Suppose I have a signal that is buried in noise two or three orders of magnitude larger. The desired signal is coherent with a reference waveform in the low audio range. What will be the difference between mixing the incoming (noisy) signal, say x= (sin(w*t+alpha) + noise(t)) by multiplying by the reference y= sin(w*t+alpha) as opposed to using sgn(y) = sgn(sin(w*t+alpha) (IOW a gain of +1 for sin(..) > 0 and -1 for sin(...) < 0 ? Best regards, Spehro Pefhany -- "it's the network..." "The Journey is the reward" speff@interlog.com Info for manufacturers: http://www.trexon.com Embedded software/hardware/analog Info for designers: http://www.speff.com
Demodulating a signal buried in noise
Started by ●September 28, 2008
Reply by ●September 28, 20082008-09-28
Spehro Pefhany wrote:> Suppose I have a signal that is buried in noise two or three orders of > magnitude larger. The desired signal is coherent with a reference > waveform in the low audio range. > > What will be the difference between mixing the incoming (noisy) > signal, say x= (sin(w*t+alpha) + noise(t)) by multiplying by the > reference y= sin(w*t+alpha) as opposed to using sgn(y) = > sgn(sin(w*t+alpha) (IOW a gain of +1 for sin(..) > 0 and -1 for > sin(...) < 0 ?Asumming the noise is white, the difference is 3 dB. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Spehro Pefhany <speffSNIP@interlogDOTyou.knowwhat> wrote:>Suppose I have a signal that is buried in noise two or three orders of >magnitude larger. The desired signal is coherent with a reference >waveform in the low audio range.>What will be the difference between mixing the incoming (noisy) >signal, say x= (sin(w*t+alpha) + noise(t)) by multiplying by the >reference y= sin(w*t+alpha) as opposed to using sgn(y) = >sgn(sin(w*t+alpha) (IOW a gain of +1 for sin(..) > 0 and -1 for >sin(...) < 0 ?I would say one difference is that that sgn(sin(w*t)) has non-zero correlation with sin(2*w*t), sin(3*w*t), etc. so you are going to be getting noise components from these frequencies in your result. But the significance of this effect would be reduced if there is narrowband filtering ahead of your mixer. Steve
Reply by ●September 29, 20082008-09-29
On Sun, 28 Sep 2008 17:13:56 -0500, Vladimir Vassilevsky wrote:> Spehro Pefhany wrote: > >> Suppose I have a signal that is buried in noise two or three orders of >> magnitude larger. The desired signal is coherent with a reference >> waveform in the low audio range. >> >> What will be the difference between mixing the incoming (noisy) signal, >> say x= (sin(w*t+alpha) + noise(t)) by multiplying by the reference y= >> sin(w*t+alpha) as opposed to using sgn(y) = sgn(sin(w*t+alpha) (IOW a >> gain of +1 for sin(..) > 0 and -1 for sin(...) < 0 ? > > Assuming the noise is white, the difference is 3 dB. >... because in multiplying by a square wave you're letting in all of the noise energy associated with the odd harmonics of your carrier ('reference waveform'). But it's more like 1dB, because your desired signal is gained up by 4/pi (+2dB), but corrupted by a bunch of noise that rides in on the edges of the square wave (-3dB). So the end effect is that you lose a dB. Realistically, you may lose more if the noise tends to be worse at high frequencies, or if there's noise associated with the carrier frequency not quite matching up to the sampling rate. But maybe it's not too bad. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <tim@seemywebsite.com> wrote:>On Sun, 28 Sep 2008 17:13:56 -0500, Vladimir Vassilevsky wrote:>> Assuming the noise is white, the difference is 3 dB.>... because in multiplying by a square wave you're letting in all of the >noise energy associated with the odd harmonics of your carrier >('reference waveform').>But it's more like 1dB, because your desired signal is gained up by 4/pi >(+2dB), but corrupted by a bunch of noise that rides in on the edges > of the square wave (-3dB).I'm not sure I agree with this. The fourier expansion of a square wave has coefficients: 1 , 1/3, 1/5, 1/7 .... And so the 3dB value would be true only if 1^2 = (sum over k = 3, 5, 7...) ( 1 / (k^2)) which I don't think is the case, as the RHS of this expression is bounded from above by 1/4. I may, of course, have miscalculated somewhere. Steve
