPU I/O PORT : 540 BOARD NAME: SDGO5416DSK (SPECTRUM DIGITAL) CPU NAME: CPU_1 then four buttons to abort/retry/ignore/diagnostic are there. even if i run diagnostic, the emulator diagnostic is failing. Can anyone help me in this? Thank you.
ccs problem
Started by ●September 26, 2008
Reply by ●September 29, 20082008-09-29
On Fri, 26 Sep 2008 20:45:56 -0500, "krish_dsp" <nmkrish@gmail.com> wrote in comp.dsp:> Hi everyone, > I am having a spectrum digital emulator board with TMS320c5416 dsp. I > bought that and i installed the CCS in my desktop. When I connect the > board > and start the CCS, the USB is enumerated but then a error window is > coming. > It is like this > title of the window: CPU_1- DSP DEVICE DRIVER. > CONTENT: > CAN'T INITIALIZE TARGET CPU > I/O PORT : 540 > BOARD NAME: SDGO5416DSK (SPECTRUM DIGITAL) > CPU NAME: CPU_1 > > then four buttons to abort/retry/ignore/diagnostic are there. even if i > run diagnostic, the emulator diagnostic is failing. > Can anyone help me in this? > > Thank you.Run the SDConfig utility that is installed to your computer with the Spectrum digital drivers. Then run the setup CCS utility installed on your computer with CCS. I haven't used the USB emulators, but that is how it works with the parallel port ones. -- Jack Klein Home: http://JK-Technology.Com FAQs for comp.lang.c http://c-faq.com/ comp.lang.c++ http://www.parashift.com/c++-faq-lite/ alt.comp.lang.learn.c-c++ http://www.club.cc.cmu.edu/~ajo/docs/FAQ-acllc.html