"Tim Wescott" <tim@seemywebsite.com> wrote in message news:7KednZUQk82I233VnZ2dnUVZ_obinZ2d@web-ster.com...> On Sun, 28 Sep 2008 17:13:56 -0500, Vladimir Vassilevsky wrote: > > > Spehro Pefhany wrote: > > > >> Suppose I have a signal that is buried in noise two or three orders of > >> magnitude larger. The desired signal is coherent with a reference > >> waveform in the low audio range. > >> > >> What will be the difference between mixing the incoming (noisy) signal, > >> say x= (sin(w*t+alpha) + noise(t)) by multiplying by the reference y= > >> sin(w*t+alpha) as opposed to using sgn(y) = sgn(sin(w*t+alpha) (IOW a > >> gain of +1 for sin(..) > 0 and -1 for sin(...) < 0 ? > > > > Assuming the noise is white, the difference is 3 dB. > > > > ... because in multiplying by a square wave you're letting in all of the > noise energy associated with the odd harmonics of your carrier > ('reference waveform'). > > But it's more like 1dB, because your desired signal is gained up by 4/pi > (+2dB), but corrupted by a bunch of noise that rides in on the edges of > the square wave (-3dB). So the end effect is that you lose a dB.Tim, I did the math. Taking the signal gained up, it is 3dB. VLV
>What will be the difference between mixing the incoming (noisy) >signal, say x= (sin(w*t+alpha) + noise(t)) by multiplying by the >reference y= sin(w*t+alpha) as opposed to using sgn(y) = >sgn(sin(w*t+alpha) (IOW a gain of +1 for sin(..) > 0 and -1 for >sin(...) < 0 ?Interesting question! If the filter following this operation is fairly sharp (with cut-off frequency less than 3w) then there is no difference. (Steve pointed this out. But as Tim pointed, there will only be odd harmonics in your case.) If an integrator follows this operation, then the loss in using the square wave multiplier is only 0.06 dB. If no filtering is applied, additional noise you will collect from all the harmonics (3w, 5w, ...) causes 0.91 dB higher (white) noise power. (Though I can't think of a good reason for not using a filter in sequel.) At any rate, 0.91 dB is the upper bound to the amount of extra noise; it should not get any worse than that given the noise is white. (Bravo, Tim, for your offhand precision.) Emre
>If the filter following this operation is fairly sharp (with cut-off >frequency less than 3w) then there is no difference. (Steve pointed this >out. But as Tim pointed, there will only be odd harmonics in your case.)Sorry, the filtering needs to be before this operation (as Steve said), if you want to eliminate the effect.>If an integrator follows this operation, then the loss in using thesquare>wave multiplier is only 0.06 dB.Never mind this. An integrator can't precede this operation anyway (it would destroy the signal), and it doesn't help afterwards.>If no filtering is applied, additional noise you will collect from allthe>harmonics (3w, 5w, ...) causes 0.91 dB higher (white) noise power.The answer still remains the same when there is no pre-filtering. Roughly 1 dB. If anyone is wondering, this is how I got the answer in Matlab: n = 1:2:1000; 10*log10(sum(1./n.^2)) ans = 0.9103 as the Fourier series coefficients of the pulse train given by sgn(sin(wt)) decay with 1/n for odd n, and are zero for even n. Emre
emre <eguven@ece.neu.edu> wrote:>The answer still remains the same when there is no pre-filtering. Roughly >1 dB. If anyone is wondering, this is how I got the answer in Matlab: >n = 1:2:1000; >10*log10(sum(1./n.^2)) >ans = 0.9103I agree with this method, and got a number just around 0.9 dB with the formula given in my last post. Tangentially: I once saw a 2.4 GHz direct-conversion radio that drove the mixer with a 800 MHz square wave. This way the third harmonic of the signal injected into the mixer was the actual component used. It was cheap, and (with a ceramic RF filter) it actually worked. Steve
I had trouble desiphering teh question but you mean using a purecoherent sine way as opposed to a coherent square wave! I wish people would use English! In a word - bugger all. Hardy Spehro Pefhany wrote:> Suppose I have a signal that is buried in noise two or three orders of > magnitude larger. The desired signal is coherent with a reference > waveform in the low audio range. > > What will be the difference between mixing the incoming (noisy) > signal, say x= (sin(w*t+alpha) + noise(t)) by multiplying by the > reference y= sin(w*t+alpha) as opposed to using sgn(y) = > sgn(sin(w*t+alpha) (IOW a gain of +1 for sin(..) > 0 and -1 for > sin(...) < 0 ? > > > > Best regards, > Spehro Pefhany > -- > "it's the network..." "The Journey is the reward" > speff@interlog.com Info for manufacturers: http://www.trexon.com > Embedded software/hardware/analog Info for designers: http://www.speff.com
